查看: 4298|回复: 1
[求助] imx6ull编译时出现python脚本错误,求大侠帮忙看看
发表于 2019-9-21 10:42:46 | 显示全部楼层 |阅读模式
编译前执行了bitbake -c cleanall fsl-image-validation-imx
下面是编译过程:
alpha@Lenovo:~/pand/nxp/imx-yocto-bsp/build$ bitbake fsl-image-validation-imx
Loading cache: 100% |################################################################################################################################| Time: 0:00:01
Loaded 3262 entries from dependency cache.
Parsing recipes: 100% |##############################################################################################################################| Time: 0:00:04
Parsing of 2423 .bb files complete (2421 cached, 2 parsed). 3264 targets, 218 skipped, 8 masked, 0 errors.
NOTE: Resolving any missing task queue dependencies
Build Configuration:
BB_VERSION           = "1.36.0"
BUILD_SYS            = "x86_64-linux"
NATIVELSBSTRING      = "ubuntu-16.04"
TARGET_SYS           = "arm-poky-linux-gnueabi"
MACHINE              = "imx6ullevk"
DISTRO               = "fsl-imx-x11"
DISTRO_VERSION       = "4.9.88-2.0.0"
TUNE_FEATURES        = "arm armv7ve vfp thumb neon callconvention-hard cortexa7"
TARGET_FPU           = "hard"
meta
meta-poky            = "HEAD:0ec241873367e18f5371a3ad9aca1e2801dcd4ee"
meta-oe
meta-multimedia      = "HEAD:dacfa2b1920e285531bec55cd2f08743390aaf57"
meta-freescale       = "HEAD:49ac225a38f6d84519798e3264f2e4d19b84f70a"
meta-freescale-3rdparty = "HEAD:1d6d5961dbf82624b28bb318b4950a64abc31d12"
meta-freescale-distro = "HEAD:0ec6d7e206705702b5b534611754de0787f92b72"
meta-bsp
meta-sdk             = "HEAD:d65692ecb3a4136fc1cc137152634e8633ddb3c6"
meta-browser         = "HEAD:d6f9aed41c73b75a97d71bff060b03a66ee087b1"
meta-gnome
meta-networking
meta-python
meta-filesystems     = "HEAD:dacfa2b1920e285531bec55cd2f08743390aaf57"
meta-qt5             = "HEAD:32bb7d18a08d1c48873d7ab6332d4cc3815a4dff"
Initialising tasks: 100% |###########################################################################################################################| Time: 0:00:34
NOTE: Executing SetScene Tasks
ERROR: libtool-native-2.4.6-r0 do_populate_sysroot_setscene: Error executing a python function in exec_python_func() autogenerated:
The stack trace of python calls that resulted in this exception/failure was:
File: 'exec_python_func() autogenerated', lineno: 2, function: <module>
     0001:
*** 0002:do_populate_sysroot_setscene(d)
     0003:
File: '/home/alpha/pand/nxp/imx-yocto-bsp/sources/poky/meta/classes/staging.bbclass', lineno: 126, function: do_populate_sysroot_setscene
     0122:do_populate_sysroot[sstate-outputdirs] = "${COMPONENTS_DIR}/${PACKAGE_ARCH}/${PN}"
     0123:do_populate_sysroot[sstate-fixmedir] = "${COMPONENTS_DIR}/${PACKAGE_ARCH}/${PN}"
     0124:
     0125:python do_populate_sysroot_setscene () {
*** 0126:    sstate_setscene(d)
     0127:}
     0128:addtask do_populate_sysroot_setscene
     0129:
     0130:def staging_copyfile(c, target, dest, postinsts, seendirs):
File: '/home/alpha/pand/nxp/imx-yocto-bsp/sources/poky/meta/classes/sstate.bbclass', lineno: 681, function: sstate_setscene
     0677:            break
     0678:
     0679:def sstate_setscene(d):
     0680:    shared_state = sstate_state_fromvars(d)
*** 0681:    accelerate = sstate_installpkg(shared_state, d)
     0682:    if not accelerate:
     0683:        bb.fatal("No suitable staging package found")
     0684:
     0685:python sstate_task_prefunc () {
File: '/home/alpha/pand/nxp/imx-yocto-bsp/sources/poky/meta/classes/sstate.bbclass', lineno: 328, function: sstate_installpkg
     0324:    for f in (d.getVar('SSTATEPREINSTFUNCS') or '').split() + ['sstate_unpack_package']:
     0325:        # All hooks should run in the SSTATE_INSTDIR
     0326:        bb.build.exec_func(f, d, (sstateinst,))
     0327:
*** 0328:    return sstate_installpkgdir(ss, d)
     0329:
     0330:def sstate_installpkgdir(ss, d):
     0331:    import oe.path
     0332:    import subprocess
File: '/home/alpha/pand/nxp/imx-yocto-bsp/sources/poky/meta/classes/sstate.bbclass', lineno: 351, function: sstate_installpkgdir
     0347:
     0348:    for state in ss['dirs']:
     0349:        prepdir(state[1])
     0350:        os.rename(sstateinst + state[0], state[1])
*** 0351:    sstate_install(ss, d)
     0352:
     0353:    for plain in ss['plaindirs']:
     0354:        workdir = d.getVar('WORKDIR')
     0355:        src = sstateinst + "/" + plain.replace(workdir, '')
File: '/home/alpha/pand/nxp/imx-yocto-bsp/sources/poky/meta/classes/sstate.bbclass', lineno: 280, function: sstate_install
     0276:
     0277:    # Run the actual file install
     0278:    for state in ss['dirs']:
     0279:        if os.path.exists(state[1]):
*** 0280:            oe.path.copyhardlinktree(state[1], state[2])
     0281:
     0282:    for postinst in (d.getVar('SSTATEPOSTINSTFUNCS') or '').split():
     0283:        # All hooks should run in the SSTATE_INSTDIR
     0284:        bb.build.exec_func(postinst, d, (sstateinst,))
File: '/home/alpha/pand/nxp/imx-yocto-bsp/sources/poky/meta/lib/oe/path.py', lineno: 113, function: copyhardlinktree
     0109:        else:
     0110:            source = src
     0111:            s_dir = os.getcwd()
     0112:        cmd = 'cp -afl --preserve=xattr %s %s' % (source, os.path.realpath(dst))
*** 0113:        subprocess.check_output(cmd, shell=True, cwd=s_dir, stderr=subprocess.STDOUT)
     0114:    else:
     0115:        copytree(src, dst)
     0116:
     0117:def remove(path, recurse=True):
File: '/usr/lib/python3.5/subprocess.py', lineno: 626, function: check_output
     0622:        # empty string. That is maintained here for backwards compatibility.
     0623:        kwargs['input'] = '' if kwargs.get('universal_newlines', False) else b''
     0624:
     0625:    return run(*popenargs, stdout=PIPE, timeout=timeout, check=True,
*** 0626:               **kwargs).stdout
     0627:
     0628:
     0629:class CompletedProcess(object):
     0630:    """A process that has finished running.
File: '/usr/lib/python3.5/subprocess.py', lineno: 708, function: run
     0704:            raise
     0705:        retcode = process.poll()
     0706:        if check and retcode:
     0707:            raise CalledProcessError(retcode, process.args,
*** 0708:                                     output=stdout, stderr=stderr)
     0709:    return CompletedProcess(process.args, retcode, stdout, stderr)
     0710:
     0711:
     0712:def list2cmdline(seq):
Exception: subprocess.CalledProcessError: Command 'cp -afl --preserve=xattr ./* /home/alpha/pand/nxp/imx-yocto-bsp/build/tmp/sysroots-components/x86_64/libtool-native' returned non-zero exit status 1
Subprocess output:
cp: cannot create hard link '/home/alpha/pand/nxp/imx-yocto-bsp/build/tmp/sysroots-components/x86_64/libtool-native/usr/lib/libltdl.so' to './usr/lib/libltdl.so': Operation not permitted
cp: cannot create hard link '/home/alpha/pand/nxp/imx-yocto-bsp/build/tmp/sysroots-components/x86_64/libtool-native/usr/lib/libltdl.so.7' to './usr/lib/libltdl.so.7': Operation not permitted
WARNING: Logfile for failed setscene task is /home/alpha/pand/nxp/imx-yocto-bsp/build/tmp/work/x86_64-linux/libtool-native/2.4.6-r0/temp/log.do_populate_sysroot_setscene.27873
WARNING: Setscene task (/home/alpha/pand/nxp/imx-yocto-bsp/sources/poky/meta/recipes-devtools/libtool/libtool-native_2.4.6.bb:do_populate_sysroot_setscene) failed with exit code '1' - real task will be run instead
NOTE: Executing RunQueue Tasks
ERROR: libtool-native-2.4.6-r0 do_populate_sysroot: Error executing a python function in exec_python_func() autogenerated:
     0001:
*** 0002:sstate_task_postfunc(d)
     0003:
File: '/home/alpha/pand/nxp/imx-yocto-bsp/sources/poky/meta/classes/sstate.bbclass', lineno: 706, function: sstate_task_postfunc
     0702:
     0703:    sstateinst = d.getVar("SSTATE_INSTDIR")
     0704:    d.setVar('SSTATE_FIXMEDIR', shared_state['fixmedir'])
     0705:
*** 0706:    sstate_installpkgdir(shared_state, d)
     0707:
     0708:    bb.utils.remove(d.getVar("SSTATE_BUILDDIR"), recurse=True)
     0709:}
     0710:sstate_task_postfunc[dirs] = "${WORKDIR}"
     0347:
     0352:
     0276:
     0281:
     0109:        else:
     0110:            source = src
     0114:    else:
     0116:
     0624:
     0627:
     0628:
     0704:            raise
     0710:
     0711:
Subprocess output:
ERROR: libtool-native-2.4.6-r0 do_populate_sysroot: Function failed: sstate_task_postfunc
ERROR: Logfile of failure stored in: /home/alpha/pand/nxp/imx-yocto-bsp/build/tmp/work/x86_64-linux/libtool-native/2.4.6-r0/temp/log.do_populate_sysroot.27885
ERROR: Task (/home/alpha/pand/nxp/imx-yocto-bsp/sources/poky/meta/recipes-devtools/libtool/libtool-native_2.4.6.bb:do_populate_sysroot) failed with exit code '1'
NOTE: Tasks Summary: Attempted 70 tasks of which 65 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There were 3 ERROR messages shown, returning a non-zero exit code.
我知道答案 目前已有1人回答
发表于 2019-10-15 16:03:26 | 显示全部楼层
这个問題应該是host packages 沒安裝好. http://community.nxp.com/docs/DOC-343758
7. Install Yocto Project host packages
$ sudo apt-get install gawk wget git-core diffstat unzip texinfo gcc-multilib build-essential chrpath socat libsdl1.2-dev
$ sudo apt-get install libsdl1.2-dev xterm sed cvs subversion coreutils texi2html docbook-utils python-pysqlite2 help2man make gcc g++ desktop-file-utils libgl1-mesa-dev libglu1-mesa-dev mercurial autoconf automake groff curl lzop asciidoc u-boot-tools
GMT+8, 2026-4-9 03:04 , Processed in 0.081960 second(s), 23 queries , Redis On.
