查看: 6712|回复: 0
[S32] 关于S32K146 bootloader跳转问题
发表于 2020-7-27 15:45:34 | 显示全部楼层 |阅读模式
我的boot   ld链接脚本配置如图
  /* Flash */
  m_interrupts          (RX)  : ORIGIN = 0x00000000, LENGTH = 0x00000400
  m_flash_config        (RX)  : ORIGIN = 0x00000400, LENGTH = 0x00000010
  m_text                (RX)  : ORIGIN = 0x00000410, LENGTH = 0x00019000
app
  /* Flash */
  m_interrupts          (RX)  : ORIGIN = 0x0001A000, LENGTH = 0x00000400
  m_flash_config        (RX)  : ORIGIN = 0x0001A400, LENGTH = 0x00000010
  m_text                (RX)  : ORIGIN = 0x0001A410, LENGTH = 0x0007FBF0
跳转函数
图一
   __asm volatile ("cpsid i":::"memory");
     /* Jump to user application */
     jumpaddr = *(uint32_t*) (appxaddr + 4);
     jumptoapp = (pfunction) jumpaddr;
     jumptoapp();
图二 搬的官方历程
void JumpToUserApplication( unsigned int userSP,  unsigned int userStartup)
    /* Check if Entry address is erased and return if erased */
    if(userSP == 0xFFFFFFFF){
        return;
    /* Set up stack pointer */
    __asm("msr msp, r0");
    __asm("msr psp, r0");
    /* Relocate vector table */
    S32_SCB->VTOR = (uint32_t)FLASH_APP_ADDR;
    /* Jump to application PC (r1) */
    __asm("mov pc, r1");
这两种跳转都尝试过  跳转过去app无法正常运行,会进入HardFault_Handler中断
不知道什么问题 噗
我知道答案 目前已有0人回答
GMT+8, 2026-4-17 02:44 , Processed in 0.078602 second(s), 22 queries , Redis On.
