查看: 1793|回复: 2
[求助] 关于SPC5644的CAN通讯问题
  • 签到天数: 7 天
    发表于 2019-10-27 12:02:08 | 显示全部楼层 |阅读模式
    我想了解CAN的发送原理,ID是怎么读进来的,是不是配置的ID和接受的ID 对上才能接收到缓存区,我测试了一下,只有两个ID一样的才能接收到,还有接收到的ID这么多,要怎么识别呀,谁有没有这方面的代码提供一个,谢谢,我想完成接受CAN线的数据识别,然后处理,再发送数据!!
    邮箱81854828@qq.com 谢谢
    我知道答案 目前已有2人回答
    上道
  • 签到天数: 7 天
     楼主| 发表于 2019-10-27 12:04:36 | 显示全部楼层
    现在已经完成CANA到CANC的发送,两个ID必须一样才行,如果接到别的CAN总线上,怎么能接收大量数据?
    我试了一下,一个也接不到
    上道
  • 签到天数: 7 天
     楼主| 发表于 2019-10-27 21:56:35 | 显示全部楼层
    #include "MPC5744P.h"
    #include "INTC_Init.h"
    * Constants and macros
    /* FlexCAN module register's bit masks */
    #define CAN_MCR_MDIS        0x80000000
    #define CAN_MCR_FRZ         0x40000000
    #define CAN_MCR_FEN         0x20000000
    #define CAN_MCR_HALT        0x10000000
    #define CAN_MCR_NOTRDY      0x08000000
    #define CAN_MCR_SOFTRST     0x02000000
    #define CAN_MCR_FRZACK      0x01000000
    #define CAN_MCR_WRNEN       0x00200000
    #define CAN_MCR_LPMACK      0x00100000
    #define CAN_MCR_SRXDIS      0x00020000
    #define CAN_MCR_BCC         0x00010000
    #define CAN_MCR_LPRIOEN     0x00002000
    #define CAN_MCR_AEN         0x00001000
    * External objects
    * Global variables
    //extern const uint32_t IntcIsrVectorTable[];
    //extern void xcptn_xmpl(void);
    uint8_t   u8_txdata = 0; /* tranmitted data */
    uint8_t   u8_rxdata = 0; /* received data */
    * Local functions
    Function Name : Sys_Init
    Engineer      : PetrS
    Date          : Mar-17-2015
    Parameters    : NONE
    Modifies      : NONE
    Returns       : NONE
    Notes         : Enable XOSC, PLL0, PLL1 and enter RUN0 with PLL0 as sys clk (200 MHz)
    Issues        : NONE
    void SysClk_Init(void)
        MC_CGM.AC3_SC.B.SELCTL = 0x01;                    //connect XOSC to the PLL0 input
        MC_CGM.AC4_SC.B.SELCTL = 0x01;                    //connect XOSC to the PLL1 input
        // Set PLL0 to 200 MHz with 40MHz XOSC reference
        PLLDIG.PLL0DV.R = 0x3002100A;             // PREDIV =  1, MFD = 10, RFDPHI = 2, RFDPHI1 = 6
        MC_ME.RUN0_MC.R = 0x00130070;                    // RUN0 cfg: IRCON,OSC0ON,PLL0ON,syclk=IRC
        // Mode Transition to enter RUN0 mode:
        MC_ME.MCTL.R = 0x40005AF0;                    // Enter RUN0 Mode & Key
        MC_ME.MCTL.R = 0x4000A50F;                    // Enter RUN0 Mode & Inverted Key
        while (MC_ME.GS.B.S_MTRANS) {};                    // Wait for mode transition to complete
        while(MC_ME.GS.B.S_CURRENT_MODE != 4) {};            // Verify RUN0 is the current mode
        // Set PLL1 to 160 MHz with 40MHz XOSC reference
        PLLDIG.PLL1DV.R = 0x00020010;             // MFD = 16, RFDPHI = 2
        MC_ME.RUN_PC[0].R = 0x000000FE;                    // enable peripherals run in all modes
        MC_ME.RUN0_MC.R = 0x001300F2;                    // RUN0 cfg: IRCON, OSC0ON, PLL1ON, syclk=PLL0
        MC_CGM.SC_DC0.R = 0x80030000;    // PBRIDGE0/PBRIDGE1_CLK at syst clk div by 4 ... (50 MHz)
        MC_CGM.AC6_SC.R = 0x04000000;    // Select PLL1 for auxiliary clock 6
        MC_CGM.AC6_DC0.R = 0x80090000;    // CLKOUT0 : Enable aux clk 6 div by 10 ?(16 MHz)
    Function Name : SUIL2_Init
    Engineer      : b21190
    Date          : Dec-19-2014
    Parameters    : NONE
    Modifies      : NONE
    Returns       : NONE
    Notes         : SIUL2 initialization (ports), setting PB6(B9) as output for clock measurement
    Issues        : NONE
    void SUIL2_Init(void)
       SIUL2.MSCR[22].R = 0x22800001;           // PB6 as CLK_OUT (on EVB it is B9)
       SIUL2.MSCR[0].R = 0x32000000;         //PA[0] GPIO - LED1
    }//SUIL2_Init
    Function Name : PIT_Init
    Engineer      : PetrS
    Date          : Mar-17-2015
    Parameters    : NONE
    Modifies      : NONE
    Returns       : NONE
    Notes         : PIT timer initialization - 1sec, PIT running from 50Mhz
    Issues        : NONE
    void PIT_Init(void)
        PIT_0.MCR.B.MDIS = 0;               //Enable PIT_0 timers
        PIT_0.TIMER[0].LDVAL.R = 50000000-1;   // setup timer 0 for 1sec period
        PIT_0.TIMER[0].TCTRL.B.TEN = 1;     // start Timer
    }//PIT_Init
    Function Name : PIT_ISR
    Engineer      : b21190
    Date          : Dec-19-2014
    Parameters    : NONE
    Modifies      : NONE
    Returns       : NONE
    Notes         : PIT timer interrupt routine
    Issues        : NONE
    void PIT_ISR(void)
        PIT_0.TIMER[0].TCTRL.B.TEN = 1;     // stop PIT_0 Timer
        SIUL2.GPDO[0].R = ~SIUL2.GPDO[0].R ;   ////PA[0] GPIO - LED
        PIT_0.TIMER[0].TFLG.B.TIF = 1;     // Clear PIT_0 interrupt flag
        PIT_0.TIMER[0].TCTRL.B.TEN = 1;     // sart PIT_0 Timer
    }//PIT_ISR
    Function Name : FlexCAN0_Init
    Engineer      : PetrS
    Date          : Mar-17-2015
    Parameters    : NONE
    Modifies      : NONE
    Returns       : NONE
    Notes         : FlexCAN0 initialization
    Issues        : NONE
    void FlexCAN0_Init(void)
        uint32_t i = 0;
        /* enable the FlexCAN module, reset and freeze */
        CAN_0.MCR.R = (0
                        | CAN_MCR_FRZ  /* enabled to enter Freeze mode */
                        | CAN_MCR_HALT /* enter freeze mode if FRZ bit is set */
                        //| CAN_MCR_SOFTRST /* soft reset */
                        | CAN_MCR_SRXDIS  /* self reception enabled */
                        | CAN_MCR_BCC  /* individual Rx masking and queue */
                        | 0x0000003F);
        /* wait until soft reset completes */
        while(1 == CAN_0.MCR.B.SOFTRST) {};
        /* double check that we are actually in freeze mode */
        while(0 == CAN_0.MCR.B.FRZACK) {};
        while(0 == CAN_0.MCR.B.NOTRDY) {};
        CAN_0.MCR.R = (0
                        /*| CAN_MCR_SRXDIS */ /* self reception enabled */
                        | CAN_MCR_AEN  /* Safe Tx abort enable */
                        | 0x0000003F); /* enable 64 MBs */
        /* Configure for OSC (40 MHz), 1.0 MHz bit time */
       // CAN_0.CTRL.R = 0x01ED0006;
        /* Configure for OSC (40 MHz), 0.5 MHz bit time */
        //CAN_0.CTRL.R = 0x04ED0002;
        CAN_0.CTRL1.R = 0x04E40004;        /* CAN bus: 40 MHz clksrc, 500K bps with 16 tq */
                                  /* PRESDIV+1 = Fclksrc/Ftq = 40 MHz/8MHz = 5 */
                                  /*    so PRESDIV = 4 */
                                  /* PSEG2 = Phase_Seg2 - 1 = 5 - 1 = 4 */
                                  /* PSEG1 = PSEG2 = 4 */
                                  /* PROPSEG= Prop_Seg - 1 = 5 - 1 = 4 */
                                  /* RJW = Resync Jump Width - 1 = 4 - 1 = 1 */
                                  /* SMP = 0: use 1 bit per CAN sample */
                                  /* CLKSRC=0 (unchanged): Fcanclk= Fxtal= 40 MHz*/
        /* Make first 32 message buffers inactive by writing their control fields
         * to "not active". They will be left
         * inactive until we're ready for communication. */
        for(i=0;i<64;i++)
            CAN_0.MB[i].CS.R = 0;
        /* set mask registers - all ID bits must match */
        for(i=0;i<64;i++)
            CAN_0.RXIMR[i].R = 0x1FFFFFFF;
        /* configure CAN0TX and CAN0RX pin functions */
        SIUL2.MSCR[16].B.SSS = 1;    /* Pad PB0: Source signal is CAN0_TX  */
        SIUL2.MSCR[16].B.OBE = 1;    /* Pad PB0: Output Buffer Enable */
        SIUL2.MSCR[16].B.SRC = 3;    /* Pad PB0: Maximum slew rate */
        SIUL2.MSCR[17].B.IBE = 1;    /* Pad PB1: Enable pad for input - CAN0_RX */
        SIUL2.IMCR[32].B.SSS = 2;   /* CAN0_RX: connected to pad PB1 */
        /* Finally clear the HALT flag in MCR to enable the FlexCAN
         * to synchronize with the CAN bus and allow
         * participation in communication. */
        CAN_0.MCR.B.HALT = 0;
        /* wait until FlexCAN ready */
        while(1 == CAN_0.MCR.B.FRZACK) {}
        while(1 == CAN_0.MCR.B.NOTRDY) {}
    Function Name : FlexCAN1_Init
    Engineer      : PetrS
    Date          : Mar-17-2015
    Parameters    : NONE
    Modifies      : NONE
    Returns       : NONE
    Notes         : FlexCAN1 initialization
    Issues        : NONE
    void FlexCAN1_Init(void)
        uint32_t i = 0;
        CAN_1.MCR.R = (0
                        | 0x0000003F);
        while(1 == CAN_1.MCR.B.SOFTRST) {};
        while(0 == CAN_1.MCR.B.FRZACK) {};
        while(0 == CAN_1.MCR.B.NOTRDY) {};
        CAN_1.MCR.R = (0
        CAN_1.CTRL1.R = 0x04E40004;        /* CAN bus: 40 MHz clksrc, 500K bps with 16 tq */
        for(i=0;i<64;i++)
            CAN_1.MB[i].CS.R = 0;
        for(i=0;i<64;i++)
            CAN_1.RXIMR[i].R = 0x1FFFFFFF;
        /* configure CAN1TX and CAN1RX pin functions */
        SIUL2.MSCR[14].B.SSS = 1;    /* Pad PA14: Source signal is CAN0_TX  */
        SIUL2.MSCR[14].B.OBE = 1;    /* Pad PA14: Output Buffer Enable */
        SIUL2.MSCR[14].B.SRC = 3;    /* Pad PA14: Maximum slew rate */
        SIUL2.MSCR[15].B.IBE = 1;    /* Pad PA15: Enable pad for input - CAN0_RX */
        SIUL2.IMCR[33].B.SSS = 1;   /* CAN1_RX: connected to pad PA15 */
        CAN_1.MCR.B.HALT = 0;
        while(1 == CAN_1.MCR.B.FRZACK) {}
        while(1 == CAN_1.MCR.B.NOTRDY) {}
    Function Name : TransmitMsg
    Engineer      : PetrS
    Date          : Mar-17-2015
    Parameters    : NONE
    Modifies      : NONE
    Returns       : NONE
    Notes         : FlexCAN0 simple transmit. per AN2865
    Issues        : NONE
    static void TransmitMsg(void)
      /* Assumption:  Message buffer CODE is INACTIVE */
      /* prepare data to send */
      u8_txdata ^= 0x01; /* toggle bit 0 */
      /* CAN_A MB8 Tx Send Once, data length to send = 1 byte */
      CAN_0.MB[8].CS.R = 0x08600000; /* Tx INACTIVE + IDE + SRR */
      CAN_0.MB[8].ID.R = 0x12340000; /* Ext.ID = 0x12340000 */
      CAN_0.MB[8].DATA.B[0] = u8_txdata; /* data to send */
      CAN_0.MB[8].CS.R = 0x0C610000; /* send 1 byte, ext.frame */
      while ( (CAN_0.IFLAG1.B.BUF31TO8I & 1) == 0) { } // wait until the tx is completed.
      CAN_0.IFLAG1.R = 0x00000100;
    Function Name : ReceiveMsg
    Engineer      : PetrS
    Date          : Mar-17-2015
    Parameters    : NONE
    Modifies      : NONE
    Returns       : NONE
    Notes         : FlexCAN1 simple receive. per AN2865
    Issues        : NONE
    static void ReceiveMsg(void)
      uint32_t temp = 0;      /* temporary and volatile 32bit */
            /* upon receiving the interrupt flag */
        /* mandatory - read control/status word - lock the MB */
            temp = CAN_1.MB[9].CS.R;
            /* check the ID field */
            /* not really needed in this example */
            /* useful in case when multiple IDs are received
             * by one message buffer (Rx mask feature) */
            temp = CAN_1.MB[9].ID.R;
            if(0x12340000 != temp)
                /* error ! trap here.
                 * we have configured this MB to receive
                 * just ID 0x12340000 and not another */
                while(1) {}
            /* read the received data */
            u8_rxdata = CAN_1.MB[9].DATA.B[0];
            /* release the internal lock for all Rx MBs
             * by reading the TIMER */
            temp = CAN_1.TIMER.R;
            /* do someting with the received data */
        /* drive the output pin with the received data */
        SIUL2.GPDO[0].R = u8_rxdata;
    * Global functions
    void main (void)
        SysClk_Init();
        //INTC_Init();
        SUIL2_Init();
        PIT_Init();
        FlexCAN0_Init();
        FlexCAN1_Init();
        /* subscribe FlexCAN_B's MB9 for Rx - extended frame format */
        //CAN_1.MB[9].CS.R = 0x00200000; /* Rx inactive + IDE */
        CAN_1.MB[9].ID.R = 0x12340000; /* Ext.ID = 0x12340000 */
        CAN_1.MB[9].CS.R = 0x04200000; /* Rx active and empty + IDE */
        while(1)
            if(PIT_0.TIMER[0].TFLG.B.TIF)
                TransmitMsg();        /* Transmit one message from a FlexCAN 0 buffer */
                /* if nothing connected to the bus, message is transmitting repeatedly
                   (not acknownledged) and a MCU is going to the error passive mode */
            if(CAN_1.IFLAG1.B.BUF31TO8I & 0x2)         // test BUF9I flag if set
                ReceiveMsg();
                /* clear the BUF09I bit - bit 9 */
                CAN_1.IFLAG1.R = 0x00000200;
    }//main
    上道
    GMT+8, 2025-10-24 11:30 , Processed in 0.080518 second(s), 24 queries , MemCache On.
