查看: 5635|回复: 6
[求助] 【LPC55S6X】FreeRTOS中喂狗就复位
    2020-1-10 11:05
  • 签到天数: 13 天
    发表于 2019-9-4 14:24:46 | 显示全部楼层 |阅读模式
    问题: LPC55S6X跑FreeRTOS,开启了看门狗,只要一喂狗就复位???
    void watchdog_init(void)
            wwdt_config_t config;
        uint32_t wdtFreq;
            /* Enable FRO 1M clock for WWDT module. */
        SYSCON->CLOCK_CTRL |= SYSCON_CLOCK_CTRL_FRO1MHZ_CLK_ENA_MASK;
        /* Set clock divider for WWDT clock source. */
        CLOCK_SetClkDiv(kCLOCK_DivWdtClk, 1U, true);
            /* The WDT divides the input frequency into it by 4 */
        wdtFreq = CLOCK_GetFreq(kCLOCK_WdtClk) / 4;
            NVIC_EnableIRQ(WDT_BOD_IRQHandler);
            WWDT_GetDefaultConfig(&config);
         * Set watchdog feed time constant to approximately 4s
         * Set watchdog warning time to 512 ticks after feed time constant
         * Set watchdog window time to 1s
            config.timeoutValue = wdtFreq * 4;
        config.warningValue = 512;
        config.windowValue  = wdtFreq * 1;
        /* Configure WWDT to reset on timeout */
        config.enableWatchdogReset = true;
        /* Setup watchdog clock frequency(Hz). */
        config.clockFreq_Hz = CLOCK_GetFreq(kCLOCK_WdtClk);
            WWDT_Init(WWDT, &config);
    int main(void)
        CLOCK_AttachClk(BOARD_DEBUG_UART_CLK_ATTACH);
        BOARD_InitPins();
        BOARD_BootClockFROHF96M();
        BOARD_InitDebugConsole();
        PRINTF("Hello world.\r\n");
        watchdog_init();
        WWDT_Refresh(WWDT);
        if (xTaskCreate(hello_task, "Hello_task", configMINIMAL_STACK_SIZE + 10, NULL, hello_task_PRIORITY, NULL) != pdPASS)
            PRINTF("Task creation failed!.\r\n");
            while (1)
        vTaskStartScheduler();
        for (;;)
    static void hello_task(void *pvParameters)
        for (;;)
            WWDT_Refresh(WWDT);
            PRINTF("Hello task.\r\n");
            vTaskDelay(1000);
    你这是开启了窗口看门狗1-4s,然后1s没到就去喂狗了?
    哈哈哈哈哈哈哈啊哈哈哈
  • 签到天数: 139 天
    发表于 2019-9-5 08:55:07 | 显示全部楼层
    你把hello_task里面的延迟去掉,打印也去掉,试试
    今天天气不错!签到!
    2020-1-10 11:05
  • 签到天数: 13 天
     楼主| 发表于 2019-9-5 09:08:05 | 显示全部楼层
    程序跑到喂狗WWDT_Refresh(WWDT)这里就被复位了,还没有跑到 延迟函数这里。然而在裸机中喂狗正常。
    int main(void)
        /* Init board hardware. */
        /* attach main clock divide to FLEXCOMM0 (debug console) */
        BOARD_InitPins();
        LED_RED_INIT(LOGIC_LED_OFF);
        APP_LED_INIT;
                    watchdog_init(5);
    #if 0
            while (1)
        for (;;)
    #else
            while(1)
                            WWDT_Refresh(WWDT);
                            delay();
    #endif
    哈哈哈哈哈哈哈啊哈哈哈
    发表于 2019-9-5 09:24:52 | 显示全部楼层
    可能是RTOS重新schedule的task运行的时候,打断了WWDT_Refresh(WWDT);的执行过程引发,你可以顺着这个思路检查一下
  • 签到天数: 139 天
    发表于 2019-9-5 15:16:55 | 显示全部楼层
    int  ...
    初始化开门狗喂狗的时间:config.timeoutValue = wdtFreq * x;其中这个x是控制时间的,例程中给的默认值先不要改,你说的重启和这个给的时间有关。在调试过程中找出一个合适值就行了
    今天天气不错!签到!
    2020-1-10 11:05
  • 签到天数: 13 天
     楼主| 发表于 2019-9-5 15:36:17 | 显示全部楼层
    l546863256 发表于 2019-9-5 15:16
    初始化开门狗喂狗的时间:config.timeoutValue = wdtFreq * x;其中这个x是控制时间的,例程中给的默认值 ...
    跟超时时间没有关系;应该是喂狗被打断了导致复位。
    哈哈哈哈哈哈哈啊哈哈哈
  • 签到天数: 177 天
    发表于 2019-9-5 15:41:58 | 显示全部楼层
    GMT+8, 2025-10-30 03:12 , Processed in 0.123772 second(s), 28 queries , MemCache On.
