查看: 8739|回复: 11
[求助] LPC51U68 ADC问题
  • 签到天数: 21 天
    发表于 2020-1-10 16:22:30 | 显示全部楼层 |阅读模式
    我使用的是LPC51U68BD48(就是48PIN封装),我将使用ADC通道2(P),但发现配置后PIN脚为高电平(3.3V),怀疑是内部拉高了?时钟有问题?...现在我想知道ADC配置过程和使用方式,是否下面附上我的配置代码
    * Definitions
    #define DEMO_ADC_BASE ADC0
    #define DEMO_ADC_SAMPLE_CHANNEL_NUMBER 2U
    #define DEMO_ADC_CLOCK_DIVIDER 0U
    void ADC_InitPins(void)
      const uint32_t port0_pin31_config = (
        IOCON_PIO_FUNC0 |                                        /* Pin is configured as ADC */
        IOCON_PIO_MODE_INACT |                                   /* No addition pin function */
        IOCON_PIO_INV_DI |                                       /* Input function is not inverted */
        IOCON_PIO_DIGITAL_OFF |                                  /* Disable digital function */
        IOCON_PIO_INPFILT_OFF |                                  /* Input filter disabled */
        IOCON_PIO_SLEW_STANDARD |                                /* Standard mode, output slew rate control is enabled */
        IOCON_PIO_OPENDRAIN_DI                                   /* Open drain is disabled */
      IOCON_PinMuxSet(IOCON, PORT0_IDX, PIN31_IDX, port0_pin31_config); /* PORT0 PIN31 (coords: 9 is configured as ADC */
    void ADC_Initialize(void)
            /* Initialize board hardware. */
            /* attach 12 MHz clock to FLEXCOMM0 (debug console) */
            CLOCK_AttachClk(BOARD_DEBUG_UART_CLK_ATTACH);
            /* Enable the power and clock for ADC. */
            ADC_ClockPower_Configuration();
            /* Calibration after power up. */
            ADC_DoSelfCalibration(DEMO_ADC_BASE);
            /* Configure the converter and work mode. */
            ADC_Configuration();
    void main()
      ADC_InitPins();
      ADC_Initialize();
      While(1)
       ADC_DoSoftwareTriggerConvSeqA(DEMO_ADC_BASE); /* Trigger the ADC and start the conversion. */
       /* Wait for the converter & transfer to be done. */
       while (!ADC_GetChannelConversionResult(DEMO_ADC_BASE, DEMO_ADC_SAMPLE_CHANNEL_NUMBER, &adcResultInfoStruct))
       ADC_Result=adcResultInfoStruct.result*330/g_Adc_12bitFullRange;
      IOCON-&gtIO[0][31] = ((IOCON-&gtIO[0][31] &     (~(IOCON_PIO_FUNC_MASK | IOCON_PIO_MODE_MASK | IOCON_PIO_DIGIMODE_MASK))) /* Mask bits to zero which are setting */   &nb ...
  • 签到天数: 21 天
     楼主| 发表于 2020-1-11 10:55:20 | 显示全部楼层
    emmm~没人吗?
    发表于 2020-1-13 09:57:15 | 显示全部楼层
    ADC测试结果是如何呢?!
  • 签到天数: 21 天
     楼主| 发表于 2020-1-13 13:28:19 | 显示全部楼层
    测试结果是检测值一直在跳变,不稳定,并且在PIN脚悬空状态下也有一个值存在,猜测可能是个虚假信号
  • 签到天数: 21 天
     楼主| 发表于 2020-1-13 13:31:38 | 显示全部楼层
    小恩GG 发表于 2020-1-13 09:57
    ADC测试结果是如何呢?!
  • 签到天数: 1506 天
    发表于 2020-1-13 16:49:25 | 显示全部楼层
    之前在测试时,如果ADC引脚悬空,其值是跳动的。
    即使正常连接阻性传感器,而未加电容滤波,其值也会是跳动的——无法通过软件去除
    发表于 2020-1-14 10:49:12 | 显示全部楼层
    evinyi 发表于 2020-1-13 13:31
    测试结果是检测值一直在跳变,不稳定,并且在PIN脚悬空状态下也有一个值存在,猜测可能是个虚假信号 ...
    我看到你上面的代码在while里一直触发ADC采样,采样结果一直跳变是正常的,只要在一个合理的范围之内。
    即使采样一个悬空的引脚也是会有采样结果的,当然这正如你说的是一个‘虚假信号’
  • 签到天数: 21 天
     楼主| 发表于 2020-1-14 11:44:57 | 显示全部楼层
    感谢您的回答!
    现在我有一个疑问,当我将引脚配置成ADC模式后,引脚会处于高电平状态(外部无电平输入),是否MCU内部默认为上拉?如果是,是否需要配置成下拉->配置方法是先配成GPIO,进行下拉动作,再配成ADC模式?因为我发现如果我将电路整流为直流后无法控制引脚状态,测试值也一直处于一个范围内,无法当作条件使用。
    发表于 2020-1-15 09:41:42 | 显示全部楼层
    引脚的默认状态却为弱上拉,配置成ADC引脚时,你可以将其配置为Inactive (no pull-down/pull-up resistor enabled)
    2016-12-2 08:40
  • 签到天数: 3 天
    发表于 2020-1-15 15:42:18 | 显示全部楼层
      IOCON->IO[0][31] = ((IOCON->IO[0][31] &
          | IOCON_PIO_FUNC(PIO031_FUNC_ALT0)                     /* Selects pin function.: PORT031 (pin 13) is configured as ADC0_2 */
          | IOCON_PIO_MODE(PIO031_MODE_INACTIVE)                 /* Selects function mode (on-chip pull-up/pull-down resistor control).: Inactive. Inactive (no pull-down/pull-up resistor enabled). */
          | IOCON_PIO_DIGIMODE(PIO031_DIGIMODE_ANALOG)           /* Select Analog/Digital mode.: Analog mode. */
    感觉你没是能PIN上的模拟模式,见我贴的这个,最好用我们的MCUXpresso Config Tool生成Pin的配置
    GMT+8, 2025-11-5 11:41 , Processed in 0.115428 second(s), 31 queries , MemCache On.
