查看: 6257|回复: 1
RT1021 使用IAR下载时提示unloaded macro file
发表于 2019-5-8 13:41:37 | 显示全部楼层 |阅读模式
Wed May 08, 2019 13:38:56: IAR Embedded Workbench 8.32.2 (C:\Program Files (x86)\IAR Systems\Embedded Workbench 8.2\arm\bin\armproc.dll)
Wed May 08, 2019 13:38:56: Loaded macro file: C:\Program Files (x86)\IAR Systems\Embedded Workbench 8.2\arm\config\debugger\NXP\iMXRT.dmac
Wed May 08, 2019 13:38:56: Loaded macro file: C:\Program Files (x86)\IAR Systems\Embedded Workbench 8.2\arm\config\flashloader\NXP\FlashIMXRT1020_EVK_FlexSPI.mac
Wed May 08, 2019 13:38:56: Loading the CMSIS-DAP driver
Wed May 08, 2019 13:38:56: Probe: CMSIS-DAP probe SW module ver 1.17
Wed May 08, 2019 13:38:56: Probe: Connecting to Fire CMSIS-DAP:HS-00004378 firmware v.1.0
Wed May 08, 2019 13:38:56: Emulation layer version 4.42
Wed May 08, 2019 13:38:56: Notification to init-after-power-up hookup.
Wed May 08, 2019 13:38:56: Notification to core-connect hookup.
Wed May 08, 2019 13:38:56: Connected DAP v1 on SWD. Detected IDCODE=0xbd11477.
Wed May 08, 2019 13:38:57: Connecting to TAP#0 DAP AHB-AP port 0 (IDR=0x4770041).
Wed May 08, 2019 13:38:57: Recognized CPUID=0x411fc271 Cortex-M7 r1p1 arch ARMv7-M
Wed May 08, 2019 13:38:57: Set cacheable access on AHB-AP port 0 (HPROT=0xeb000000).
Wed May 08, 2019 13:38:57: Debug resources: 8 instruction comparators, 4 data watchpoints.
Wed May 08, 2019 13:38:57: MultiCore: Asynchronous core execution FORCED.
Wed May 08, 2019 13:38:57: MultiCore: Synchronous core execution DISABLED.
Wed May 08, 2019 13:38:57: LowLevelReset(hardware, delay 200)
Wed May 08, 2019 13:38:58: Notification to init-after-hw-reset hookup.
Wed May 08, 2019 13:38:58: Connecting to TAP#0 DAP AHB-AP port 0 (IDR=0x4770041).
Wed May 08, 2019 13:38:58: Recognized CPUID=0x411fc271 Cortex-M7 r1p1 arch ARMv7-M
Wed May 08, 2019 13:38:58: Set cacheable access on AHB-AP port 0 (HPROT=0xeb000000).
Wed May 08, 2019 13:38:58: Debug resources: 8 instruction comparators, 4 data watchpoints.
Wed May 08, 2019 13:38:58: CPU status - IN RESET
Wed May 08, 2019 13:38:58: Loaded debugee: C:\Program Files (x86)\IAR Systems\Embedded Workbench 8.2\arm\config\flashloader\NXP\FlashIMXRT1020_EVK_FlexSPI.out
Wed May 08, 2019 13:38:59: Target reset
Wed May 08, 2019 13:38:59: ----- Prepare hardware for Flashloader2 -----
Wed May 08, 2019 13:39:07: Unloaded macro file: C:\Program Files (x86)\IAR Systems\Embedded Workbench 8.2\arm\config\flashloader\NXP\FlashIMXRT1020_EVK_FlexSPI.mac
Wed May 08, 2019 13:39:07: IAR Embedded Workbench 8.32.2 (C:\Program Files (x86)\IAR Systems\Embedded Workbench 8.2\arm\bin\armproc.dll)
Wed May 08, 2019 13:39:07: Loading the CMSIS-DAP driver
卡在如下图界面
发表于 2019-5-13 16:46:48 | 显示全部楼层
在解答之前,我需要你提供一些信息,比如板子是否是官方板子,还有测试的代码和测试过程,以及这个现象是否是现在才出现,以前debug成功过等等
GMT+8, 2025-10-26 11:02 , Processed in 0.091808 second(s), 21 queries , MemCache On.
