查看: 3299|回复: 1
[求助] S9KEAZ128AMLH的FTM0怎样使用外部时钟
发表于 2019-8-30 15:29:39 | 显示全部楼层 |阅读模式
FTMx_CS  CLKS
Clock Source Selection
Selects one of the three FTM counter clock sources. This field is write protected. It can be written only when MODE[WPDIS] = 1.
00 No clock selected. This in effect disables the FTM counter.
01 System clock
10 Fixed frequency clock
11 External clock
请问这里的外部时钟是不是指的晶体振荡器时钟?
我的外部晶体振荡器时钟是16MHZ,选用11 External clock ,定时器不工作。选用系统时钟正常。
请问怎样使用External clock??
FTM初始化代码如下
        /* open the clock gate */
        SIM->SCGC |= SIM_SCGC_FTM0_MASK;
        NVIC_EnableIRQ(FTM0_IRQn);
         /* Ouput FTM0 Ch0/1 to PTA0/PTA1 */
        SIM->PINSEL &= (~SIM_PINSEL_FTM0PS0_MASK);
        SIM->PINSEL &= (~SIM_PINSEL_FTM0PS1_MASK);
        FTM0->SC  = 0x0;     /* diable counter */
        FTM0->MOD = 0xFFFF;  /* free running */
        FTM0->CONTROLS[0].CnSC = FTM_CnSC_CHIE_MASK | FTM_CnSC_ELSA_MASK | FTM_CnSC_ELSB_MASK;
        FTM0->CONTROLS[1].CnSC = FTM_CnSC_CHIE_MASK | FTM_CnSC_ELSA_MASK | FTM_CnSC_ELSB_MASK;
        FTM0->SC  = FTM_SC_PS(4) | FTM_SC_CLKS(3);
时钟初始化如下:
#elif (CLOCK_SETUP == 1)
   SIM->CLKDIV = SIM_CLKDIV_OUTDIV1(0x00); /* Update system prescalers */
   ICS->C2 &= (uint8_t)~(uint8_t)((ICS_C2_BDIV(0x07) | ICS_C2_LP_MASK));
   OSC->CR = (OSC_CR_OSCEN_MASK | OSC_CR_OSCOS_MASK | OSC_CR_RANGE_MASK);
   ICS->C1 = (ICS_C1_CLKS(0x00) | ICS_C1_RDIV(0x04) | ICS_C1_IRCLKEN_MASK);
   while((ICS->S & ICS_S_IREFST_MASK) != 0x00U) { /* Check that the source of the FLL reference clock is the external reference clock. */
   while((ICS->S & 0x0CU) != 0x00U) {    /* Wait until output of the FLL is selected */
#elif (CLOCK_SETUP == 2)
我知道答案 目前已有1人回答
发表于 2019-8-30 17:51:14 | 显示全部楼层
外部时钟是通过外部引脚输入的时钟。
你看下KEA128的参考手册,10.3.5 Timer modules。
TCLKn就是对应的FTM 外部时钟输入引脚。
GMT+8, 2026-4-17 08:18 , Processed in 0.090098 second(s), 22 queries , Redis On.
