查看: 3781|回复: 2
[求助] imx8不支持1366*768显示
发表于 2019-7-12 15:13:30 | 显示全部楼层 |阅读模式
[    1.158048] [drm] VCO frequency (2160000 KHz) is supported. Settings found in row 1
[    1.189590] [drm] CDN_API_General_Write_Register_blocking LANES_CONFIG ret = 0
[    1.198550] [drm] hdmi-audio-codec driver bound to HDMI
[    1.203806] imx-drm display-subsystem: bound 32c00000.hdmi (ops imx_hdp_imx_ops)
[    1.235291] 0,ff,ff,ff,ff,ff,ff,0
[    1.238629] i.mx8-hdp 32c00000.hdmi: 0,ff,ff,ff,ff,ff,ff,0
[    1.244136] drm_add_edid_modes:current quirks:0
[    1.248744] add_detailed_modes:current num_modes:6
[    1.253550] add_cvt_modes:current num_modes:6
[    1.257922] drm_mode_std=hsize:1366,vrefresh_rate:60,vsize:768,aspect_ratio:3
[    1.265075] drm_mode_std=hsize:1920,vrefresh_rate:60,vsize:1080,aspect_ratio:3
[    1.272311] add_standard_modes:1,closure.modes:0
[    1.276940] add_standard_modes:current num_modes:7
[    1.281761] add_established_modes:current num_modes:17
[    1.286931] add_cea_modes:current num_modes:32
[    1.291610] add_alternate_cea_modes:current num_modes:42
[    1.296936] add_displayid_detailed_modes:current num_modes:42
[    1.302694] current display_info.bpc:8
[    1.306459] drm_edid_to_eld use num_modes:42
[    1.315848] [drm] Link rate is too high - forcing link to lower rate
我知道答案 目前已有2人回答
发表于 2019-7-16 15:40:02 | 显示全部楼层
请问你用的是哪块板子?
发表于 2019-7-16 15:49:30 | 显示全部楼层
请问你这里使用的是什么显示屏,你如何配置的参数?
GMT+8, 2025-10-27 02:30 , Processed in 0.089444 second(s), 23 queries , MemCache On.
