查看: 6467|回复: 0
[S32] S32K144 LPI2C (Low Power Inter-Integrated Circuit) 多字节读取函数
发表于 2020-7-17 09:45:05 | 显示全部楼层 |阅读模式
* Function Name : LPI2C0_read_bytes
* Parameters    : uint8_t s_r_address, uint8_t s_reg_address, uint8_t *p_buffer, uint8_t n_bytes
* Modifies      : uint8_t *p_buffer
* Returns       : uint8_t
* Notes         : Read from a slave
* Date          : 2020/07/16 Check by Read 7 bytes from PCF8563
uint8_t LPI2C0_read_bytes(uint8_t s_r_address, uint8_t s_reg_address, uint8_t *p_buffer, uint8_t n_bytes)
    uint8_t  n;
    uint16_t time = 0;
    uint16_t command;
    if(bus_busy()) return (error |= (1 << BUSY));
    generate_start_ACK(s_r_address - 1); /*<! Send I2C Address : Write 0xA2 */
    transmit_data(s_reg_address);        /*<! Send Register Address */
    generate_stop();                     /*<! Send stop */
        for (n = 0; n < n_bytes; ++n) {
                generate_start_ACK(s_r_address); /*<! Send Register Address : Write 0xA2 */
                command  =   0x0100;             /*<! Read Command is bit15 to bit8 */
                command |=   0;                  /*<! with (n_bytes - 1) parameter */
                LPI2C0->MTDR = command;          /*<! Send 1 byte Read Command with (n_bytes - 1) */
                time = 0;
                while (((LPI2C0->MFSR) >> 16 != 1) && (time < READING_TIMEOUT)) ++time;
                if(time >= READING_TIMEOUT) {
                        LPI2C0->MCR |= (1 << 9);     /*<! Reset Receive FIFO */
                        error |= (1 << NO_DATA_RECEIVED);
                } else {
                        p_buffer[n] = (uint8_t)(LPI2C0->MRDR & 0x000000FF);
    if(generate_stop()) return error;
    else return OK;
该函数2020/07/16 通过验证,其余代码,可以在NXP 国外论坛搜索到。
我知道答案 目前已有0人回答
GMT+8, 2026-4-15 17:40 , Processed in 0.075341 second(s), 21 queries , Redis On.
