查看: 3964|回复: 1
[求助] KL25/KL26 之GPIO中断打不开
  • 签到天数: 5 天
    发表于 2020-7-4 09:20:42 | 显示全部楼层 |阅读模式
    以前玩的stm32,最近开始玩的KL系列,发现差距好大
    KL25的中断有多难打开啊!
    咋配置都没有用
    1. void echo_input(void)
    2. {
    3.     const port_pin_config_t portc12_pin88_config = {/* Internal pull-up resistor is enabled */
    4.                                                   kPORT_PullDown, //kPORT_PullUp,
    5.                                                   /* Slow slew rate is configured */
    6.                                                   kPORT_FastSlewRate,
    7.                                                   /* Passive filter is disabled */
    8.                                                   kPORT_PassiveFilterDisable,
    9.                                                   /* Low drive strength is configured */
    10.                                                   kPORT_LowDriveStrength,
    11.                                                   /* Pin is configured as PTC12 */
    12.                                                   kPORT_MuxAsGpio};
    13.     /* PORTC12 (pin 88) is configured as PTC12 */
    14.     PORT_SetPinConfig(ECHO_PORT, ECHO_PINn, &portc12_pin88_config);
    15.
    16.     /* Define the init structure for the input switch pin */
    17.     gpio_pin_config_t sw_config = {
    18.         kGPIO_DigitalInput, 0,
    19.     };
    20. PORT_SetPinInterruptConfig(ECHO_PORT, ECHO_PINn, kPORT_InterruptFallingEdge);
    21. EnableIRQ(ECHO_PORT_IRQn);
    22.
    23.     GPIO_PinInit(ECHO_GPIO, ECHO_PINn, &sw_config);
    24.     /* Init input switch GPIO. */
    25. }
    中断入口
    1. void PORTD_IRQHandler(void)
    2. {
    3.   GPIO_ClearPinsInterruptFlags(ECHO_GPIO, 1u<<ECHO_PINn);
    4.   static uint32_t tick_start = 0;
    5.   if(GPIO_ReadPinInput(ECHO_GPIO, ECHO_PINn) == 1)
    6.   {
    7.     tick_start = get_us();
    8.   }
    9.   else
    10.   {
    11.     distance = (get_us()-tick_start)*170/10000;
    12.   }
    13. #if defined __CORTEX_M && (__CORTEX_M == 4U)
    14.     __DSB();
    15. #endif
    16. }
    就是不进中断
    我知道答案 目前已有1人回答
    uart_polling.zip
    2.73 KB, 下载次数: 1, 下载积分: 威望 1
    打卡打卡!今天天气不好!
  • 签到天数: 5 天
     楼主| 发表于 2020-7-4 10:58:57 | 显示全部楼层
    用A口,好了
    打卡打卡!今天天气不好!
    GMT+8, 2026-4-12 00:29 , Processed in 0.084131 second(s), 23 queries , Redis On.
