查看: 2278|回复: 0
NXPS08P+DAC输出
  • 签到天数: 273 天
    发表于 2019-7-25 13:37:47 | 显示全部楼层 |阅读模式
    S08P芯片没有DAC功能,但是板子上外挂了一个8位的DAC芯片DAC5571,S08P芯片通过IIC与DAC5571通讯。本次实现功能是S08P通过与DAC5571芯片输出电压,然后用S08P芯片的ADC读取出来。
    官方已经有了各种测试例程,只要作删减保留自己所要的就能实现功能了。
    1、首先还是各种初始化:
        Sys_Init();
        EnableInterrupts;
        printf("\n-- S08-LITE DAC输出实现 --\n");
        printf("\n");
        //Initialize MTIM0, 625Hz interrupt interval, used for toggle LED
        MTIM0_Init();
        MTIM0_Start();
        //Initialize MTIM1, 1ms interrupt interval, used for 1ms time delay
        MTIM1_Init();
        //Initialize GPIO used for LED
        LED_Init();
        //Initialize ADC, 12bit mode
        ADC_Init();
        //Initialize I2C PTA2/3 used for DAC5571 write/read
        DAC5571_Init();
    2、本次实验的程序:
            void DAC5571WriteData(unsigned char u8Data)
                    /* send data to slave */
                    IIC_StartTransmission(DAC5571_I2C_ADDRESS, MWSR);
                    i2c_Wait();
                    /* Send I2C address */
                    I2C_D = u8Data>>4;
                    i2c_Wait();
                    /* Send data */
                    I2C_D = u8Data<<4;
                    i2c_Wait();
                    i2c_Stop();
                    delay();
            void DAC5571_Test(void)
                    unsigned short uiADC_Value;
                    unsigned long uiADC_Value_temp;
                    unsigned char i;
                    unsigned char dacOutputValue;
                    unsigned char dacOutputValueMin, dacOutputValueMax;
                    uint8_t temp;
                    //initialize adc channel to measure the dac output
                    if (DAC5571_ADC_CHANNEL<8)
                            temp = ADC_APCTL1;
                            temp |= (1<<DAC5571_ADC_CHANNEL);
                            ADC_APCTL1 = temp;
               else
                            temp = ADC_APCTL2;
                            temp |= (1<<(DAC5571_ADC_CHANNEL-8));
                            ADC_APCTL2 = temp;
                    printf("DAC5571 test: BEGINS\n");
                    while(1)
                            for(dacOutputValue=0; dacOutputValue<255; dacOutputValue++)
                                    DAC5571WriteData(dacOutputValue);
                                    DelayMS(1000);
                                    uiADC_Value = ADC_GetResult(DAC5571_ADC_CHANNEL);
                                    for (i=0; i<10; i++)
                                            uiADC_Value_temp = ADC_GetResult(DAC5571_ADC_CHANNEL);
                                            uiADC_Value_temp += uiADC_Value;
                                            uiADC_Value = (unsigned short)(uiADC_Value_temp/2);
                                    //8-bit DAC, 12-bit ADC, so the mapping ratio = 4096/256 = 16
                                    uiADC_Value = uiADC_Value /16;
                                    printf ("输出电压 :  %d\n", dacOutputValue);
                                    printf ("检测电压 :  %d\n", uiADC_Value);
    3、实验结果:
    专用芯片的DAC输出还是很准的!附上点资料,来自于网络
    DAC5571 使用心得.rar (398.93 KB, 下载次数: 5)
    GMT+8, 2026-4-5 03:47 , Processed in 0.095860 second(s), 22 queries , Redis On.
