查看: 7544|回复: 3
[求助] LPC54618 CAN0 收发不成功 ,CAN1收发正常,不知错在那里了?
  • 签到天数: 14 天
    发表于 2020-7-1 17:10:41 | 显示全部楼层 |阅读模式
    我从官网上修改引脚过来的程序初始化如下:
          mcan_config_t mcanConfig;
        mcan_frame_filter_config_t rxFilter;
            mcan_ext_filter_element_config_t extFilter;
        mcan_rx_fifo_config_t rxFifo0;
        mcan_tx_buffer_config_t txBuffer;
        uint8_t node_type;
        uint8_t numMessage = 0;
        uint8_t cnt        = 0;
       // Set MCAN clock 180/6=30MHz. /
       // 引脚配置:
                 IOCON->PIO[1][2] = ((IOCON->PIO[1][2] &
                                                     // Mask bits to zero which are setting //
                                                     (~(IOCON_PIO_FUNC_MASK | IOCON_PIO_DIGIMODE_MASK)))
                                                    // Selects pin function.
                                                    // * : PORT12 (pin 117) is configured as CAN0_TD. //
                                                    | IOCON_PIO_FUNC(PIO12_FUNC_ALT1)
                                                    // Select Analog/Digital mode.
                                                    // : Digital mode. /
                                                    | IOCON_PIO_DIGIMODE(PIO12_DIGIMODE_DIGITAL));
            IOCON->PIO[1][3] = ((IOCON->PIO[1][3] &
                                                    // * : PORT13 (pin 120) is configured as CAN0_RD. //
                                                    | IOCON_PIO_FUNC(PIO13_FUNC_ALT1)
                                                    // * : Digital mode. //
                                                    | IOCON_PIO_DIGIMODE(PIO13_DIGIMODE_DIGITAL));
      // 时钟源配置
       CLOCK_SetClkDiv(kCLOCK_DivCan0Clk, 6U, true);
        MCAN_GetDefaultConfig(&mcanConfig);
    #if (defined(USE_IMPROVED_TIMING_CONFIG) && USE_IMPROVED_TIMING_CONFIG)
                    mcan_timing_config_t timing_config;
                    memset(&timing_config, 0, sizeof(timing_config));
                    if (MCAN_CalculateImprovedTimingValues(mcanConfig.baudRateA, MCAN_CLK_FREQ, &timing_config))
                            /* Update the improved timing configuration*/
                            memcpy(&(mcanConfig.timingConfig), &timing_config, sizeof(mcan_timing_config_t));
                    else
                       //        PRINTF("No found Improved Timing Configuration. Just used default configuration\r\n\r\n");
    #endif
       // 基础配置
        MCAN_Init(EXAMPLE_MCAN, &mcanConfig, MCAN_CLK_FREQ);
       // Create MCAN handle structure and set call back function. //
        MCAN_TransferCreateHandle(EXAMPLE_MCAN, &mcanHandle, mcan_callback, NULL);
       // Set Message RAM base address and clear to avoid BEU/BEC error. //
        MCAN_SetMsgRAMBase(EXAMPLE_MCAN, MSG_RAM_BASE);
        uint32_t *p = (uint32_t *)(MSG_RAM_BASE);
        memset(p, 0, (8U + CAN_DATASIZE) * sizeof(uint8_t));
        /* STD filter config. */
        rxFilter.address  = STD_FILTER_OFS;
        rxFilter.idFormat = kMCAN_FrameIDExtend;
        rxFilter.listSize = 0U;
        rxFilter.nmFrame  = kMCAN_acceptinFifo0;
        rxFilter.remFrame = kMCAN_filterFrame;
        MCAN_SetFilterConfig(EXAMPLE_MCAN, &rxFilter);
        extFilter.efec=kMCAN_disable;
        extFilter.eft=kMCAN_range;
            extFilter.efid1=0; //  : 29; /*!< Extended Filter ID 1. */
        extFilter.efid2=0x1fffffff;//  : 29; /*!< Extended Filter ID 2. */
            MCAN_SetEXTFilterElement(EXAMPLE_MCAN, &rxFilter,&extFilter,0);
        /* RX fifo0 config. */
        rxFifo0.address       = RX_FIFO0_OFS;
        rxFifo0.elementSize   = 1U;
        rxFifo0.watermark     = 0;
        rxFifo0.opmode        = kMCAN_FifoBlocking;
        rxFifo0.datafieldSize = kMCAN_8ByteDatafield;
        MCAN_SetRxFifo0Config(EXAMPLE_MCAN, &rxFifo0);
        /* TX buffer config. */
        memset(&txBuffer, 0, sizeof(txBuffer));
        txBuffer.address       = TX_BUFFER_OFS;
        txBuffer.dedicatedSize = 1U;
        txBuffer.fqSize        = 0;
        txBuffer.datafieldSize = kMCAN_8ByteDatafield;
        MCAN_SetTxBufferConfig(EXAMPLE_MCAN, &txBuffer);
        /* Finish software initialization and enter normal mode, synchronizes to
           CAN bus, ready for communication */
        MCAN_EnterNormalMode(EXAMPLE_MCAN);
    // 以下为发送 部分:
        // ----------- 1秒计时 --------------
         if(uiCAN0RunT<1000) return;
              uiCAN0RunT=0;
            //   Test_LED_TOGGLE();
              // Config TX frame data. //
                          txIdentifier=0x1826f456U;
                            tx_data[0] =0x01;
                            tx_data[1] =0x01;
                            tx_data[2] =0x00;
                            tx_data[3] =0xff;
                            tx_data[4] =0xff;
                            tx_data[5] =0xff;
                            tx_data[6] =0xff;
                            tx_data[7] =0xff;
                txFrame.xtd  = kMCAN_FrameIDExtend;     //  kMCAN_FrameIDStandard;
                txFrame.rtr  = kMCAN_FrameTypeData;     // kMCAN_FrameTypeRemote;   //   kMCAN_FrameTypeData;
                txFrame.fdf  = 0;
                txFrame.brs  = 0;
                txFrame.id   =txIdentifier;// txIdentifier << STDID_OFFSET;
                txFrame.data = tx_data;
                txFrame.size = CAN_DATASIZE;
                txFrame.fdf = 0; // 1;
                txFrame.brs = 1;
                txFrame.dlc = 6;
                txXfer.frame     = &txFrame;
                txXfer.bufferIdx = 0;
                MCAN_TransferSendNonBlocking(EXAMPLE_MCAN, &mcanHandle, &txXfer);
    本帖最后由 zmh169 于 2020-7-2 10:21 编辑 问题描述不具体:是代码卡死在哪了?还是代码正常跑,但CAN总线收发不到数据?先确保CAN收发硬件没问题。排除硬件问题那估计是初始化问题,试试增加GPIO时钟使能看看。 ...
  • 签到天数: 27 天
    发表于 2020-7-2 09:34:29 | 显示全部楼层
    1.     /* Enables the clock for the GPIO module */
    2.     CLOCK_EnableClock(kCLOCK_Gpio0);
    3.     CLOCK_EnableClock(kCLOCK_Gpio1);
    发表于 2021-3-19 09:16:54 | 显示全部楼层
    楼主我也遇到这个问题了,CAN0和CAN1配置一样,请问一下这个问题出在哪里呀
  • 签到天数: 14 天
     楼主| 发表于 2021-4-14 18:01:23 | 显示全部楼层
    CAN0和CAN1配置是不一样的,尤其是接收RAM绶存配置、时钟配置。
    GMT+8, 2026-4-5 00:54 , Processed in 0.090252 second(s), 25 queries , Redis On.
