查看: 5600|回复: 0
[分享] KW36入门学习(六、开机后自动广播)
    发表于 2020-5-13 16:36:31 | 显示全部楼层 |阅读模式
    KW36入门学习(六、开机后自动广播)
    由于nxp提供的例程基本都得按下按键sw2后,才会有广播。这样对于自己设计的板子上没有按键的就很受伤,所以这里讲如何让板子上电后不用按按键,就直接广播看现象。
    首先得知道在哪里修改,查看程序流程
    main_task-》 App_Thread-》 App_HandleHostMessageInput-》 BleApp_GenericCallback
    前面的都是在Appmian文件里,对于所有的蓝牙工程都是用的它,所以真正程序开始做自己的是在最后这个步骤,在这个环境下有如下情况。
    typedef enum gapGenericEventType_tag {
        gInitializationComplete_c,                  /*!< Initial setup started by Ble_HostInitialize is complete. */
        gInternalError_c,                           /*!< An internal error occurred. */
        gAdvertisingSetupFailed_c,                  /*!< Error during advertising setup. */
        gAdvertisingParametersSetupComplete_c,      /*!< Advertising parameters have been successfully set. Response to Gap_SetAdvertisingParameters. */
        gAdvertisingDataSetupComplete_c,            /*!< Advertising and/or scan response data has been successfully set. Response to Gap_SetAdvertisingData. */
        gWhiteListSizeRead_c,                       /*!< Contains the White List size. Response to Gap_ReadWhiteListSize. */
        gDeviceAddedToWhiteList_c,                  /*!< Device has been added to White List. Response to Gap_AddDeviceToWhiteList. */
        gDeviceRemovedFromWhiteList_c,              /*!< Device has been removed from the White List. Response to Gap_RemoveDeviceFromWhiteList. */
        gWhiteListCleared_c,                        /*!< White List has been cleared. Response to Gap_ClearWhiteList. */
        gRandomAddressReady_c,                      /*!< A random device address has been created. Response to Gap_CreateRandomDeviceAddress. */
        gCreateConnectionCanceled_c,                /*!< Connection initiation was successfully cancelled. Response to Gap_CancelInitiatingConnection. */
        gPublicAddressRead_c,                       /*!< Contains the public device address. Response to Gap_ReadPublicDeviceAddress. */
        gAdvTxPowerLevelRead_c,                     /*!< Contains the TX power on the advertising channel. Response to Gap_ReadAdvertisingTxPowerLevel. */
        gPrivateResolvableAddressVerified_c,        /*!< Contains the result of PRA verification. Response to Gap_VerifyPrivateResolvableAddress. */
        gRandomAddressSet_c,                        /*!< Random address has been set into the Controller. Response to Gap_SetRandomAddress. */
        gControllerResetComplete_c,                 /*!< Controller has been successfully reset. */
        gLeScPublicKeyRegenerated_c,                /*!< The private/public key pair used for LE Secure Connections pairing has been regenerated. */
        gLeScLocalOobData_c,                        /*!< Local OOB data used for LE Secure Connections pairing. */
        gHostPrivacyStateChanged_c,                 /*!< Host Privacy was enabled or disabled. */
        gControllerPrivacyStateChanged_c,           /*!< Controller Privacy was enabled or disabled. */
        gControllerTestEvent_c,                     /*!< Controller Test was started or stopped. */
        gTxPowerLevelSetComplete_c,                 /*!< Controller Tx Power Level set complete or invalid. */
        gLePhyEvent_c                               /*!< Phy Mode of a connection has been updated by the Controller. */
    } gapGenericEventType_t;
    在hrs工程里用的是红色的标记, gInitializationComplete_c 会去配置应用层,gAdvertisingParametersSetupComplete_c 会去处理广播事件,连接事件。这里我们希望当蓝牙数据设置完成后就开始广播(这个就是我们想去执行的),为了处罚广播事件,添加gAdvertisingDataSetupComplete_c 。添加的具体内容参考按键里面的,增加 BleApp_Start();具体修改如下
    void BleApp_GenericCallback (gapGenericEvent_t* pGenericEvent)
        /* Call BLE Conn Manager */
        BleConnManager_GenericEvent(pGenericEvent);
        switch (pGenericEvent->eventType)
            case gInitializationComplete_c:
                BleApp_Config();
            break;
            case gAdvertisingParametersSetupComplete_c:
                App_StartAdvertising(BleApp_AdvertisingCallback, BleApp_ConnectionCallback);
            break;
            case gAdvertisingDataSetupComplete_c:
                BleApp_Start();
            break;
            default:
                break;
    到这里其实只是配置好了广播参数,这里的都是准备工作为了促发广播事件,看BleApp_Start到底做了什么
    BleApp_Start()-》BleApp_Advertise-》Gap_SetAdvertisingParameters
    再分析App_StartAdvertising,所以最后广播在Gap_StartAdvertising这里启动
    App_StartAdvertising-》Gap_StartAdvertising
    这样download程序后,直接可以看到广播了,好处是方便调试。
    文章出处:CSDN
    GMT+8, 2026-4-13 00:43 , Processed in 0.080386 second(s), 20 queries , Redis On.
