查看: 5335|回复: 2
[求助] imx8 mini yocto构建fsl-image-qt5时报错
发表于 2020-1-13 13:50:14 | 显示全部楼层 |阅读模式
具体报错信息如下:
ERROR gstreamer1.0-plugins-base-1.14.4.imx-r0 do_prepare_recipe_sysroot Error executing a python function in exec_python_func() autogenerated
The stack trace of python calls that resulted in this exceptionfailure was
File 'exec_python_func() autogenerated', lineno 2, function module
     0001
  0002extend_recipe_sysroot(d)
     0003
File 'homezhiweiMYD-C8MMX-develMYIR-Yocto-i.MX8MMsourcespokymetaclassesstaging.bbclass', lineno 545, function extend_recipe_sysroot
     0541                    dest = newmanifest[l]
     0542                    if l.endswith()
     0543                        staging_copydir(l, targetdir, dest, seendirs)
     0544                        continue
  0545                    staging_copyfile(l, targetdir, dest, postinsts, seendirs)
     0546
     0547    bb.note(Installed into sysroot %s % str(msg_adding))
     0548    bb.note(Skipping as already exists in sysroot %s % str(msg_exists))
     0549
File 'homezhiweiMYD-C8MMX-develMYIR-Yocto-i.MX8MMsourcespokymetaclassesstaging.bbclass', lineno 151, function staging_copyfile
     0147        os.symlink(linkto, dest)
     0148        #bb.warn(c)
     0149    else
     0150        try
  0151            os.link(c, dest)
     0152        except OSError as err
     0153            if err.errno == errno.EXDEV
     0154                bb.utils.copyfile(c, dest)
     0155            else
Exception FileExistsError [Errno 17] File exists 'homezhiweiMYD-C8MMX-develMYIR-Yocto-i.MX8MMbuild_8m_minitmpsysroots-componentsalliso-codessysroot-providersiso-codes' - 'homezhiweiMYD-C8MMX-develMYIR-Yocto-i.MX8MMbuild_8m_minitmpworkaarch64-mx8mm-poky-linuxgstreamer1.0-plugins-base1.14.4.imx-r0recipe-sysrootsysroot-providersiso-codes'
ERROR gstreamer1.0-plugins-base-1.14.4.imx-r0 do_prepare_recipe_sysroot Function failed extend_recipe_sysroot
ERROR Logfile of failure stored in homezhiweiMYD-C8MMX-develMYIR-Yocto-i.MX8MMbuild_8m_minitmpworkaarch64-mx8mm-poky-linuxgstreamer1.0-plugins-base1.14.4.imx-r0templog.do_prepare_recipe_sysroot.3550
ERROR Task (homezhiweiMYD-C8MMX-develMYIR-Yocto-i.MX8MMsourcesmeta-myirmeta-myir-bsprecipes-multimediagstreamergstreamer1.0-plugins-base_1.14.imx.bbdo_prepare_recipe_sysroot) failed with exit code '1'
我本以为是Python版本不对,尝试替换/usr/bin下的python未能解决,请大佬们协助一下。谢谢。
我知道答案 目前已有2人回答
发表于 2020-1-15 10:47:51 | 显示全部楼层
请问你这里使用的是哪块板子?哪个版本的BSP?
发表于 2020-1-15 18:02:24 | 显示全部楼层
你构建的yocto是那个版本?有按照对应的yocto project配置Ubuntu环境吗?替换的Python有达到该yocto对应的最低Python版本要求吗?
GMT+8, 2026-4-9 00:48 , Processed in 0.091166 second(s), 24 queries , Redis On.
