查看: 4257|回复: 0
[分享] LPC824 gpio中断配置指南
    发表于 2020-5-12 14:48:12 | 显示全部楼层 |阅读模式
    LPC824 gpio中断配置指南
    1. gpio4 做为PIN_INT0_IRQn
    中断初始化:
    //gpio4 作为eint0
        NVIC_ClearPendingIRQ(PIN_INT0_IRQn);
        NVIC_EnableIRQ(PIN_INT0_IRQn);
        //NVIC_EnableIRQ(PIN_INT4_IRQn);
        LPC_SYSCON->PDRUNCFG  &= ~WDT_OSC_PD;                               /* 运行WDT                      */
        /*PIO4 低功耗初始化*/
        LPC_SYSCON->PINTSEL0 = 4;
        // 中断0 对应的边缘触发
        LPC_PIN_INT->ISEL   &= ~0x1;                                         /* 边沿触发                     */
         LPC_PIN_INT->IENF   |=  0x1;                     // enable 中断0
        LPC_PIN_INT->IST =0xff;                    //清所有中断状态reg
    中断服务进程如下:
    void PIN_INT0_IRQHandler (void)
        LPC_PIN_INT->IST |=  (1<<0);
    2.  gpio28做为PIN_INT4_IRQn配置如下:
    #if 1 //add liuxd 20190327 reload vbus wakeup system
        NVIC_ClearPendingIRQ(PIN_INT4_IRQn);
        axp173_irq_init();
        LPC_SYSCON->SYSAHBCLKCTRL |= (1 << 6);
        LPC_GPIO_PORT->DIR0 &= ~(1<<28);         // io28 input
        LPC_SYSCON->PINTSEL4 = 28;
        LPC_PIN_INT->ISEL   &= ~0x10;         /* 边沿触发                     */
        LPC_PIN_INT->IENF   |=  0x10;            //使用中断4
        LPC_PIN_INT->IST = 0xff;                 //clear INT status
    #endif
    void PIN_INT4_IRQHandler (void)
        LPC_PIN_INT->IST |=  (1<<4);
    中断发生后一定要清中断,要不中断被占用后将不再发生中断!
    本案中用的pmu为axp173,可它的IRQ一直没有发生,原来不是中断被占用后将不再发生中断的原因,将中断全部清一下后ok
    清中断如下:
    static void axp173_irq_init(void)
          char buff[2] = {0};
          buff[0] = 8;
          i2c2_write_nbytes(0x34,0x40,buff,1); // INT Enable
          buff[0] = 8;
          i2c2_write_nbytes(0x34,0x41,buff,1); // INT Enable
          buff[0] = 0;
          i2c2_write_nbytes(0x34,0x42,buff,1); // INT Enable
          buff[0] = 0;
          i2c2_write_nbytes(0x34,0x43,buff,1); // INT Enable
          buff[0] = 0xff;
          i2c2_write_nbytes(0x34,0x44,buff,1); //clear INT status
          buff[0] = 0xff;
          i2c2_write_nbytes(0x34,0x45,buff,1); //clear INT status
          buff[0] = 0xff;
          i2c2_write_nbytes(0x34,0x46,buff,1); //clear INT status
          buff[0] = 0xff;
          i2c2_write_nbytes(0x34,0x47,buff,1); //clear INT status
    大功告成!
    文章出处:CSDN
    GMT+8, 2025-9-12 04:34 , Processed in 0.082847 second(s), 19 queries , MemCache On.
