在线时间104 小时
UID3617445
注册时间2020-2-7
NXP金币43
TA的每日心情 | 开心 2025-7-10 13:07 |
签到天数: 43 天 连续签到: 1 天 [LV.5]常住居民I
- 1630
- 2026-1-27
LPC55S69之定时器
用CTimer来产生100ms和1s标志位,用于在主循环中使用。
一、引脚。
二、代码。
- <font size="3" face="微软雅黑">#include "fsl_debug_console.h"
- #include "board.h"
- #include "fsl_ctimer.h"
- #include "pin_mux.h"
- #include <stdbool.h>
- #define CTIMER CTIMER2 /* Timer 2 */
- #define CTIMER_MAT_OUT kCTIMER_Match_1 /* Match output 1 */
- #define CTIMER_CLK_FREQ CLOCK_GetCTimerClkFreq(2U)
- void ctimer2_callback(uint32_t flags);
- volatile uint32_t g_pwmPeriod = 0U;
- volatile uint32_t g_pulsePeriod = 0U;
- static ctimer_callback_t ctimer_callback[] = {ctimer2_callback};
- volatile uint32_t gCtimer100msCnt = 0U;
- volatile uint32_t gCtimer100msFlag = 0U;
- volatile uint32_t gCtimer1sFlag = 0U;
- status_t CTIMER_GetPwmPeriodValue(uint32_t pwmFreqHz, uint8_t dutyCyclePercent, uint32_t timerClock_Hz) {
- g_pwmPeriod = (timerClock_Hz / pwmFreqHz) - 1;
- if (dutyCyclePercent == 0) {
- g_pulsePeriod = g_pwmPeriod + 1;
- } else {
- g_pulsePeriod = (g_pwmPeriod * (100 - dutyCyclePercent)) / 100;
- return kStatus_Success;
- void ctimer2_callback(uint32_t flags) {
- gCtimer100msFlag = 1;
- if(gCtimer100msCnt > 9) {
- gCtimer1sFlag = 1;
- gCtimer100msCnt = 0;
- } else {
- gCtimer100msCnt++;
- int main(void) {
- ctimer_config_t config;
- uint32_t timerClock;
- uint8_t flag1 = 0,flag2 = 0;
- CLOCK_AttachClk(BOARD_DEBUG_UART_CLK_ATTACH);
- CLOCK_AttachClk(kFRO_HF_to_CTIMER2);
- BOARD_InitPins();
- BOARD_BootClockPLL150M();
- BOARD_InitDebugConsole();
- CTIMER_GetDefaultConfig(&config);
- timerClock = CTIMER_CLK_FREQ / (config.prescale + 1);
- CTIMER_Init(CTIMER, &config);
- CTIMER_RegisterCallBack(CTIMER, &ctimer_callback[0], kCTIMER_SingleCallback);
- CTIMER_GetPwmPeriodValue(10, 50, timerClock); // 10Hz = 100ms中断一次
- CTIMER_SetupPwmPeriod(CTIMER, CTIMER_MAT_OUT, g_pwmPeriod, g_pulsePeriod, true);
- CTIMER_StartTimer(CTIMER);
- while (1) {
- if(gCtimer100msFlag == 1) {
- if(flag1 == 0) {
- GPIO_PinWrite(BOARD_INITPINS_OUT1_GPIO,BOARD_INITPINS_OUT1_PORT,BOARD_INITPINS_OUT1_PIN,0);
- flag1 = 1;
- } else {
- GPIO_PinWrite(BOARD_INITPINS_OUT1_GPIO,BOARD_INITPINS_OUT1_PORT,BOARD_INITPINS_OUT1_PIN,1);
- flag1 = 0;
- gCtimer100msFlag = 0;
- } else if(gCtimer1sFlag == 1) {
- if(flag2 == 0) {
- GPIO_PinWrite(BOARD_INITPINS_OUT2_GPIO,BOARD_INITPINS_OUT2_PORT,BOARD_INITPINS_OUT2_PIN,0);
- flag2 = 1;
- } else {
- GPIO_PinWrite(BOARD_INITPINS_OUT2_GPIO,BOARD_INITPINS_OUT2_PORT,BOARD_INITPINS_OUT2_PIN,1);
- flag2 = 0;
- gCtimer1sFlag = 0;
- }</font>
复制代码 三、其它问题。
使用CTimer0、1、3、4时,发现
timerClock = CTIMER_CLK_FREQ / (config.prescale + 1);的CTIMER_CLK_FREQ为0,将其改为96000000即可。
文章出处:点击
