查看: 5087|回复: 2
[原创] 【经验分享】自制ble服务
发表于 2020-9-2 10:41:12 | 显示全部楼层 |阅读模式
找一个例程,比如health_t例程
设备:KW36
手机应用:nrf connect
1 在gatt_uuid128.h 自定义UUID,使用宏定义UUID128(服务名/特征名,128位uuid)
UUID128(uuid_service_adcTst,0x01,0x03,0x07,0x09,0x0b,0x0d,0x0f,0x02,0x03,0x01,0x04,0x43,0x23,0x32,0x33,0x78)
UUID128(uuid_characteristic_adcTst,0x01,0x03,0x07,0x0a,0x0b,0x0d,0x0f,0x02,0x04,0x01,0x04,0x93,0x23,0x32,0x33,0x79)
名字+16字节uuid
2 gatt_db.h定义服务
PRIMARY_SERVICE_UUID128(service_device_adc,uuid_service_adcTst)
CHARACTERISTIC_UUID128(char_adc_value,uuid_characteristic_adcTst,(gGattCharPropRead_c| gGattCharPropNotify_c | gGattCharPropWrite_c))
       VALUE_UUID128(value_adc_value, uuid_characteristic_adcTst,gPermissionFlagReadable_c | gPermissionFlagWritable_c ,1, 0x00)
       CCCD(cccd_adc)
3 在profiles下创建一个新文件夹,放自定义服务,在文件夹下放两个文件,xxx_interface.h和xxx_services.c
4 在interface.h自定义数据结构,类似
typedef struct psConfig_tag
    uint16_t    serviceHandle;                /*!<Service handle */
    uint8_t    potentiometerValue;           /*!<Input report field */
} psConfig_t;
声明两个开启服务的函数,类似
bleResult_t Ps_Start(psConfig_t *pServiceConfig);
bleResult_t
Ps_Stop(psConfig_t *pServiceConfig);
两个注册客户端注册服务,类似
bleResult_t Ps_Subscribe(deviceId_t clientDeviceId);
bleResult_t
Ps_Unsubscribe();
用于读写更新特征的函数,类似
bleResult_t Ps_RecordPotentiometerMeasurement (uint16_t serviceHandle, uint8_t newPotentiometerValue);
5 service.c要实现
一个静态变量用于存储ID
static deviceId_t mPs_SubscribedClientId;
实现以上函数
bleResult_t Ps_Start (psConfig_t *pServiceConfig)
/* Clear subscibed clien ID (if any) */
= gInvalidDeviceId_c;
/* Set the initial value defined in pServiceConfig to the characteristic values */
return Ps_RecordPotentiometerMeasurement (pServiceConfig->serviceHandle,
                                             pServiceConfig
->potentiometerValue);
bleResult_t Ps_Stop
/* Unsubscribe current client */
return Ps_Unsubscribe();
bleResult_t
Ps_Subscribe(deviceId_t deviceId)
/* Subscribe a new client to this service */
= deviceId;
return gBleSuccess_c;
bleResult_t
Ps_Unsubscribe()
/* Clear current subscribed client ID */
这函数的 特征uuid变量是定义在uuid128里的,但是我实验时候发现,直接填进函数里会报未定义错误,后来使用了extern解决了问题
    uint16_t  handle
    bleResult_t result
/* Get handle of Potentiometer characteristic */
    result
= GattDb_FindCharValueHandleInService(serviceHandle,
        gBleUuidType128_c
, (bleUuid_t*)&potentiometerCharacteristicUuid128, &handle);
if (result != gBleSuccess_c)
return result;
/* Update characteristic value */
    result
= GattDb_WriteAttribute(handle, sizeof(uint8_t), (uint8_t*)&newPotentiometerValue);
return result;
Ps_SendPotentiometerMeasurementNotification(handle);
实现发送提醒的函数
static void Ps_SendPotentiometerMeasurementNotification
  uint16_t handle
    uint16_t  hCccd
    bool_t isNotificationActive
/* Get handle of CCCD */
if (GattDb_FindCccdHandleForCharValueHandle(handle, &hCccd) != gBleSuccess_c)
return;
if (gBleSuccess_c == Gap_CheckNotificationStatus
(mPs_SubscribedClientId, hCccd, &isNotificationActive) &&
        TRUE
== isNotificationActive)
GattServer_SendNotification(mPs_SubscribedClientId, handle);
6 在文件里,放置服务数据的地方,定义自定义的数据,类似
       StaticpsConfig_t psServiceConfig = {service_potentiometer,0};
这个service_potentiometer就是UUID定义的主服务
7 在BleApp_Config() 里开启服务
Ps_Start(&psServiceConfig);
8 在BleApp_ConnectionCallback,在gConnEvtConnected_c这个状态下,调用
Ps_Subscribe(peerDeviceId); 注册ID,开启对应服务定时器,实现定时器回调函数
9 如果需要处理,Notifications和写请求
在BleApp_GattServerCallback里的ccd写情况下,开启定时器,定时发送数据
写请求则要先用GattServer_RegisterHandlesForWriteNotifications来注册函数uint16_t notifiableHandleArray[] = {value_led_control, value_buzzer, value_accelerometer_scale, value_controller_command, value_controller_configuration};
    uint8_t notifiableHandleCount
= sizeof(notifiableHandleArray)/2;
    bleResult_t initializationResult
= GattServer_RegisterHandlesForWriteNotifications(notifiableHandleCount, (uint16_t*)&notifiableHandleArray[0]);
在BleApp_GattServerCallback里的属性写情况下,
同时要用GattServer_RegisterHandlesForWriteNotifications来注册句柄,cpHandles放了VALUE值的句柄,需要在里面添加VALUE对应的第一个名字
实现sendAttWrite…
static void BleApp_SendAttWriteResponse (deviceId_t* pDeviceId, gattServerEvent_t* pGattServerEvent, bleResult_t* pResult){
  attErrorCode_t attErrorCode
// Determine response to send (OK or Error)
if(*pResult == gBleSuccess_c)
    attErrorCode
= gAttErrCodeNoError_c;
else{
    attErrorCode
= (attErrorCode_t)(*pResult & 0x00FF);
// Send response to client
GattServer_SendAttributeWrittenStatus(*pDeviceId, pGattServerEvent->eventData.attributeWrittenEvent.handle, attErrorCode);
按下nrf connect里的notify按钮则会触发cccd写事件 gEvtCharacteristicCccdWritten_c
启用配对验证在app_preinclude.h定义为1
/*! Enable/disable use of bondingcapability */
#define gAppUseBonding_d   1
/*! Enable/disable use of pairing procedure*/
#define gAppUsePairing_d   1
密钥定义
#define gPasskeyValue_c                999999
参考链接custom profile
SELF_Profile.pdf (226.83 KB, 下载次数: 11)
  • 签到天数: 220 天
    发表于 2020-9-2 12:21:05 | 显示全部楼层
    学习了!
  • 签到天数: 206 天
    发表于 2020-10-29 11:16:22 | 显示全部楼层
    双击666
    GMT+8, 2026-2-22 03:13 , Processed in 0.113962 second(s), 22 queries , Redis On.
