查看: 3006|回复: 2
[求助] lpc54606烧不进去程序
发表于 2019-11-10 00:00:16 | 显示全部楼层 |阅读模式
总是提示烧不进去程序
Build started: Project: LPC546XX
*** Using Compiler 'V5.06 update 6 (build 750)', folder: 'F:\MDK5_27\ARM\ARMCC\Bin'
Build target 'SeekFree_LPC546XX'
".\Objects\LPC546XX.axf" - 0 Error(s), 0 Warning(s).
Build Time Elapsed:  00:00:00
Load "F:\\恩智浦\\龙邱LPC54606核心板及母板配套资料\\LPC54606核心板\\LPC54606核心板\\LPC54606(BETAV1.11)\\Projecct\\MDK\\Objects\\LPC546XX.axf"
Set JLink Project File to "F:\恩智浦\龙邱LPC54606核心板及母板配套资料\LPC54606核心板\LPC54606核心板\LPC54606(BETAV1.11)\Projecct\MDK\JLinkSettings.ini"
* JLink Info: Device "LPC54606J512" selected.
JLink info:
DLL: V6.44a, compiled Mar  8 2019 17:31:48
Firmware: J-Link ARM V8 compiled Nov 28 2014 13:44:46
Hardware: V8.00
S/N : 17935099
Feature(s) : RDI,FlashDL,FlashBP,JFlash
* JLink Info: Found SW-DP with ID 0x2BA01477
* JLink Info: Scanning AP map to find all available APs
* JLink Info: AP[1]: Stopped AP scan as end of AP map has been reached
* JLink Info: AP[0]: AHB-AP (IDR: 0x24770011)
* JLink Info: Iterating through AP map to find AHB-AP to use
* JLink Info: AP[0]: Core found
* JLink Info: AP[0]: AHB-AP ROM base: 0xE00FF000
* JLink Info: CPUID register: 0x410FC241. Implementer code: 0x41 (ARM)
* JLink Info: Found Cortex-*** r0p1, Little endian.
* JLink Info: FPUnit: 6 code (BP) slots and 2 literal slots
* JLink Info: CoreSight components:
* JLink Info: ROMTbl[0] @ E00FF000
* JLink Info: ROMTbl[0][0]: E000E000, CID: B105E00D, PID: 000BB00C SCS-M7
* JLink Info: ROMTbl[0][1]: E0001000, CID: B105E00D, PID: 003BB002 DWT
* JLink Info: ROMTbl[0][2]: E0002000, CID: B105E00D, PID: 002BB003 FPB
* JLink Info: ROMTbl[0][3]: E0000000, CID: B105E00D, PID: 003BB001 ITM
* JLink Info: ROMTbl[0][4]: E0040000, CID: B105900D, PID: 000BB9A1 TPIU
* JLink Info: ROMTbl[0][5]: E0041000, CID: B105900D, PID: 000BB925 ETM
ROMTableAddr = 0xE00FF000
* JLink Info: Reset: Halt core after reset via DEMCR.VC_CORERESET.
* JLink Info: Reset: Reset device via AIRCR.SYSRESETREQ.
Target info:
Device: LPC54606J512BD208:***
VTarget = 3.313V
State of Pins:
TCK: 0, TDI: 0, TDO: 0, TMS: 1, TRES: 1, TRST: 1
Hardware-Breakpoints: 6
Software-Breakpoints: 8192
Watchpoints:          4
JTAG speed: 4000 kHz
No Algorithm found for: 00000000H - 000010AFH
Erase skipped!
Error: Flash Download failed  -  "Cortex-***"
Flash Load finished at 23:39:00
JLink info:
Hardware: V8.00
S/N : 17935099
Target info:
VTarget = 3.313V
State of Pins:
Watchpoints:          4
Erase skipped!
Flash Load finished at 23:44:10
JLink info:
Hardware: V8.00
S/N : 17935099
Target info:
VTarget = 3.313V
State of Pins:
Watchpoints:          4
JTAG speed: 500 kHz
Erase skipped!
Flash Load finished at 23:45:54
JLink info:
Hardware: V8.00
S/N : 17935099
Target info:
VTarget = 3.313V
State of Pins:
Watchpoints:          4
JTAG speed: 500 kHz
Erase skipped!
Flash Load finished at 23:49:11
file:///C:/Users/13392/AppData/Roaming/Tencent/Users/1339275029/QQ/WinTemp/RichOle/0F%7BT_XC_YX3TG%60LT%7B$17I_A.png
我知道答案 目前已有2人回答
 楼主| 发表于 2019-11-10 00:31:20 | 显示全部楼层
问题解决了,芯片包选择不对
发表于 2019-11-11 09:18:19 | 显示全部楼层
好的
GMT+8, 2026-4-15 17:22 , Processed in 0.074767 second(s), 23 queries , Redis On.
