查看: 1922|回复: 6
[求助] ima6q下载程序失败
发表于 2019-11-23 17:57:10 | 显示全部楼层 |阅读模式
mcu:imx6q
下载工具mfgtools 2.08现象:
连接开发板,上电,打开软件,点击start。烧录软件加载uboot、kernel、fs。jumpuing to os image后,串口开始打印信息,很短一段时间后停止打印,设备自动重启,烧录软件显示no device。
买的二手板子,原有一份QT程序能正常运行。
下面是打印的log:
q pll1: 792MHz
mx6q pll2: 528MHz
mx6q pll3: 480MHz
mx6q pll8: 50MHz
ipg clock     : 66000000Hz
ipg per clock : 66000000Hz
uart clock    : 80000000Hz
cspi clock    : 60000000Hz
ahb clock     : 132000000Hz
axi clock   : 264000000Hz
emi_slow clock: 132000000Hz
ddr clock     : 528000000Hz
usdhc1 clock  : 198000000Hz
usdhc2 clock  : 198000000Hz
usdhc3 clock  : 198000000Hz
usdhc4 clock  : 198000000Hz
nfc clock     : 24000000Hz
Board: i.MX6Q-SABRESD: unknown-board Board: 0x63015 [POR ]
Boot Device: SD
I2C:   ready
DRAM:   2 GB
Initializing cgroup subsys cpu
Linux version 3.0.35-g7c686b7-dirty (root@ubuntu) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #23 SMP PREEMPT Mon Apr 2 20:16:23 PDT 2018
CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: Freescale i.MX 6Quad  TOPEET Board
Memory policy: ECC disabled, Data cache writealloc
CPU identified as i.MX6Q, unknown revision
PERCPU: Embedded 7 pages/cpu @c2065000 s6528 r8192 d13952 u32768
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 475136
Kernel command line: console=ttymxc0,115200 rdinit=/linuxrc enable_wait_mode=off
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 1616MB 256MB = 1872MB total
Memory: 1886752k/1886752k available, 210400k reserved, 1228800K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    DMA     : 0xfbe00000 - 0xffe00000   (  64 MB)
    vmalloc : 0xea800000 - 0xf2000000   ( 120 MB)
    lowmem  : 0xc0000000 - 0xea000000   ( 672 MB)
    pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    modules : 0xbf000000 - 0xbfe00000   (  14 MB)
      .init : 0xc0008000 - 0xc0043000   ( 236 kB)
      .text : 0xc0043000 - 0xc0740cd4   (7160 kB)
      .data : 0xc0742000 - 0xc07b2e38   ( 452 kB)
       .bss : 0xc07b2e5c - 0xc082deec   ( 493 kB)
Preemptible hierarchical RCU implementation.
NR_IRQS:624
MXC GPIO hardware
sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 1431655ms
arm_max_freq=1GHz
MXC_Early serial console at MMIO 0x2020000 (options '115200')
bootconsole [ttymxc0] enabled
Console: colour dummy device 80x30
Calibrating delay loop... K watchpoint single-step.
hw-breakpoint: maximum watchpoint size is 4 bytes.
L310 cache controller enabled
l2x0: 16 ways, CACHE_ID 0x410000c7, AUX_CTRL 0x32070000, Cache size: 1048576 B
bio: create slab <bio-0> at 0
mxs-dma mxs-dma-apbh: initialized
print_constraints: SPKVDD: 4200 mV
print_constraints: vmmc: 3300 mV
vgaarb: loaded
SCSI subsystem initialized
spi_imx imx6q-ecspi.0: probed
spi_imx imx6q-ecspi.1: probed
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
Freescale USB OTG Driver loaded, $Revision: 1.55 $
imx-ipuv3 imx-ipuv3.0: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
imx-ipuv3 imx-ipuv3.1: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
mxc_mipi_csi2 mxc_mipi_csi2: i.MX MIPI CSI2 driver probed
mxc_mipi_csi2 mxc_mipi_csi2: i.MX MIPI CSI2 dphy version is 0x3130302a
MIPI CSI2 driver module loaded
Advanced Linux Sound Architecture Driver Version 1.0.24.
i2c-core: driver [max17135] using legacy suspend method
i2c-core: driver [max17135] using legacy resume method
Switching to clocksource mxc_timer1
NET: Registered protocol family 2
IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
TCP: Hash tables configured (established 131072 bind 65536)
TCP reno registered
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
NET: Registered protocol family 1
Unpacking initramfs...
link up failed, DB_R0:0x00992900, DB_R1:0x08200000!
IMX PCIe port: link down with power supply 1!
IMX usb wakeup probe
add wake up source irq 75
cpu regulator mode:ldo_enable
i.MXC CPU frequency driver
audit: initializing netlink socket (disabled)
type=2000 audit(2.110:1): initialized
imx-sdma imx-sdma: initialized
imx-uart.1: ttymxc1 at MMIO 0x21e8000 (irq = 59) is a IMX
imx-uart.2: ttymxc2 at MMIO 0x21ec000 (irq = 60) is a IMX
buzzer_ctl      initialized
leds_ctl        initialized
max485_ctl Initialize
relay_ctl       initialized
loop: module loaded
GPS: mt3326_gps_power: Switching GPS device on
GPS: mt3326_gps_power: ignore power control: 1
GPS: mt3326_gps_probe: Registering chardev
GPS: mt3326_gps_probe: major: 251, minor: 0
GPS: mt3326_gps_probe: Done
m25p80 spi0.0: found w25q32, expected sst25vf016b
m25p80 spi0.0: w25q32 (4096 Kbytes)
Creating 2 MTD partitions on "m25p80":
0x000000000000-0x000000100000 : "bootloader"
0x000000100000-0x000000400000 : "kernel"
GPMI NAND driver registered. (IMX)
FEC Ethernet Driver
fec_enet_mii_bus: probed
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
fsl-ehci fsl-ehci.0: Freescale On-Chip EHCI Host Controller
fsl-ehci fsl-ehci.0: new USB bus registered, assigned bus number 1
fsl-ehci fsl-ehci.0: irq 75, io base 0x02184000
fsl-ehci fsl-ehci.0: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
add wake up source irq 72
fsl-ehci fsl-ehci.1: Freescale On-Chip EHCI Host Controller
fsl-ehci fsl-ehci.1: new USB bus registered, assigned bus number 2
fsl-ehci fsl-ehci.1: irq 72, io base 0x02184200
fsl-ehci fsl-ehci.1: USB 2.0 started, EHCI 1.00
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
usbcore: registered new interface driver cdc_acm
cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
usbcore: registered new interface driver usbserial
usbserial: USB Serial Driver core
USB Serial support registered for GSM modem (1-port)
usbcore: registered new interface driver option
option: v0.7.2:USB Driver for GSM modems
ARC USBOTG Device Controller driver (1 August 2005)
g_file_storage gadget: controller 'fsl-usb2-udc' not recognized
check_parameters:UTP settings are in place now, overriding defaults
g_file_storage gadget: No serial-number string provided!
g_file_storage gadget: File-backed Storage Gadget, version: 1 September 2010
g_file_storage gadget: Number of LUNs=1
Suspend udc for OTG auto detect
fsl-usb2-udc: bind to driver g_file_storage
using rtc device, snvs_rtc, for alarms
snvs_rtc snvs_rtc.0: rtc core: registered snvs_rtc as rtc0
i2c /dev entries driver
mag3110 2-000e: check mag3110 chip ID
input: FreescaleMagnetometer as /devices/virtual/input/input0
input: eCompass as /devices/virtual/input/input1
mag3110 2-000e: mag3110 is probed
i2c-core: driver [mag3110] using legacy suspend method
i2c-core: driver [mag3110] using legacy resume method
Thermal calibration data is 0x57b4ec69
Thermal sensor with ratio = 181
Anatop Thermal registered as thermal_zone0
anatop_thermal_probe: default cooling device is cpufreq!
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
usbcore: registered new interface driver snd-usb-audio
mxc_hdmi_soc mxc_hdmi_soc.0: MXC HDMI Audio
mmc0: new high speed DDR MMC card at address 0001
mmcblk0: mmc0:0001 AWPD3R 14.5 GiB
mmcblk0boot0: mmc0:0001 AWPD3R partition 1 4.00 MiB
mmcblk0boot1: mmc0:0001 AWPD3R partition 2 4.00 MiB
hub 2-1:1.0: USB hub found
mmcblk0: p1
hub 2-1:1.0: 4 ports detected
mmcblk0boot1: unknown partition table
asoc: wm8960-hifi <-> imx-ssi.1 mapping ok
mmcblk0boot0: unknown partition table
input: wm8960-audio Mic Jack as /devices/platform/soc-audio.5/sound/card0/input3
input: wm8960-audio Headphone Jack as /devices/platform/soc-audio.5/sound/card0/input4
asoc: mxc-hdmi-soc <-> imx-hdmi-soc-dai.0 mapping ok
ALSA device list:
  #0: wm8960-audio
  #1: imx-hdmi-soc
oprofile: using arm/armv7-ca9
u32 classifier
    Actions configured
Netfilter messages via NETLINK v0.30.
nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
ctnetlink v0.93: registering with nfnetlink.
NF_TPROXY: Transparent proxy support initialized, version 4.1.0
NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
xt_time: kernel timezone is -0000
ip_tables: (C) 2000-2006 Netfilter Core Team
arp_tables: (C) 2002 David S. Miller
TCP cubic registered
Initializing XFRM netlink socket
NET: Registered protocol family 10
Mobile IPv6
ip6_tables: (C) 2000-2006 Netfilter Core Team
NET: Registered protocol family 17
NET: Registered protocol family 15
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
Bus freq driver module loaded
Bus freq driver Enabled
mxc_dvfs_core_probe
DVFS driver module loaded
regulator_init_complete: SPKVDD: incomplete constraints, leaving on
snvs_rtc snvs_rtc.0: setting system clock to 1970-01-01 19:35:58 UTC (70558)
Freeing init memory: 236K
Starting UTP
ln: /etc/mtab: File exists
disable turn off display
Starting the hotplug events dispatcher udevd
udevd (2084): /proc/2084/oom_adj is deprecated, please use /proc/2084/oom_score_adj instead.
Synthesizing initial hotplug events
uuc 0.4 [built Dec 18 2012 13:50:52]
UTP: Waiting for device to appear
UTP: file/device node /dev/utp already exists
cpu_id is 0
以下是ucl2.xml文件
<UCL>
  <CFG>
    <STATE name="BootStrap" dev="MX6Q" vid="15A2" pid="0054"/>
    <STATE name="Updater"   dev="MSC" vid="066F" pid="37FF"/>
  </CFG>
<LIST name="Ubuntu-SabreSD-eMMC" desc="Choose eMMC android as media">
    <CMD state="BootStrap" type="boot" body="BootStrap" file ="u-boot-mx6q-sabresd.bin" >Loading U-boot</CMD>
    <CMD state="BootStrap" type="load" file="uImage" address="0x10800000"
        loadSection="OTH" setSection="OTH" HasFlashHeader="FALSE" >Loading Kernel.</CMD>
    <CMD state="BootStrap" type="load" file="initramfs.cpio.gz.uboot" address="0x10C00000"
        loadSection="OTH" setSection="OTH" HasFlashHeader="FALSE" >Loading Initramfs.</CMD>
    <CMD state="BootStrap" type="jump" > Jumping to OS image. </CMD>
    <CMD state="Updater" type="push" body="$ ls /dev/*"/>
    <CMD state="Updater" type="push" body="$ dd if=/dev/zero of=/dev/mmcblk0 bs=512 seek=1536 count=16">clean up u-boot parameter</CMD>
    <CMD state="Updater" type="push" body="$ dd if=/dev/zero of=/dev/mmcblk0 bs=512 conv=fsync count=4000">clean up u-boot parameter</CMD>
    <CMD state="Updater" type="push" body="$ echo 0 > /sys/block/mmcblk0boot0/force_ro">access boot partition 1</CMD>
    <CMD state="Updater" type="push" body="$ dd if=/dev/zero of=/dev/mmcblk0boot0 bs=512 count=4000">clear u-boot arg</CMD>
    <CMD state="Updater" type="push" body="send" file="files/ubuntu/u-boot.bin">Sending U-Boot</CMD>
    <CMD state="Updater" type="push" body="$ dd if=$FILE of=/dev/mmcblk0boot0 bs=512 seek=2 skip=2">write U-Boot to sd card</CMD>
    <CMD state="Updater" type="push" body="$ echo 1 > /sys/block/mmcblk0boot0/force_ro"> re-enable read-only access </CMD>
    <CMD state="Updater" type="push" body="$ echo 8 > /sys/block/mmcblk0/device/boot_config">enable boot partion 1 to boot</CMD>
    <CMD state="Updater" type="push" body="send" file="mksdcard.sh.tar">Sending partition shell</CMD>
    <CMD state="Updater" type="push" body="$ tar xf $FILE "> Partitioning...</CMD>
    <CMD state="Updater" type="push" body="$ sh mksdcard.sh /dev/mmcblk0"> Partitioning...</CMD>
    <CMD state="Updater" type="push" body="send" file="files/ubuntu/uImage">Sending kernel uImage</CMD>
    <CMD state="Updater" type="push" body="$ dd if=$FILE of=/dev/mmcblk0 bs=1M seek=1 conv=fsync">write kernel image to sd card</CMD>
    <CMD state="Updater" type="push" body="$ mkfs.ext3 -j /dev/mmcblk0p1">Formatting rootfs partition</CMD>
    <CMD state="Updater" type="push" body="$ mkdir -p /mnt/mmcblk0p1"/>
    <CMD state="Updater" type="push" body="$ mount -t ext3 /dev/mmcblk0p1 /mnt/mmcblk0p1"/>
    <CMD state="Updater" type="push" body="pipe tar  -zxv -C /mnt/mmcblk0p1" file="files/ubuntu/iMX6_ubuntu_12.04.tgz">Sending and writting rootfs</CMD>
    <CMD state="Updater" type="push" body="frf">Finishing ubuntu rootfs write</CMD>
    <CMD state="Updater" type="push" body="$ umount /mnt/mmcblk0p1">Unmounting rootfs partition</CMD>
    <CMD state="Updater" type="push" body="$ echo Update Complete!">Done</CMD>
</LIST>
以下是配置文件
[profiles]
chip = MX6Q Linux Update
[platform]
board = SabreSD
[LIST]
name =ubuntu-SabreSD-eMMC
希望有人施以援手,感激不尽
我知道答案 目前已有6人回答
 楼主| 发表于 2019-12-8 22:56:28 | 显示全部楼层
终于烧录进去了。不知道为什么,换个电脑同样的操作就能烧录。难道缺少驱动?
发表于 2019-12-11 21:31:32 | 显示全部楼层
请问你是换了 什么系统的电脑能烧录进去的呢,我现在用的win10,也遇到了相同的问题
发表于 2020-1-3 16:35:37 | 显示全部楼层
liluocheng 发表于 2019-12-8 22:56
终于烧录进去了。不知道为什么,换个电脑同样的操作就能烧录。难道缺少驱动? ...
应该是PC usb接口的问题
发表于 2020-1-3 16:36:40 | 显示全部楼层
ibinus 发表于 2019-12-11 21:31
请问你是换了 什么系统的电脑能烧录进去的呢,我现在用的win10,也遇到了相同的问题 ...
应该是usb 驱动的问题。你这里使用的是哪块板子?板子上要写哪个版本的BSP images?
发表于 2020-1-15 14:33:38 | 显示全部楼层
emmc电压供电不稳有可能造成这种问题
发表于 2020-1-15 17:45:15 | 显示全部楼层
可能是PC机USB接口供电不足
GMT+8, 2025-10-26 20:30 , Processed in 0.107899 second(s), 26 queries , MemCache On.
