查看: 6115|回复: 0
[分享] GitLab 部署 NXP-i.MX 8MM 源码
    发表于 2020-5-12 14:08:22 | 显示全部楼层 |阅读模式
    为了方便多人的协作开发,现在把NXP-i.MX 8MM部署在内部服务器搭建的GitLab上。
    GitLab上新建Groups,然后在Groups中添加需要的仓库
    针对有子目录的情况, 可以新建subgroup来解决, 比如src/meta1 , src/meta2等仓库
    源码的目录结构通过manifests/default.xml来维护,通过repo来管理
    1. <font size="3" face="微软雅黑"><?xml version="1.0" encoding="UTF-8"?>
    2. <manifest>
    3.         <remote name="origin" fetch="." review="ssh://git@gitlab.sugrsugr.com:9022/nxp/" />
    4.         <default revision="master" remote="origin" />
    5.     <project name="doc" path="doc">
    6.         <copyfile dest="fsl-setup-release.sh" src="build/fsl-setup-release.sh"/>
    7.         <copyfile dest="setup-environment" src="build/setup-environment"/>
    8.         <copyfile dest="README-IMXBSP" src="build/README-IMXBSP"/>
    9.         <copyfile dest="README" src="build/README"/>
    10.         </project>
    11.         <project name="base" path="sources/base"/>
    12.         <project name="meta-browser" path="sources/meta-browser"/>
    13.         <project name="meta-freescale" path="sources/meta-freescale"/>
    14.         <project name="meta-freescale-3rdparty" path="sources/meta-freescale-3rdparty"/>
    15.         <project name="meta-freescale-distro" path="sources/meta-freescale-distro"/>
    16.         <project name="meta-fsl-bsp-release" path="sources/meta-fsl-bsp-release"/>
    17.         <project name="meta-openembedded" path="sources/meta-openembedded"/>
    18.         <project name="meta-qt5" path="sources/meta-qt5"/>
    19.         <project name="poky" path="sources/poky"/>
    20. </manifest>
    21. </font>
    repo下载源码:
    1. <font size="3" face="微软雅黑">git clone xxx/nxp/repo.git
    2. mkdir .repo
    3. mv repo .repo
    4. cp .repo/repo/repo ./
    5. repo init -u xxx/nxp/manifests.git  -b master
    6. repo sync </font>
    GitLab里面集成的服务越来越多,包括CI/CD等服务。这也是下一步需要着手去做的。
    问题1
    1. <font size="3" face="微软雅黑">➜   ./repo sync
    2. fatal: duplicate path sources/meta-fsl-bsp-release in /home/mike/Project/nxp-yocto-gitlab/.repo/manifest.xml
    3. </font>
    出错的原因是,manifest.xml多重定义
    1. <font size="3" face="微软雅黑"> <project name="meta-fsl-bsp-release" path="sources/meta-fsl-bsp-release/">
    2.     <project name="meta-fsl-bsp-release" path="sources/meta-fsl-bsp-release">
    3.         <linkfile dest="fsl-setup-release.sh" src="imx/tools/fsl-setup-release.sh"/>
    4.         </project>
    5. </font>
    改为
    1. <font size="3" face="微软雅黑"><project name="meta-fsl-bsp-release" path="sources/meta-fsl-bsp-release">
    2.         <linkfile dest="fsl-setup-release.sh" src="imx/tools/fsl-setup-release.sh"/>
    3.         </project>
    4. </font>
    文章出处:CSDN     原文链接:http://blog.csdn.net/z2066411585/article/details/89972811
    GMT+8, 2026-4-13 00:39 , Processed in 0.073580 second(s), 20 queries , Redis On.
