查看: 3467|回复: 0
[S32] opensda升级成jlink 能检测到型号却不能下载
    郁闷
    2019-8-9 13:47
    发表于 2019-6-24 10:49:50 | 显示全部楼层 |阅读模式
    SEGGER J-Link Commander V6.14b (Compiled Mar  9 2017 08:46:23)
    DLL version V6.14b, compiled Mar  9 2017 08:46:04
    Connecting to J-Link via USB...O.K.
    Firmware: J-Link OpenSDA 2 compiled May 27 2019 11:01:03
    Hardware version: V1.00
    S/N: 621000000
    VTref = 3.300V
    Type "connect" to establish a target connection, '?' for help
    J-Link>connect
    Please specify device / core. <Default>: MK20DX128XXX5
    Type '?' for selection dialog
    Device>MK20DX128XXX5
    Please specify target interface:
      J) JTAG (Default)
      S) SWD
    TIF>S
    Specify target interface speed [kHz]. <Default>: 4000 kHz
    Speed>4000
    Device "MK20DX128XXX5" selected.
    Found SWD-DP with ID 0x2BA01477
    Protection bytes in flash at addr. 0x400 - 0x40F indicate that readout protection is set.
    For debugger connection the device needs to be unsecured.
    Note: Unsecuring will trigger a mass erase of the internal flash.
    Executing default behavior previously saved in the registry.
    Device will be unsecured now.
    ****** Error: Kinetis (connect): Timeout while unsecuring device. Erase never starts.
    Kinetis (connect): Failed to unsecure Kinetis device.
    Cannot connect to target.
    J-Link>
    我知道答案 目前已有0人回答
    GMT+8, 2026-4-10 02:27 , Processed in 0.089474 second(s), 22 queries , Redis On.
