查看: 5705|回复: 1
[求助] IMX6 QT + OpenGL ES2.0 问题
发表于 2019-9-7 16:22:21 | 显示全部楼层 |阅读模式
我是用IMX6  ARM板,
我的使用思路:用的是英蓓特SM-SOM9300,用不是飞思卡尔的板子,所以交叉编译器不是sysroots里面的交叉编译器,交叉编译器版本为gcc-linaro-5.3.1-2016.05-i686_arm-linux-gnueabihf.tar.xz
现在要使用Opengl ES功能,需要下载了yocto 工具,生成sysroots工具,在交叉编译时,使用sysroots里面的库,下面是修改文件和configure
qmake.conf 文件内容
qtbase/mkspecs/linux-arm-gnueabihf-g++/qmake.conf
# qmake configuration for building with arm-linux-gnueabi-g++
M***EFILE_GENERATOR      = UNIX
CONFIG                 += incrementar
QM***E_INCREMENTAL_STYLE = sublib
include(../common/linux.conf)
include(../common/gcc-base-unix.conf)
include(../common/g++-unix.conf)
QM***E_INCDIR_OPENGL_ES2 += /opt/sysroot/imx6qsabresd/usr/include
QM***E_LIBDIR_OPENGL_ES2 += /opt/sysroot/imx6qsabresd/usr/lib
QM***E_LIBS_EGL         += -lEGL
QM***E_LIBS_OPENGL_ES2  += -lGLESv2 -lEGL -lGAL
QM***E_LIBS_OPENVG      += -lOpenVG -lEGL -lGAL
IMX6_CFLAGS           =-march=armv7-a  -mfloat-abi=hard -mfpu=neon -mtune=cortex-a9 -DLINUX=1 -DEGL_API_FB=1
QM***E_CFLAGS           += $$IMX6_CFLAGS
QM***E_CXXFLAGS         += $$IMX6_CFLAGS
DISTRO_OPTS+= hard-float
#Preferred eglfs backend
EGLFS_DEVICE_INTEGRATION= eglfs_viv
QT_QPA_DEFAULT_PLATFORM= eglfs
QM***E_CFLAGS_RELEASE   += -O2 $$QM***E_CFLAGS
QM***E_CXXFLAGS_RELEASE+= -O2 $$QM***E_CXXFLAGS
# modifications to g++.conf
QM***E_CC                = arm-linux-gnueabihf-gcc
QM***E_CXX               = arm-linux-gnueabihf-g++
QM***E_LINK              = arm-linux-gnueabihf-g++
QM***E_LINK_SHLIB        = arm-linux-gnueabihf-g++
# modifications to linux.conf
QM***E_AR                = arm-linux-gnueabihf-ar cqs
QM***E_OBJCOPY           = arm-linux-gnueabihf-objcopy
QM***E_NM                = arm-linux-gnueabihf-nm -P
QM***E_STRIP             = arm-linux-gnueabihf-strip
load(qt_config)
configure命令
./configure -prefix /Qt5.12x_opengl -confirm-license -shared -release -xplatform linux-arm-gnueabihf-g++ -qt-pcre -no-libproxy -no-pch -no-rpath -no-alsa -no-cups -dbus -no-directfb -evdev -no-harfbuzz -no-iconv -icu -no-kms -no-openvg -sysconfdir /Qt5.12x_opengl/sysconf -nomake tests -nomake examples -eglfs  -opengl es2 -egl -device-option CROSS_COMPILE=/usr/local/arm/gcc-5.3.1/bin/arm-linux-gnueabihf-  -sysroot /opt/sysroot/imx6qsabresd -v
每次都是报错 找不到插件eglfs,求解?
我知道答案 目前已有1人回答
发表于 2020-7-21 08:44:48 | 显示全部楼层
帮忙顶一下
GMT+8, 2026-4-12 02:30 , Processed in 0.082016 second(s), 23 queries , Redis On.
