查看: 3023|回复: 0
【S08P闯关赛经验分享】+按键
  • 签到天数: 8 天
    发表于 2020-7-9 19:12:55 | 显示全部楼层 |阅读模式
          测试一下按键,也遇到了xyzml坛友同样的问题,按键失灵,SW3按下无反应,万用表测按键已经失效,两个都换掉了。
    * key.h
    *  Created on: Jul 9, 2020
    *      Author: Haifeng
    #ifndef KEY_H_
    #define KEY_H_
    #define        KEY_S2Init()        PORT_Init(PTD, 4, 1, PORT_MODE_IN_PULL)
    #define        KEY_S2Read()        PORT_PinRead(PTD, 4)
    #define        KEY_S3Init()        PORT_Init(PTD, 5, 1, PORT_MODE_IN_PULL)
    #define        KEY_S3Read()        PORT_PinRead(PTD, 5)
    #define        KEY_Init()        do{        \
            KEY_S2Init();                \
            KEY_S3Init();                \
    }while(0)
    #endif /* KEY_H_ */
    #include <hidef.h> /* for EnableInterrupts macro */
    #include "derivative.h" /* include peripheral declarations */
    unsigned char key_code,key_tri,key_cnt;
    void        DELAY_Ms(int tMs)
            int tUs;
            while(tMs--)
                    tUs = 250;
                    while(tUs --);
    void        KEY_Read(void)
            unsigned char key_value = 0;
            if(KEY_S2Read() == 0)
                    key_value |= 0x01;
            if(KEY_S3Read() == 0)
                    key_value |= 0x02;
            if(key_code != key_value)
                    key_code = key_value;
                    key_cnt = 0;
            else if(key_cnt < 20)
                    key_cnt ++;
                    if((key_cnt == 10) &&
                       (key_code != 0))
                            key_tri = 1;
    void main(void)
            unsigned char i = 0x01;
            key_code = 0;
            key_tri = 0;
            WDT_Init(10000);
            DisableInterrupts;
      /* include your code here */
            LED_Init();
            KEY_Init();
            for(;;)
                    WDT_Clr();        /* feeds the dog */
                    KEY_Read();
                    if(key_tri != 0)
                            key_tri = 0;
                            if(key_code & 0x01) i++;
                            else if(key_code & 0x02) i--;
                    LED_Display(~i);
                    DELAY_Ms(10);
            } /* loop forever */
      /* please make sure that you never leave main */
    今天天气不错!签到!
    GMT+8, 2026-11-23 01:34 , Processed in 0.077725 second(s), 22 queries , Redis On.
