查看: 3126|回复: 4
[讨论] NXP LPC55S69 TDM
    郁闷
    2021-8-25 16:50
  • 签到天数: 57 天
    发表于 2019-12-3 13:55:03 | 显示全部楼层 |阅读模式
    LPC55S68 做 4slot,32bit TDM。只有一个 slot 的信号出来。下面是 I2S 的配置:
    void I2S_TxGetDefaultConfig(i2s_config_t *config)
        config->masterSlave = kI2S_MasterSlaveNormalMaster;//kI2S_MasterSlaveNormalMaster;
        config->mode        = kI2S_ModeDspWsShort;//kI2S_ModeDspWsLong;kI2S_ModeDspWs50;//kI2S_ModeI2sClassic;
        config->rightLow    = false;
        config->leftJust    = false;
    #if (defined(FSL_FEATURE_FLEXCOMM_I2S_HAS_DMIC_INTERCONNECTION) && FSL_FEATURE_FLEXCOMM_I2S_HAS_DMIC_INTERCONNECTION)
        config->pdmData = false;
    #endif
        config->sckPol      = false;
        config->wsPol       = true ;//false;
        config->divider     = 1U;
        config->oneChannel  = false;
        config->dataLength  = 32;  //16U;
        config->frameLength = 32 * 2 * 4; // 32bit ,2ch , 4 slot
        config->position    = 0U;
        config->watermark   = 4U;
        config->txEmptyZero = true;
        config->pack48      = false;
    这个是 main.c:
    * Copyright (c) 2016, Freescale Semiconductor, Inc.
    * Copyright 2016-2017 NXP
    * All rights reserved.
    * SPDX-License-Identifier: BSD-3-Clause
    * Includes
    #include "fsl_device_registers.h"
    #include "fsl_debug_console.h"
    #include "board.h"
    #include "fsl_i2c.h"
    #include "fsl_i2s.h"
    #include "fsl_wm8904.h"
    #include "music.h"
    #include "fsl_codec_common.h"
    #include <stdbool.h>
    #include "pin_mux.h"
    #include "fsl_sysctl.h"
    #include "fsl_codec_adapter.h"
    * Definitions
    #define DEMO_I2C (I2C4)
    #define DEMO_I2S_MASTER_CLOCK_FREQUENCY 24576000
    #define DEMO_I2S_TX (I2S7)
    #define DEMO_I2S_RX (I2S6)
    #define I2S_CLOCK_DIVIDER (CLOCK_GetPll0OutFreq() / 48000U / 16U / 2U / 2  )
    #define DEMO_AUDIO_BIT_WIDTH (16)
    #define DEMO_AUDIO_SAMPLE_RATE (48000)
    #define DEMO_AUDIO_PROTOCOL kCODEC_BusI2S
    * Prototypes
    static void StartSoundPlayback(void);
    static void StartDigitalLoopback(void);
    static void TxCallback(I2S_Type *base, i2s_handle_t *handle, status_t completionStatus, void *userData);
    static void RxCallback(I2S_Type *base, i2s_handle_t *handle, status_t completionStatus, void *userData);
    * Variables
    wm8904_config_t wm8904Config = {
        .i2cConfig    = {.codecI2CInstance = BOARD_CODEC_I2C_INSTANCE, .codecI2CSourceClock = BOARD_CODEC_I2C_CLOCK_FREQ},
        .recordSource = kWM8904_RecordSourceLineInput,
        .recordChannelLeft  = kWM8904_RecordChannelLeft2,
        .recordChannelRight = kWM8904_RecordChannelRight2,
        .playSource         = kWM8904_PlaySourceDAC,
        .slaveAddress       = WM8904_I2C_ADDRESS,
        .protocol           = kWM8904_ProtocolI2S,
        .format             = {.sampleRate = kWM8904_SampleRate48kHz, .bitWidth = kWM8904_BitWidth16},
        .mclk_HZ            = DEMO_I2S_MASTER_CLOCK_FREQUENCY,
        .master             = false,
    codec_config_t boardCodecConfig = {.codecDevType = kCODEC_WM8904, .codecDevConfig = &wm8904Config};
    __ALIGN_BEGIN static uint8_t s_Buffer[400] __ALIGN_END; /* 100 samples => time about 2 ms */
    static i2s_config_t s_TxConfig;
    static i2s_config_t s_RxConfig;
    static i2s_handle_t s_TxHandle;
    static i2s_handle_t s_RxHandle;
    static i2s_transfer_t s_TxTransfer;
    static i2s_transfer_t s_RxTransfer;
    extern codec_config_t boardCodecConfig;
    uint8_t codecHandleBuffer[CODEC_HANDLE_SIZE] = {0U};
    codec_handle_t *codecHandle                  = (codec_handle_t *)codecHandleBuffer;
    * Code
    void BOARD_InitSysctrl(void)
        SYSCTL_Init(SYSCTL);
        /* select signal source for share set */
        SYSCTL_SetShareSignalSrc(SYSCTL, kSYSCTL_ShareSet0, kSYSCTL_SharedCtrlSignalSCK, kSYSCTL_Flexcomm7);
        SYSCTL_SetShareSignalSrc(SYSCTL, kSYSCTL_ShareSet0, kSYSCTL_SharedCtrlSignalWS, kSYSCTL_Flexcomm7);
        /* select share set for special flexcomm signal */
        SYSCTL_SetShareSet(SYSCTL, kSYSCTL_Flexcomm7, kSYSCTL_FlexcommSignalSCK, kSYSCTL_ShareSet0);
        SYSCTL_SetShareSet(SYSCTL, kSYSCTL_Flexcomm7, kSYSCTL_FlexcommSignalWS, kSYSCTL_ShareSet0);
        SYSCTL_SetShareSet(SYSCTL, kSYSCTL_Flexcomm6, kSYSCTL_FlexcommSignalSCK, kSYSCTL_ShareSet0);
        SYSCTL_SetShareSet(SYSCTL, kSYSCTL_Flexcomm6, kSYSCTL_FlexcommSignalWS, kSYSCTL_ShareSet0);
    * @brief Main function
    int main(void)
        CLOCK_EnableClock(kCLOCK_InputMux);
        CLOCK_EnableClock(kCLOCK_Iocon);
        CLOCK_EnableClock(kCLOCK_Gpio0);
        CLOCK_EnableClock(kCLOCK_Gpio1);
        /* USART0 clock */
        CLOCK_AttachClk(BOARD_DEBUG_UART_CLK_ATTACH);
        /* I2C clock */
        CLOCK_AttachClk(kFRO12M_to_FLEXCOM***);
        PMC->PDRUNCFGCLR0 |= PMC_PDSLEEPCFG0_PDEN_XTAL32M_MASK;  /*!< Ensure XTAL16M is on  */
        PMC->PDRUNCFGCLR0 |= PMC_PDSLEEPCFG0_PDEN_LDOXO32M_MASK; /*!< Ensure XTAL16M is on  */
        SYSCON->CLOCK_CTRL |= SYSCON_CLOCK_CTRL_CLKIN_ENA_MASK;  /*!< Ensure CLK_IN is on  */
        ANACTRL->XO32M_CTRL |= ANACTRL_XO32M_CTRL_ENABLE_SYSTEM_CLK_OUT_MASK;
        CLOCK_AttachClk(kEXT_CLK_to_PLL0);
        const pll_setup_t pll0Setup = {
            .pllctrl = SYSCON_PLL0CTRL_CLKEN_MASK | SYSCON_PLL0CTRL_SELI(8U) | SYSCON_PLL0CTRL_SELP(31U),
            .pllndec = SYSCON_PLL0NDEC_NDIV(125U),
            .pllpdec = SYSCON_PLL0PDEC_PDIV(8U),
            .pllsscg = {0x0U, (SYSCON_PLL0SSCG1_MDIV_EXT(3072U) | SYSCON_PLL0SSCG1_SEL_EXT_MASK)},
            .pllRate = 24576000U,
            .flags   = PLL_SETUPFLAG_WAITLOCK,
        /*!< Configure PLL to the desired values */
        CLOCK_SetPLL0Freq(&pll0Setup);
        /* Attach PLL clock to MCLK for I2S, no divider */
        CLOCK_AttachClk(kPLL0_to_MCLK);
        SYSCON->MCLKDIV = SYSCON_MCLKDIV_DIV(0U);
        SYSCON->MCLKIO  = 1U;
        CLOCK_SetClkDiv(kCLOCK_DivPll0Clk, 1U, true);
        CLOCK_SetClkDiv(kCLOCK_DivPll0Clk, 1U, false);
        /*!< Switch PLL0 clock source selector to XTAL16M */
        /* I2S clocks */
        CLOCK_AttachClk(kPLL0_DIV_to_FLEXCOMM6);
        CLOCK_AttachClk(kPLL0_DIV_to_FLEXCOMM7);
        /* reset FLEXCOMM for I2C */
        RESET_PeripheralReset(kFC4_RST_SHIFT_RSTn);
        /* reset FLEXCOMM for I2S */
        RESET_PeripheralReset(kFC6_RST_SHIFT_RSTn);
        RESET_PeripheralReset(kFC7_RST_SHIFT_RSTn);
                    RESET_PeripheralReset(kFC5_RST_SHIFT_RSTn);
        NVIC_ClearPendingIRQ(FLEXCOMM6_IRQn);
        NVIC_ClearPendingIRQ(FLEXCOMM7_IRQn);
        /* Enable interrupts for I2S */
        EnableIRQ(FLEXCOMM6_IRQn);
        EnableIRQ(FLEXCOMM7_IRQn);
        /* Initialize the rest */
        BOARD_InitPins();
        BOARD_BootClockFROHF96M();
        BOARD_InitDebugConsole();
        BOARD_InitSysctrl();
        PRINTF("Configure WM8904 codec\r\n");
                    PRINTF("The main clock is %dHz\r\n",CLOCK_GetCoreSysClkFreq()/1000000);
                    PRINTF("The Flexcomm7 clock is %dHz\r\n",CLOCK_GetFreq(kCLOCK_Flexcomm7  ));//CLOCK_GetClockAttachId(kPLL0_DIV_to_FLEXCOMM7)/10000);
                    PRINTF("The Flexcomm6 clock is %dHz\r\n",CLOCK_GetFreq(kCLOCK_Flexcomm6  ));
        /* protocol: i2s
         * sampleRate: 48K
         * bitwidth:16
    #if 0 //Disable codec
        if (CODEC_Init(codecHandle, &boardCodecConfig) != kStatus_Success)
            PRINTF("WM8904_Init failed!\r\n");
        /* Initial volume kept low for hearing safety. */
        /* Adjust it to your needs, 0x0006 for -51 dB, 0x0039 for 0 dB etc. */
        CODEC_SetVolume(codecHandle, kCODEC_PlayChannelHeadphoneLeft | kCODEC_PlayChannelHeadphoneRight, 0x0001);
    #endif
        PRINTF("Configure I2S\r\n");
         * masterSlave = kI2S_MasterSlaveNormalMaster;
         * mode = kI2S_ModeI2sClassic;
         * rightLow = false;
         * leftJust = false;
         * pdmData = false;
         * sckPol = false;
         * wsPol = false;
         * divider = 1;
         * oneChannel = false;
         * dataLength = 16;
         * frameLength = 32;
         * position = 0;
         * watermark = 4;
         * txEmptyZero = true;
         * pack48 = false;
        I2S_TxGetDefaultConfig(&s_TxConfig);
        s_TxConfig.divider = I2S_CLOCK_DIVIDER;
    //                s_TxConfig.wsPol = 1;
         * masterSlave = kI2S_MasterSlaveNormalSlave;
         * rightLow = false;
         * leftJust = false;
         * pdmData = false;
         * sckPol = false;
         * wsPol = false;
         * divider = 1;
         * dataLength = 16;
         * frameLength = 32;
         * position = 0;
         * watermark = 4;
         * txEmptyZero = false;
         * pack48 = false;
    //    I2S_RxGetDefaultConfig(&s_RxConfig);
        I2S_TxInit(DEMO_I2S_TX, &s_TxConfig);
    //    I2S_RxInit(DEMO_I2S_RX, &s_RxConfig);
        if (true)
            StartSoundPlayback();
        else
            StartDigitalLoopback();
        while (1)
        PRINTF("Setup looping playback of sine wave\r\n");
        s_TxTransfer.data     = &g_Music[0];
        s_TxTransfer.dataSize = sizeof(g_Music) ;
        I2S_TxTransferCreateHandle(DEMO_I2S_TX, &s_TxHandle, TxCallback, (void *)&s_TxTransfer);
        I2S_TxTransferNonBlocking(DEMO_I2S_TX, &s_TxHandle, s_TxTransfer);
        PRINTF("Setup digital loopback\r\n");
        s_TxTransfer.data     = &s_Buffer[0];
        s_TxTransfer.dataSize = sizeof(s_Buffer);
        s_RxTransfer.data     = &s_Buffer[0];
        s_RxTransfer.dataSize = sizeof(s_Buffer);
        I2S_RxTransferCreateHandle(DEMO_I2S_RX, &s_RxHandle, RxCallback, (void *)&s_RxTransfer);
        I2S_RxTransferNonBlocking(DEMO_I2S_RX, &s_RxHandle, s_RxTransfer);
        /* Enqueue the same original s_Buffer all over again */
        i2s_transfer_t *transfer = (i2s_transfer_t *)userData;
        I2S_TxTransferNonBlocking(base, handle, *transfer);
        I2S_RxTransferNonBlocking(base, handle, *transfer);
    不知道是配置的问题还是发送的时候的问题?
    LPC55S69 TDM 波形
    LPC55S69 TDM  波形
    签到
    郁闷
    2021-8-25 16:50
  • 签到天数: 57 天
     楼主| 发表于 2019-12-4 11:10:02 | 显示全部楼层
    有人能帮忙解答一下吗
    签到
    发表于 2019-12-5 10:13:32 | 显示全部楼层
    不言而喻hgj 发表于 2019-12-4 11:10
    有人能帮忙解答一下吗
    楼主你好!
    关于LPC I2S的具体问题,建议你可以去官方的论坛:
    http://community.nxp.com/communi ... se-mcus/lpc/content
    或者官网建case, 问题内容请使用英文书写方式,那边会有更多的LPC专家帮你解答。
    郁闷
    2021-8-25 16:50
  • 签到天数: 57 天
     楼主| 发表于 2019-12-6 08:56:56 | 显示全部楼层
    小恩GG 发表于 2019-12-5 10:13
    楼主你好!
    http://community.nxp.com/community/gen ...
    谢谢。现在已经找到解决办法了。
    签到
    郁闷
    2021-8-25 16:50
  • 签到天数: 57 天
     楼主| 发表于 2019-12-6 09:01:03 | 显示全部楼层
    不言而喻hgj 发表于 2019-12-6 08:56
    谢谢。现在已经找到解决办法了。
    还需要对另外3路的I2S配置,另外3路做slave,position 分别是 64,64*2,64*3,再把data线接到一起。波形就能出来了。但是 WS 拉倒 48K 会不正常。
    签到
    GMT+8, 2026-4-17 06:31 , Processed in 0.105112 second(s), 25 queries , Redis On.
