查看: 6265|回复: 2
[求助] 求助万能大佬MK22FA12的FLASH到底怎么擦除呀总是失败!内含...
发表于 2020-10-23 13:37:50 | 显示全部楼层 |阅读模式
//**********定义flash配置全局变量**********//
static flash_config_t g_stflash_config;
//**********定义flash工作信息结构体**********//
stFlashWorkInfo g_stFlashWorkInfo;
unsigned int pflashBlockBase = 0;
unsigned int pflashTotalSize = 0;
unsigned int pflashSectorSize = 0;
            *函数名称:void Flash_Init( void )
            *函数功能:Flash初始化函数
            *入口参数:无
            *出口参数:无
            *备注:无
flash_security_state_t l_stflash_security_state = kFLASH_SecurityStateNotSecure;
memset( &g_stflash_config, 0, sizeof( flash_config_t ) );
if( kStatus_FLASH_Success != FLASH_Init( &g_stflash_config ) )
  printf("flash init failed !\r\n");
  g_stFlashWorkInfo.m_enFlashState = FLASH_ABNORMAL;
else
  FLASH_GetProperty(&g_stflash_config, kFLASH_PropertyPflashBlockBaseAddr, &pflashBlockBase);
    FLASH_GetProperty(&g_stflash_config, kFLASH_PropertyPflashTotalSize, &pflashTotalSize);
    FLASH_GetProperty(&g_stflash_config, kFLASH_PropertyPflashSectorSize, &pflashSectorSize);
  if( kStatus_FLASH_Success != FLASH_GetSecurityState( &g_stflash_config, &l_stflash_security_state ) )
   printf("flash get security failed !\r\n");
  else
   if ( kFLASH_SecurityStateNotSecure != l_stflash_security_state )
    printf("flash is secure !\r\n");
   else
    printf("flash init ok\r\n");
    g_stFlashWorkInfo.m_enFlashState = FLASH_NORMAL;
            *函数名称:void Flash_Erase_Data( void )
            *函数功能:Flash擦除数据函数
            *入口参数:数据起始地址(l_u32StartAdd),数据缓存指针(*l_pu32DataBufferStartAdd),数据数量(l_u8DataCnt)
            *出口参数:无
            *备注:无
void Flash_Erase_Data( unsigned int l_u32StartAdd, unsigned int *l_pu32DataBufferStartAdd, unsigned char l_u8DataCnt )
if( FLASH_NORMAL == Get_Flash_State() )
  else
   else
    l_u32StartAdd = pflashBlockBase + (pflashTotalSize - (1U * pflashSectorSize * 2));
    if( kStatus_FLASH_Success != FLASH_Erase(&g_stflash_config, l_u32StartAdd, l_u8DataCnt, kFLASH_ApiEraseKey) )
     printf("flash eraser add 0X%x failed \r\n", l_u32StartAdd);
    else
     if( kStatus_FLASH_Success != FLASH_VerifyErase(&g_stflash_config, l_u32StartAdd, l_u8DataCnt, kFLASH_MarginValueUser) )
      printf("flash verify eraser add 0X%x failed \r\n", l_u32StartAdd);
     else
      printf("flash verify eraser add 0X%x ok \r\n", l_u32StartAdd);
  else
  printf( "flash state err before eraser 0X%x \r\n", l_u32StartAdd );
我知道答案 目前已有2人回答
 楼主| 发表于 2020-10-23 13:53:58 | 显示全部楼层
        flash_security_state_t l_stflash_security_state;
                else
                        else
                                else
                                        else
  else
更正一下擦除程序,是这个 总是打印printf("flash eraser add 0X%x failed \r\n", l_u32StartAdd);
发表于 2020-10-29 10:07:27 | 显示全部楼层
你试试sdk的例程,先排除芯片问题。然后debug一下,看看get_index的问题还是首地址的问题,或者是不是user key的问题。一般这个问题都是解锁没有成功导致的删除错误。
GMT+8, 2026-3-16 01:35 , Processed in 0.095486 second(s), 22 queries , Redis On.
