查看: 5274|回复: 3
[讨论] mfgtool刷写i.MX6 android6.0版本失败
发表于 2019-9-29 16:07:14 | 显示全部楼层 |阅读模式
Mfgtool烧写镜像失败,停在Jumping to OS image,然后又自动重新烧写(重复上面)。
工具版本:android_m6.0.1_2.1.0_tool.tar.gz
img版本:android_M6.0.1_2.1.0_image_6dqpsabresd.tar.gz
在Windows7(64Bit)烧写失败了。烧录linux成功,烧录Android失败了。用的是i.MX6D开发板,请问根据下面的错误可以知道到底是哪里出了问题?
下面是错误日志:
DLL version: 2.6.2
Wednesday, September 18, 2019 11:48:45   Start new logging
ModuleID[2] LevelID[10]: CMyExceptionHandler thread is running
ModuleID[2] LevelID[1]: new MxHidDeviceClass
ModuleID[2] LevelID[10]: new MxHidDevice[04CCEB88]
ModuleID[2] LevelID[10]: new MxHidDevice[04C5A288]
ModuleID[2] LevelID[10]: new MxHidDevice[04D10FD8]
ModuleID[2] LevelID[10]: new MxHidDevice[04D11398]
ModuleID[2] LevelID[10]: new MxHidDevice[04C5F460]
ModuleID[2] LevelID[10]: new MxHidDevice[04C5FA80]
ModuleID[2] LevelID[10]: Device Manager thread is running
ModuleID[2] LevelID[1]: Can't set m_hStopEvent before it initialized or it already stop
ModuleID[2] LevelID[10]: DeviceManager:evChangeWnd::OnDeviceChange() - DEVICE_REMOVAL_EVT(\\?\USB#VID_15A2&ID_0054#5&319e20c6&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed})
ModuleID[2] LevelID[10]: DeviceManager:evChangeWnd::OnDeviceChange() - end
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - DEVICE_REMOVAL_EVT(\\?\USB#VID_15A2&ID_0054#5&319e20c6&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed})
ModuleID[2] LevelID[10]: DeviceClass::FindDeviceByUsbPath--DeviceListType_Current, _devices.size: 1
ModuleID[2] LevelID[10]: DeviceClass::FindDeviceByUsbPath--DeviceListType_Current, devInstPathToFind: USB\VID_15A2&ID_0054\5&319E20C6&0&1, _deviceInstanceID: USB\VID_15A2&ID_0054\5&319E20C6&0&1
ModuleID[2] LevelID[10]: DeviceClass::FindDeviceByUsbPath--DeviceListType_Current, Find the device
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - DEVICE_REMOVAL_EVT,[MxHidDeviceClass] vid_15a2&pid_0054, Hub:1-Port:1
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - DEVICE_REMOVAL_EVT, Notify
ModuleID[2] LevelID[10]: CmdOpreation[0]--OnDeviceChangeNotify, Volume Arrive/Remove or Device Arrive/Remove
ModuleID[2] LevelID[10]: CmdOpreation[0]--OnDeviceChangeNotify, m_p_usb_port is not NULL, so only refresh
ModuleID[2] LevelID[10]: CmdOpreation[0]--OnDeviceChangeNotify, Volume/Device Remove
ModuleID[2] LevelID[1]: CmdOpreation[0]--set m_hDeviceRemoveEvent.
ModuleID[2] LevelID[10]: CmdOpreation[0]--WaitforEvents device remove1
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent()-DEVICE_REMOVAL_EVT, hDevCanDeleteEvent has been set
ModuleID[2] LevelID[10]: delete MxHidDevice[04C5FA80]
ModuleID[2] LevelID[10]: DeviceManager:evChangeWnd::OnDeviceChange() - DEVICE_ARRIVAL_EVT(\\?\USB#VID_15A2&ID_0054#5&319e20c6&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed})
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - DEVICE_ARRIVAL_EVT(\\?\USB#VID_15A2&ID_0054#5&319e20c6&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed})
ModuleID[2] LevelID[10]: DeviceClass::FindDeviceByUsbPath--DeviceListType_Current, _devices.size: 0
ModuleID[2] LevelID[1]: DeviceClass::FindDeviceByUsbPath() - DeviceListType_New--index: 0
ModuleID[2] LevelID[1]: DeviceClass::FindDeviceByUsbPath() - DeviceListType_New--devPath: \\?\hid#vid_15a2&pid_0054#6&323a0273&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
ModuleID[2] LevelID[10]: new MxHidDevice[04C5FA40]
ModuleID[2] LevelID[10]: DeviceClass::FindDeviceByUsbPath--DeviceListType_New, devInstPathToFind: USB\VID_15A2&ID_0054\5&319E20C6&0&1, _deviceInstanceID: USB\VID_15A2&ID_0054\5&319E20C6&0&1
ModuleID[2] LevelID[10]: DeviceClass::FindDeviceByUsbPath--DeviceListType_New, Find the device, Port: 1
ModuleID[2] LevelID[10]: DeviceClass::AddUsbDevice() successful USB#VID_15A2&ID_0054#5&319E20C6&0&1#{A5DCBF10-6530-11D2-901F-00C04FB951ED} add to current list, retrycount: 0
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - DEVICE_ARRIVAL_EVT,[MxHidDeviceClass] vid_15a2&pid_0054, Hub:1-Port:1
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - DEVICE_ARRIVAL_EVT, Notify
ModuleID[2] LevelID[10]: CmdOpreation[0]--OnDeviceChangeNotify, Volume/Device Arrive
ModuleID[2] LevelID[1]: CmdOpreation[0]--set m_hDeviceArriveEvent.
ModuleID[2] LevelID[10]: CmdOpreation[0]--WaitforEvents device arrive1
ModuleID[2] LevelID[10]: CmdOperation[0] device chagned and reset to state 0
ModuleID[2] LevelID[10]: ExecuteCommand--Boot[WndIndex:0], File is C:\Users\Administrator\Desktop\IMX6\mfgtools\Profiles\linux\OS Firmware\files\android\sabresd\u-boot-imx6q.imx
ModuleID[2] LevelID[10]: CmdOperation[0], skip current command, so SetEvent(hDevCanDeleteEvent)
ModuleID[2] LevelID[10]: ExecuteCommand--Load[WndIndex:0], File is C:\Users\Administrator\Desktop\IMX6\mfgtools\Profiles\linux\OS Firmware\firmware\zImage, address is 0x12000000
ModuleID[2] LevelID[10]: PortMgrDlg(0)--Command Load excute successfully, retry count: 0
ModuleID[2] LevelID[10]: ExecuteCommand--Load[WndIndex:0], File is C:\Users\Administrator\Desktop\IMX6\mfgtools\Profiles\linux\OS Firmware\firmware\fsl-image-mfgtool-initramfs-imx_mfgtools.cpio.gz.u-boot, address is 0x12C00000
ModuleID[2] LevelID[10]: ExecuteCommand--Load[WndIndex:0], File is C:\Users\Administrator\Desktop\IMX6\mfgtools\Profiles\linux\OS Firmware\firmware\zImage-imx6q-sabresd.dtb, address is 0x18000000
ModuleID[2] LevelID[10]: ExecuteCommand--Jump[WndIndex:0]
ModuleID[2] LevelID[10]: *********MxHidDevice[04C5FA40] Jump to Ramkernel successfully!**********
ModuleID[2] LevelID[10]: CmdOperation[0], current state command has been finished and the last command is successful, so SetEvent(hDevCanDeleteEvent)
ModuleID[2] LevelID[1]: MxHidDevice::Read() Error reading from device 0x48f.
ModuleID[2] LevelID[1]: Failed to read HAB type from ROM!!!
ModuleID[2] LevelID[1]: Failed to initialize memory!
ModuleID[2] LevelID[1]: PortMgrDlg(0)--MxHidDevice--Command Boot excute failed
ModuleID[2] LevelID[10]: CmdOperation[0], current command executed failed, so SetEvent(hDevCanDeleteEvent)
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - DEVICE_REMOVAL_EVT(\\?\USB#VID_15A2&PID_0054#5&319e20c6&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed})
ModuleID[2] LevelID[10]: DeviceClass::FindDeviceByUsbPath--DeviceListType_Current, devInstPathToFind: USB\VID_15A2&PID_0054\5&319E20C6&0&1, _deviceInstanceID: USB\VID_15A2&PID_0054\5&319E20C6&0&1
ModuleID[2] LevelID[10]: delete MxHidDevice[04C5FA40]
CPU:原厂标准完整型号: MCIMX6D6AVT10AD
DDR:SAMSUNG  K482G1646F *2
eMMC:SanDisk  SDINBDG4-16G
android版本:android_M6.0.1_2.1.0_source.tar.gz
kernel版本:m6.0.1_2.1.0-ga
u-boot版本:m6.0.1_2.1.0-ga
patch版本:imx_M6.0.1_2.1.0
麻烦帮忙确认一下问题出在哪?谢谢!
发表于 2019-10-15 12:30:48 | 显示全部楼层
你好,以下是给你的建议:
1. 您烧写linux成功,说明DDR初始化正确。OS Firmawre下面的images是没问题的。
2. 根据您的MFG Tools log的提示。可能问题在于MFG Tools没有找到你的android文件。
3. 在MFG TOOLS里有ucl2.xml文件,这里是由各个list组成的,您烧写android的时候,会使用到其中的一个列表。这个列表中的每个命令行,请检查一下对应的路径里,是否是正确的android image名字。如果名字和这个列表里的对不上,那么就会出错。
Have a nice day!
NXP TIC IMX team
Weidong sun
 楼主| 发表于 2019-11-5 11:18:06 | 显示全部楼层
你好,问题已解决,经过确认是内存做了裁剪导致的问题,将内存参数调整为512MB,验证OK。多谢支持!
发表于 2019-11-12 14:57:16 | 显示全部楼层
这个是比较成熟的平台了
GMT+8, 2026-4-9 03:01 , Processed in 0.091918 second(s), 23 queries , Redis On.
