查看: 2367|回复: 1
[求助] 關於GPIO腳位與地線對接問題
发表于 2019-5-15 16:01:48 | 显示全部楼层 |阅读模式
先上代碼
  1. #include "derivative.h" /* include peripheral declarations SKEAZ128M4 */
  2. #define PTE7 7
  3. //#define OUTPUT_TOGGLE(PTE,PTE7)
  4. #define PTI5 5        /* Port PTE4, bit 4: input from BTN0*/
  5. #define PTI4 4
  6. int main(void) {
  7.         GPIOC_PDDR &= ~(1<<PTI4);
  8.         GPIOC_PIDR &= ~(1<<PTI4);
  9.         PORT_PUE2 |= 1<<PTI4;
  10.         GPIOC_PDDR &= ~(1<<PTI5);
  11.         GPIOC_PIDR &= ~(1<<PTI5);
  12.         PORT_PUE2 |= 1<<PTI5;
  13.
  14.         GPIOB_PDDR |= 1<<PTE7;
  15.         GPIOB_PIDR &= 1<<PTE7;
  16.   for(;;) {
  17.     if (GPIOC_PDIR & (1<<PTI4))  {        /* If Pad Data Input = 1 (BTN0 [SW2] not pushed) */
  18.             GPIOB_PCOR |= 1<<PTE7;                /* Set Output on port E7 (LED off) */
  19.     }else if (GPIOC_PDIR & (1<<PTI5))  {        /* If Pad Data Input = 1 (BTN0 [SW2] not pushed) */
  20.             GPIOB_PCOR |= 1<<PTE7;                /* Set Output on port E7 (LED off) */
  21.     }
  22.     else {                                                        /* If BTN0 was pushed */
  23.             GPIOB_PSOR |= 1<<PTE7;                /* Clear Output on port E7 (LED on) */
  24.     }
  25.   }
  26. }
上面的寫法 }else if (GPIOC_PDIR & (1<<PTI5)) { 是不會作動的
兩個都寫if     if (GPIOC_PDIR & (1<<PTI4))會不作動
目前要用這類似HIGH LOW的東西來寫控制馬達
能否求助? 我有點束手無策
我知道答案 目前已有1人回答
发表于 2019-5-16 10:07:14 | 显示全部楼层
检查一下GPIO时钟是否使能了,建议可以参考此链接的代码分享
https://www.nxpic.org.cn/module/forum/thread-603403-1-1.html
GMT+8, 2025-10-25 11:09 , Processed in 0.089981 second(s), 22 queries , MemCache On.
