查看: 4548|回复: 0
[分享] (kinetis K60)UART寄存器 串口收发数据
  • 签到天数: 48 天
    发表于 2020-7-7 22:44:42 | 显示全部楼层 |阅读模式
    串口初始化……
    main.c 文件
    1. #include "common.h"
    2. #include "uart.h"
    3. #include "isr.h"
    4. void UART4_Init(U32);
    5. void delay(long count);
    6. void Uart4_SendByte(U8 Char);
    7. void main (void)
    8. {
    9.   char str[]="hello cortex-m4  ";
    10.   U8 i;
    11.
    12.   DisableInterrupts;
    13.   UART4_Init(57600);
    14.   EnableInterrupts;
    15.
    16.   while(1)
    17.   {
    18.     for(i=0; str[i]!='\0'; i++)
    19.       Uart4_SendByte(str[i]);
    20.     delay(7000000);
    21.   }
    22. }
    23. void delay(long count)
    24. {
    25.   while(count--)
    26.       asm("nop");
    27. }
    28. void UART4_Init(U32 BaudRate)
    29. {
    30.   U16 ubd, brfa;
    31.   U8 temp;
    32.
    33.   PORTC_PCR15 = PORT_PCR_MUX(0x3);   //引脚使能
    34.   PORTC_PCR14 = PORT_PCR_MUX(0x3);
    35.   SIM_SCGC1 |= SIM_SCGC1_UART4_MASK;   //时钟使能
    36.   UART4_C2 &= ~((1<<2) | (1<<3)); //禁止发送接收   控制寄存器C2
    37.
    38.   UART4_C1 = 0;  //控制器C1 全部使用默认配备
    39.   ubd = (U16)((50000000)/(BaudRate * 16));   //波特率设置
    40.   UART4_BDH = (U8)ubd>>8;
    41.   UART4_BDL = (U8)(ubd);
    42.
    43.
    44.   brfa = (((50000000)/(BaudRate * 16)) - (ubd * 32));  //波特率微调 1/32的增量
    45.   temp = UART4_C4 & ~(UART_C4_BRFA(0x1F));
    46.   UART4_C4 = temp | UART_C4_BRFA(brfa);
    47.
    48.   UART4_C2 |= ((1<<2) | (1<<3));  //允许发送接收
    49.   return;
    50. }
    51. void Uart4_SendByte(U8 Char)
    52. {
    53.     while(!(UART_S1_REG(UART4_BASE_PTR) & UART_S1_TDRE_MASK)); //UARTx_S1状态寄存器
    54.     UART4_D = Char;
    55.     return;
    56. }
    串口接收函数
    1. U8 Uart4_Receive(void)
    2. {
    3.     U8 Receivechar;
    4.     while(!(UART_S1_REG(UART4_BASE_PTR) & UART_S1_RDRF_MASK));       //查询是否接受到数据
    5.     Receivechar  =   UART4_D;                    //接受到8位的数据
    6.     return(Receivechar);
    7. }
    11111签到
    GMT+8, 2025-10-26 08:38 , Processed in 0.083221 second(s), 19 queries , MemCache On.
