在线时间212 小时
UID3467032
注册时间2018-4-10
NXP金币48
TA的每日心情 | 开心 2024-3-12 16:11 |
签到天数: 818 天 连续签到: 1 天 [LV.10]以坛为家III
- 2761
- 2025-10-16
发表于 2019-9-24 14:05:49
显示全部楼层
我用的是MC9S12XEP100,应该是同一系列的,供你参考。
可以有三种方法设置中断函数入口
1、在project.prm中,如下表示复位向量入口
VECTOR 0 _Startup /* reset vector: this is the default entry point for a C/C++ application. */
2、直接在写中断入口函数时,指定中断号,需要计算。
#pragma CODE_SEG __NEAR_SEG NON_BANKED
void interrupt 20 SCI0_ISR(void)
3、中断向量表
#pragma CODE_SEG DEFAULT
/*lint -save -e950 Disable MISRA rule (1.1) checking. */
static const tIsrFunc _InterruptVectorTable[] @0xFF10U = { /* Interrupt vector table */
/*lint -restore Enable MISRA rule (1.1) checking. */
/* ISR name No. Address Pri XGATE Name Description*/
&Cpu_Interrupt, /* 0x08 0xFF10 - - ivVsi */
&Cpu_Interrupt, /* 0x09 0xFF12 - - ivVsyscall */
&Cpu_Interrupt, /* 0x0A 0xFF14 - - ivVmpuaccesserr */
&Cpu_Interrupt, /* 0x0B 0xFF16 - no ivVxsei */
&Cpu_Interrupt, /* 0x0C 0xFF18 1 no ivVReserved115 */
&Cpu_Interrupt, /* 0x0D 0xFF1A 1 no ivVReserved114 */
&Cpu_Interrupt, /* 0x0E 0xFF1C 1 no ivVReserved113 */
&Cpu_Interrupt, /* 0x0F 0xFF1E 1 no ivVReserved112 */
&Cpu_Interrupt, /* 0x10 0xFF20 1 no ivVReserved111 */
&Cpu_Interrupt, /* 0x11 0xFF22 1 no ivVReserved110 */
&Cpu_Interrupt, /* 0x12 0xFF24 1 no ivVReserved109 */
&Cpu_Interrupt, /* 0x13 0xFF26 1 no ivVReserved108 */
&Cpu_Interrupt, /* 0x14 0xFF28 1 no ivVReserved107 */
&Cpu_Interrupt, /* 0x15 0xFF2A 1 no ivVReserved106 */
&Cpu_Interrupt, /* 0x16 0xFF2C 1 no ivVReserved105 */
&Cpu_Interrupt, /* 0x17 0xFF2E 1 no ivVReserved104 */
&Cpu_Interrupt, /* 0x18 0xFF30 1 no ivVReserved103 */
&Cpu_Interrupt, /* 0x19 0xFF32 1 no ivVReserved102 */
&Cpu_Interrupt, /* 0x1A 0xFF34 1 no ivVReserved101 */
&Cpu_Interrupt, /* 0x1B 0xFF36 1 no ivVReserved100 */
&Cpu_Interrupt, /* 0x1C 0xFF38 1 no ivVReserved99 */
&Cpu_Interrupt, /* 0x1D 0xFF3A 1 no ivVReserved98 */
&Cpu_Interrupt, /* 0x1E 0xFF3C 1 no ivVatd1compare */
&Cpu_Interrupt, /* 0x1F 0xFF3E 1 no ivVatd0compare */
&Cpu_Interrupt, /* 0x20 0xFF40 1 no ivVtimpaie */
&Cpu_Interrupt, /* 0x21 0xFF42 1 no ivVtimpaaovf */
&Cpu_Interrupt, /* 0x22 0xFF44 1 no ivVtimovf */
&Cpu_Interrupt, /* 0x23 0xFF46 1 no ivVtimch7 */
&Cpu_Interrupt, /* 0x24 0xFF48 1 no ivVtimch6 */
&Cpu_Interrupt, /* 0x25 0xFF4A 1 no ivVtimch5 */
&Cpu_Interrupt, /* 0x26 0xFF4C 1 no ivVtimch4 */
&Cpu_Interrupt, /* 0x27 0xFF4E 1 no ivVtimch3 */
&Cpu_Interrupt, /* 0x28 0xFF50 1 no ivVtimch2 */
&Cpu_Interrupt, /* 0x29 0xFF52 1 no ivVtimch1 */
&Cpu_Interrupt, /* 0x2A 0xFF54 1 no ivVtimch0 */
&SCI7_ISR, /* 0x2B 0xFF56 1 no ivVsci7 */
&Cpu_Interrupt, /* 0x2C 0xFF58 1 no ivVpit7 */
&Cpu_Interrupt, /* 0x2D 0xFF5A 1 no ivVpit6 */
&Cpu_Interrupt, /* 0x2E 0xFF5C 1 no ivVpit5 */
&Cpu_Interrupt, /* 0x2F 0xFF5E 1 no ivVpit4 */
&Cpu_Interrupt, /* 0x30 0xFF60 1 no ivVReserved79 */
&Cpu_Interrupt, /* 0x31 0xFF62 1 no ivVReserved78 */
&Cpu_Interrupt, /* 0x32 0xFF64 1 no ivVxst7 */
&Cpu_Interrupt, /* 0x33 0xFF66 1 no ivVxst6 */
&Cpu_Interrupt, /* 0x34 0xFF68 1 no ivVxst5 */
&Cpu_Interrupt, /* 0x35 0xFF6A 1 no ivVxst4 */
&Cpu_Interrupt, /* 0x36 0xFF6C 1 no ivVxst3 */
&Cpu_Interrupt, /* 0x37 0xFF6E 1 no ivVxst2 */
&Cpu_Interrupt, /* 0x38 0xFF70 1 no ivVxst1 */
&Cpu_Interrupt, /* 0x39 0xFF72 1 no ivVxst0 */
&Cpu_Interrupt, /* 0x3A 0xFF74 1 no ivVpit3 */
&FILE_CH376_ISR, /* 0x3B 0xFF76 1 no ivVpit2 */
&WT588D_ISR, /* 0x3C 0xFF78 1 no ivVpit1 */
&Cpu_Interrupt, /* 0x3D 0xFF7A 1 no ivVpit0 */
&Cpu_Interrupt, /* 0x3E 0xFF7C 1 - ivVhti */
&Cpu_Interrupt, /* 0x3F 0xFF7E 1 no ivVapi */
&Cpu_Interrupt, /* 0x40 0xFF80 1 no ivVlvi */
&Cpu_Interrupt, /* 0x41 0xFF82 1 no ivViic1 */
&SCI5_ISR, /* 0x42 0xFF84 1 no ivVsci5 */
&SCI4_ISR, /* 0x43 0xFF86 1 no ivVsci4 */
&SCI3_ISR, /* 0x44 0xFF88 1 no ivVsci3 */
&SCI2_ISR, /* 0x45 0xFF8A 1 no ivVsci2 */
&Cpu_Interrupt, /* 0x46 0xFF8C 1 no ivVpwmesdn */
&Cpu_Interrupt, /* 0x47 0xFF8E 1 no ivVportp */
&Cpu_Interrupt, /* 0x48 0xFF90 1 no ivVcan4tx */
&CAN4_RxNotificationISR, /* 0x49 0xFF92 1 no ivVcan4rx */
&Cpu_Interrupt, /* 0x4A 0xFF94 1 no ivVcan4err */
&Cpu_Interrupt, /* 0x4B 0xFF96 1 no ivVcan4wkup */
&Cpu_Interrupt, /* 0x4C 0xFF98 1 no ivVcan3tx */
&CAN3_RxNotificationISR, /* 0x4D 0xFF9A 1 no ivVcan3rx */
&Cpu_Interrupt, /* 0x4E 0xFF9C 1 no ivVcan3err */
&Cpu_Interrupt, /* 0x4F 0xFF9E 1 no ivVcan3wkup */
&Cpu_Interrupt, /* 0x50 0xFFA0 1 no ivVcan2tx */
&CAN2_RxNotificationISR, /* 0x51 0xFFA2 1 no ivVcan2rx */
&Cpu_Interrupt, /* 0x52 0xFFA4 1 no ivVcan2err */
&Cpu_Interrupt, /* 0x53 0xFFA6 1 no ivVcan2wkup */
&Cpu_Interrupt, /* 0x54 0xFFA8 1 no ivVcan1tx */
&CAN1_RxNotificationISR, /* 0x55 0xFFAA 1 no ivVcan1rx */
&Cpu_Interrupt, /* 0x56 0xFFAC 1 no ivVcan1err */
&Cpu_Interrupt, /* 0x57 0xFFAE 1 no ivVcan1wkup */
&Cpu_Interrupt, /* 0x58 0xFFB0 1 no ivVcan0tx */
&CAN0_RxNotificationISR, /* 0x59 0xFFB2 1 no ivVcan0rx */
&Cpu_Interrupt, /* 0x5A 0xFFB4 1 no ivVcan0err */
&Cpu_Interrupt, /* 0x5B 0xFFB6 1 no ivVcan0wkup */
&Cpu_Interrupt, /* 0x5C 0xFFB8 1 no ivVflash */
&Cpu_Interrupt, /* 0x5D 0xFFBA 1 no ivVflashfd */
&Cpu_Interrupt, /* 0x5E 0xFFBC 1 no ivVspi2 */
&SPI1_ISR, /* 0x5F 0xFFBE 1 no ivVspi1 */
&Cpu_Interrupt, /* 0x60 0xFFC0 1 no ivViic0 */
&SCI6_ISR, /* 0x61 0xFFC2 1 no ivVsci6 */
&Cpu_Interrupt, /* 0x62 0xFFC4 1 no ivVcrgscm */
&Cpu_Interrupt, /* 0x63 0xFFC6 1 no ivVcrgplllck */
&Cpu_Interrupt, /* 0x64 0xFFC8 1 no ivVectpabovf */
&Cpu_Interrupt, /* 0x65 0xFFCA 1 no ivVectmdcu */
&Cpu_Interrupt, /* 0x66 0xFFCC 1 no ivVporth */
&Cpu_Interrupt, /* 0x67 0xFFCE 1 no ivVportj */
&Cpu_Interrupt, /* 0x68 0xFFD0 1 no ivVatd1 */
&Filtered0, /* 0x69 0xFFD2 1 no ivVatd0 */
&SCI1_ISR, /* 0x6A 0xFFD4 1 no ivVsci1 */
&SCI0_ISR, /* 0x6B 0xFFD6 1 no ivVsci0 */
&Cpu_Interrupt, /* 0x6C 0xFFD8 1 no ivVspi0 */
&Cpu_Interrupt, /* 0x6D 0xFFDA 1 no ivVectpaie */
&Cpu_Interrupt, /* 0x6E 0xFFDC 1 no ivVectpaaovf */
&Cpu_Interrupt, /* 0x6F 0xFFDE 1 no ivVectovf */
&Cpu_Interrupt, /* 0x70 0xFFE0 1 no ivVectch7 */
&Cpu_Interrupt, /* 0x71 0xFFE2 1 no ivVectch6 */
&Cpu_Interrupt, /* 0x72 0xFFE4 1 no ivVectch5 */
&Cpu_Interrupt, /* 0x73 0xFFE6 1 no ivVectch4 */
&Cpu_Interrupt, /* 0x74 0xFFE8 1 no ivVectch3 */
&Cpu_Interrupt, /* 0x75 0xFFEA 1 no ivVectch2 */
&Cpu_Interrupt, /* 0x76 0xFFEC 1 no ivVectch1 */
&Cpu_Interrupt, /* 0x77 0xFFEE 1 no ivVectch0 */
&RTI_ISR, /* 0x78 0xFFF0 1 no ivVrti */
&Cpu_Interrupt, /* 0x79 0xFFF2 1 no ivVirq */
&Cpu_Interrupt, /* 0x7A 0xFFF4 - - ivVxirq */
&Cpu_Interrupt, /* 0x7B 0xFFF6 - - ivVswi */
&Cpu_Interrupt /* 0x7C 0xFFF8 - - ivVtrap */
/* end vector.c */
