在线时间26 小时
UID3553759
注册时间2019-4-13
NXP金币0
 该用户从未签到 注册会员
	积分161
最后登录2021-4-20 |
| 大家好 imax6q的板子,5.9.5的qt creator,kernel 4.1.15
 我用opencv采集v4l2的摄像头,然后用qt的label显示出来。目前可以显示,但是感觉图像有追帧。
 下面附上部分代码
 MainWindow::MainWindow(QWidget *parent) :
 QMainWindow(parent),
 ui(new Ui::MainWindow)
 ui->setupUi(this);
 cout << "####### step 1 ###########" <<endl;
 thread1 = new myThread;
 videoMode = 0;
 connect(&theTimer, &QTimer::timeout, this, &MainWindow::updateImage);   //QBasicTimer
 connect(ui->buttonCapture, SIGNAL(clicked()), this, SLOT(captureImage()));
 connect(ui->buttonSave, SIGNAL(clicked()), this, SLOT(saveImage()));
 connect(ui->buttonQuit, SIGNAL(clicked()), qApp, SLOT(quit()));
 connect(this, SIGNAL(openMenuMsg()), this, SLOT(openMenuEvent()));
 connect(this, SIGNAL(hideMenuMsg(int)), this, SLOT(hideMenuEvent(int)));
 connect(this, SIGNAL(upItemMsg(int)), this, SLOT(upItemEvent(int)));
 connect(this, SIGNAL(downItemMsg(int)), this, SLOT(downItemEvent(int)));
 connect(this, SIGNAL(openSecMenuMsg()), this, SLOT(openSecMenuEvent()));
 connect(this, SIGNAL(videoModeSwitMsg(int)), this, SLOT(videoModeSwitEvent(int)));
 connect(this, SIGNAL(openTrdMenuMsg()), this, SLOT(openTrdMenuEvent()));
 if(videoMode == 0)
 cam.open("imxv4l2src device=/dev/video2 ! videoconvert ! appsink");// ! videoconvert ! appsink
 //         cam.open("/dev/video2");
 else if(videoMode == 1)
 cam.open("imxv4l2src device=/dev/video1 ! videoconvert ! appsink");
 if (!cam.isOpened())        // check if we succeeded
 cout << "####### step cannot open camera ###########" <<endl;
 exit(0);
 cout << "w is " << cam.get(CV_CAP_PROP_FRAME_WIDTH) << "h is "<< cam.get(CV_CAP_PROP_FRAME_HEIGHT) << endl;
 double rate = cam.get(CV_CAP_PROP_FPS);
 cout<<"帧率为:"<<rate<<endl;
 cout<<"thread end"<<endl;
 input_image = Mat::zeros(cam.get(CV_CAP_PROP_FRAME_HEIGHT), cam.get(CV_CAP_PROP_FRAME_WIDTH), CV_8UC3);
 theTimer.start(20);//20   3
 cout << "####### step 2 ###########" <<endl;
 imageLabel = new QLabel(this);
 ui->ImageView->addWidget(imageLabel);
 ui->ImageCapture->setScaledContents(true);
 ui->listWidget->hide();
 ui->listWidget_2->hide();
 ui->listWidget_3->hide();
 ui->listWidget_IR->hide();
 感谢各位
追帧   |
