查看: 6838|回复: 2
[求助] NXP S32DS
发表于 2020-10-14 09:56:11 | 显示全部楼层 |阅读模式
请问,
大家有没有遇到过下面LOG中这样错误?请指教,感谢!
开发环境:NXP S32DS
仿真器:PE micro,Multilink universal
MCU: KEAZ128
一直用的很好的,有一天download时就遇到了下面的问题,期间只是download了一个NXP官网关于的LIN Demo code安装了一下。重新安装了S32DS和PE,都没有效果,目前只有一块板子,无法确定是不是硬件的问题。但是从log上看好像是PE的问题。
Connection from "127.0.0.1" via 127.0.0.1
PE-ERROR: Warning. Can't read registers while part is running.
Telnet server running on 127.0.0.1:51794
Copyright 2012 P&E Microcomputer Systems,Inc.
Command Line :C:\NXP\S32DS_ARM_v2.0\eclipse\plugins\com.pemicro.debug.gdbjtag.pne_3.1.1.201708081924\win32\pegdbserver_console -device=NXP_KEx_S9KEAZ128*** -startserver -singlesession -serverport=7224 -gdbmiport=6224 -interface=OPENSDA -speed=5000 -port=U?
CMD>RE
Initializing.
Target has been RESET and is active.
CMD>CM C:\NXP\S32DS_ARM_v2.0\eclipse\plugins\com.pemicro.debug.gdbjtag.pne_3.1.1.201708081924\win32\gdi\P&E\support***_ARM\NXP\KEx\freescale_s9keaz128m4_pflash.arp
Initializing.
Initialized.
;version 1.03, 06/02/2014, Copyright 2014 P&E Microcomputer Systems, Inc. All rights reserved. www.pemicro.com [ke_128k_pflash_ftmre_m0]
;device freescale, s9keaz128m4, pflash
;begin_cs device=$00000000, length=$00020000, ram=$20000000
Loading programming algorithm ...
WARNING - Selected .ARP file has been modified. CRC16 = $2AD1
Done.
CMD>VC
Command is inactive for this .ARP file.
CMD>EM
Error Erasing flash of device
Error occured during Flash programming.
我知道答案 目前已有2人回答
发表于 2020-10-15 16:35:31 | 显示全部楼层
1.你看看是不是把相关的swd引脚给配置成其他功能了。2.你试试找个外部的jlink,看看是不是芯片锁住了。如果是第一个原因,按住reset,然后再点击IDE的download。如果是第二个原因,可以用jlink解锁。
GMT+8, 2026-4-9 01:39 , Processed in 0.077487 second(s), 21 queries , Redis On.
