查看: 3832|回复: 2
[求助] iTOP-i.MX6开发板_V2.7.1 网络问题
发表于 2020-1-30 12:15:03 | 显示全部楼层 |阅读模式
官方提供的 1.imx6q光盘资料\04 源码_android 4.4文件系统 这套源码功能不完整?
使用这套源码调试EIM接口发现内核未初始化EIM接口,增加初始化后正常
现在继续调试网络,怎么都调不通,连ping开发板或开发板ping主机都不通 【开发板IP 默认是192.168.1.230,我的主机是192.168.1.55】
[root@iTOP-iMX6]# ip addr show dev eth0
3: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast qlen 1000
    link/ether 08:90:90:90:90:90 brd ff:ff:ff:ff:ff:ff
    inet 192.168.1.230/24 brd 192.168.1.255 scope global eth0
    inet6 fe80::a90:90ff:fe90:9090/64 scope link
       valid_lft forever preferred_lft forever
[root@iTOP-iMX6]# PHY: 1:00 - Link is Up - 10/Full
[root@iTOP-iMX6]# ping 192.168.1.55
PING 192.168.1.55 (192.168.1.55): 56 data bytes
这里就不动了,等待一段时间后出现下面打印》》
------------[ cut here ]------------
WARNING: at net/sched/sch_generic.c:255 dev_watchdog+0x3a4/0x3b4()
NETDEV WATCHDOG: eth0 (fec): transmit queue 0 timed out
Modules linked in:
[<c005a85c>] (unwind_backtrace+0x0/0x13c) from [<c0096e1c>] (warn_slowpath_commo
n+0x54/0x64)
[<c0096e1c>] (warn_slowpath_common+0x54/0x64) from [<c0096ec0>] (warn_slowpath_f
mt+0x30/0x40)
[<c0096ec0>] (warn_slowpath_fmt+0x30/0x40) from [<c06d4e3c>] (dev_watchdog+0x3a4
/0x3b4)
[<c06d4e3c>] (dev_watchdog+0x3a4/0x3b4) from [<c00a7070>] (run_timer_softirq+0x1
8c/0x3f0)
[<c00a7070>] (run_timer_softirq+0x18c/0x3f0) from [<c009e7cc>] (__do_softirq+0xd
0/0x274)
[<c009e7cc>] (__do_softirq+0xd0/0x274) from [<c009ebfc>] (irq_exit+0xb0/0xb4)
[<c009ebfc>] (irq_exit+0xb0/0xb4) from [<c0053084>] (handle_IRQ+0x5c/0xb8)
[<c0053084>] (handle_IRQ+0x5c/0xb8) from [<c005204c>] (__irq_svc+0x4c/0xe8)
[<c005204c>] (__irq_svc+0x4c/0xe8) from [<c00531fc>] (default_idle+0x24/0x28)
[<c00531fc>] (default_idle+0x24/0x28) from [<c005393c>] (cpu_idle+0xf0/0x124)
[<c005393c>] (cpu_idle+0xf0/0x124) from [<c00089bc>] (start_kernel+0x2ec/0x2f8)
[<c00089bc>] (start_kernel+0x2ec/0x2f8) from [<10008040>] (0x10008040)
---[ end trace 42f9a7b2d6f396bf ]---
fec_stop : Graceful transmit stop did not complete !
这是什么情况????
z358915781 发表于 2020-1-31 22:05 问题进一步确认为内核内核源码的问题,使用官方提供编译好的uimage就能正常ping通,但是使用官方源码编译出 ... 你下载源码,如何编译的。 你可以看一下你购买板子公司提供的文档 ...
 楼主| 发表于 2020-1-31 22:05:09 | 显示全部楼层
问题进一步确认为内核内核源码的问题,使用官方提供编译好的uimage就能正常ping通,但是使用官方源码编译出来的uimage就不能ping了,编译时需要特别的配置吗?手册中并未说明
发表于 2020-2-11 10:36:00 | 显示全部楼层
你下载源码,如何编译的。 你可以看一下你购买板子公司提供的文档,或者是哪里需要修改的。你的这块板子应该是http://www.topeetboard.com/
GMT+8, 2025-10-26 21:21 , Processed in 0.111016 second(s), 25 queries , MemCache On.
