查看: 4303|回复: 2
[求助] S32DS 编译例程的时候出现Segmentation fault错误
发表于 2019-7-26 16:31:17 | 显示全部楼层 |阅读模式
问题出现的过程如下,电脑安装S32DS,一切默认安装。
安装后 File -> New -> S32DS project from example 直接选一个 hello_s32k144 的例程添加进来,直接编译,结果报错,完整的编译信息如下,错误信息为红字部分:
16:28:59 **** Incremental Build of configuration Debug for project hello_s32k144 ****
make -j4 all
Building file: ../Project_Settings/Startup_Code/startup.c
Building file: ../Project_Settings/Startup_Code/startup_S32K144.S
Building file: ../Project_Settings/Startup_Code/system_S32K144.c
Executing target #1 ../Project_Settings/Startup_Code/startup.c
Executing target #2 ../Project_Settings/Startup_Code/startup_S32K144.S
Executing target #3 ../Project_Settings/Startup_Code/system_S32K144.c
Invoking: Standard S32DS C Compiler
arm-none-eabi-gcc "@Project_Settings/Startup_Code/startup.args" -MMD -MP -MF"Project_Settings/Startup_Code/startup.d" -MT"Project_Settings/Startup_Code/startup.o" -o "Project_Settings/Startup_Code/startup.o" "../Project_Settings/Startup_Code/startup.c"
Invoking: Standard S32DS Assembler
arm-none-eabi-gcc "@Project_Settings/Startup_Code/startup_S32K144.args" -o "Project_Settings/Startup_Code/startup_S32K144.o" "../Project_Settings/Startup_Code/startup_S32K144.S"
arm-none-eabi-gcc "@Project_Settings/Startup_Code/system_S32K144.args" -MMD -MP -MF"Project_Settings/Startup_Code/system_S32K144.d" -MT"Project_Settings/Startup_Code/system_S32K144.o" -o "Project_Settings/Startup_Code/system_S32K144.o" "../Project_Settings/Startup_Code/system_S32K144.c"
Building file: ../src/hello.c
Executing target #4 ../src/hello.c
arm-none-eabi-gcc "@src/hello.args" -MMD -MP -MF"src/hello.d" -MT"src/hello.o" -o "src/hello.o" "../src/hello.c"
make: *** [Project_Settings/Startup_Code/subdir.mk:59: Project_Settings/Startup_Code/startup_S32K144.o] Segmentation fault
make: *** Waiting for unfinished jobs....
make: *** [Project_Settings/Startup_Code/subdir.mk:51: Project_Settings/Startup_Code/startup.o] Segmentation fault
make: *** [Project_Settings/Startup_Code/subdir.mk:67: Project_Settings/Startup_Code/system_S32K144.o] Segmentation fault
make: *** [src/subdir.mk:35: src/hello.o] Segmentation fault
16:29:06 Build Finished (took 7s.688ms)
同样操作和安装包,换一台电脑就没问题,把工程复制到别的电脑下编译也是可以的,不知道是这台电脑的什么问题。系统win10 x64 ,别的电脑都OK,管理员权限也不行。
在NXP官网上看到有人问同样的问题,但是好像也没解决,链接如下:
http://community.nxp.com/thread/503947
由于某些原因,不能重装系统。希望有经验的大神指点一下,大概是哪方面的问题,不胜感激。
我知道答案 目前已有2人回答
发表于 2019-7-29 08:35:19 | 显示全部楼层
你试着重新安装一下S32看看
 楼主| 发表于 2019-8-5 15:36:08 | 显示全部楼层
小恩GG 发表于 2019-7-29 08:35
你试着重新安装一下S32看看
试过,还是不行。包括在管理员账户下卸载重装
GMT+8, 2026-4-20 01:20 , Processed in 0.079927 second(s), 23 queries , Redis On.
