12
返回列表 发新帖
楼主: systick
[交流讨论] LPCXpresso55S69/LPC55S69-EVK下载的注意事项
 楼主| 发表于 2019-10-31 16:23:30 | 显示全部楼层
00-405686 发表于 2019-10-31 16:05
好的,谢谢,另外请教一下,那我们如何确定手里的板卡芯片是否存在此问题呢?我的板卡已经全片擦除过,但 ...
是的,从你的现象来看,从官网下载最新的MCUXpresso IDE应该就可以了。
发表于 2019-10-31 16:46:48 | 显示全部楼层
完了,我的板子曾经全擦除过了,现在ISP也下载不了啊
 楼主| 发表于 2019-10-31 16:56:10 | 显示全部楼层
之前是通过IDE全片擦除的吗?
  • 签到天数: 861 天
    发表于 2019-10-31 20:50:15 | 显示全部楼层
    谢谢回复,我再次按照指导中的步骤实验了一次(我理解的还是ISP模式,这个模式用flashmagic 可以下载),错误还是存在
    MCUXpresso IDE11是最新版本的
    附上错误截图
    以及控制台显示的错误信息
    1. MCUXpresso IDE RedlinkMulti Driver v11.0 (Aug 27 2019 16:51:03 - crt_emu_cm_redlink build 22)
    2. Found chip XML file in /home/leo/Documents/MCUXpresso_11.0.1_2563/workspace/lpcxpresso55s69_hello_world/Debug/LPC55S69.xml
    3. (  5) Remote configuration complete
    4. Reconnected to existing LinkServer process.
    5. Using memory from core 0 after searching for a good core
    6. processor is in secure mode
    7. debug interface type      = Cortex-M33 (DAP DP ID 6BA02477) over SWD TAP 0
    8. processor type            = Cortex-M33 (CPU ID 00000D21) on DAP AP 0
    9. number of h/w breakpoints = 8
    10. number of flash patches   = 0
    11. number of h/w watchpoints = 4
    12. Probe(0): Connected&Reset. DpID: 6BA02477. CpuID: 00000D21. Info: <None>
    13. Debug protocol: SWD. RTCK: Disabled. Vector catch: Disabled.
    14. Content of CoreSight Debug ROM(s):
    15. RBASE E00FE000: CID B105100D PID 0000095000 ROM (type 0x1)
    16. ROM 1 E00FF000: CID B105100D PID 04000BB4C9 ROM (type 0x1)
    17. ROM 2 E000E000: CID B105900D PID 04000BBD21 CSt ARM ARMv8-M type 0x0 Misc - Undefined
    18. ROM 2 E0001000: CID B105900D PID 04000BBD21 CSt ARM DWTv2 type 0x0 Misc - Undefined
    19. ROM 2 E0002000: CID B105900D PID 04000BBD21 CSt ARM FPBv2 type 0x0 Misc - Undefined
    20. ROM 2 E0000000: CID B105900D PID 04000BBD21 CSt ARM ITMv2 type 0x43 Trace Source - Bus
    21. ROM 1 E0040000: CID B105900D PID 04000BBD21 CSt type 0x11 Trace Sink - TPIU
    22. NXP: LPC55S69
    23. DAP stride is 1024 bytes (256 words)
    24. Inspected v.2 On chip Flash memory using IAP lib LPC55xx.cfx
    25. Image 'LPC55xx Aug 27 2019 15:35:49'
    26. Opening flash driver LPC55xx.cfx
    27. Retask watch 0 <NONE> address 0x0 (unused) for boot rom stall
    28. Sending SYSRESETREQ to run flash driver
    29. processor is in non-secure mode
    30. state - running or following reset request - re-read of state failed - rc Nn(05). Wire ACK Fault in DAP access
    31. state - running or following reset request - re-read of state failed - rc Nn(05). Wire ACK Fault in DAP access
    32. Warning - processor did not halt - gave up waiting
    33. target failed to halt after flash driver reset - (null)
    34. Driver memory check after reset - mem not working after mailbox read - Em(12). Target rejected debug access at location 0x30006810
    35. flash start - disabling IRQs failed - rc Ep(08). Cannot access core regs when target running.
    36. chip initialization failed - Ep(08). Cannot access core regs when target running.
    37. failed to initialize flash driver LPC55xx.cfx
    38. error closing down debug session - Nn(05). Wire ACK Fault in DAP access
    另外在附上dap模式下的错误,我把不同的部分贴出来了,供参考
    22. NXP: LPC55S69
    29. Restore internally retasked watch #1 no type address 0x0 (unused)
    30. AFTER driver startup timeout (302 5ms retries)
    31. Driver Addresses
    32. Start:  14000000
    33. Entry:  14000035
    34. End:    140003B8
    35. Stack:  30000800
    36. Mailbox:30006800
    37. Driver Register State
    38. R0:     30006800
    39. R1:     00000000
    40. R2:     50000280
    41. R3:     00000000
    42. R4:     30006800
    43. R5:     00000000
    44. R6:     00000000
    45. R7:     00000000
    46. R8:     00000000
    47. R9:     00000000
    48. R10:    00000000
    49. R11:    00000000
    50. R12:    00000000
    51. SP:     30004000
    52. LR:     FFFFFFF9 (exception from main thread)
    53. PC:     00000228
    54. xPSR:   49000003
    55. MSP:    30004000
    56. PSP:    30000800
    57. CFBP:   00000001 (CONTROL=0x0, FAULTMASK=0x0, BASEPRI=0x0, PRIMASK=0x1)
    58. Stacked Exception information at MSP
    59. 3000401C:  xPSR:   05D430CB
    60. 30004018:  VECTPC: 2467D649
    61. 30004014:  LR:     4BA7A19C
    62. 30004010:  R12:    29175066
    63. 3000400C:  R3:     39302112
    64. 30004008:  R2:     A3505FE4
    65. 30004004:  R1:     0***8C7EB
    66. 30004000:  R0:     1709A02B
    67. Exception registers
    68. E000ED04:  ICSR:   00000803 (VECTPEND=0(none), RETTOBASE, VECTACTIVE=3(hard fault))
    69. E000ED08:  VTOR:   00000000 TBLBASE=0(INCODE), TBLOFF=0x0
    70. E000ED28:  MMFSR:  00
    71. E000ED29:  BFSR:   00
    72. E000ED2A:  UFSR:   0010 ()
    73. E000ED2C:  HFSR:   40000000 (FORCED)
    74. E000ED30:  DFSR:   00000001 (HALTED)
    75. E000ED3C:  AFSR:   00000000
    76. E000ED24:  SHCSR:  00000004 (HARDFAULTACT)
    77. E000ED34:  MMAR:   14000160
    78. E000ED38:  BFAR:   14000160
    79. E000EDFC:  DEMCR:  01100000 (TRCENA)
    80. Flash Driver V.2 startup failed - rc Ef(34): Timed-out initializing flash.
    81. chip initialization failed - Ef(34): Timed-out initializing flash.
    82. failed to initialize flash driver LPC55xx.cfx
    点评
    您好,能不能分享一下您的FlashMagic软件呢,wang18982654780@163.com  发表于 2020-1-5 17:29
     楼主| 发表于 2019-10-31 21:12:49 | 显示全部楼层
    leo121_3006061 发表于 2019-10-31 20:50
    谢谢回复,我再次按照指导中的步骤实验了一次(我理解的还是ISP模式,这个模式用flashmagic 可以下载),错 ...
    SDK版本也要是最新的2.6.3
  • 签到天数: 861 天
    发表于 2019-10-31 23:44:01 | 显示全部楼层
    systick 发表于 2019-10-31 21:12
    SDK版本也要是最新的2.6.3
    SDK更新到2.6.3,所有问题都消失,一切功能都正常了,谢谢!
     楼主| 发表于 2019-11-1 10:09:59 | 显示全部楼层
    是的,使用最新的SDK和IDE就可以解决绝大部分问题。
    GMT+8, 2026-4-4 03:33 , Processed in 0.103892 second(s), 28 queries , Redis On.
