在线时间1 小时
UID3466130
注册时间2020-11-2
NXP金币0
TA的每日心情 | 郁闷 2020-11-3 09:20 |
- 11
- 2020-11-6
Mfgtools烧写失败:提示实在解压文件系统出现错误,开发板上电的时候uboot,linux内核都可以正常启动,只是到了挂载文件系统时;提示找到不到 init程序:
串口输出的烧写信息提示:pid is 2833, UTP: executing "tar --numeric-owner -zxv -C /mnt/mmcblk0p1"
UTP: sending Success to kernel for command pipe tar --numeric-owner -zxv -C /mnt/mmcblk0p1.
bin/
bin/false
bin/addgroup
bin/linux64
bin/gzip
bin/ps
lib/modules/
lib/modules/3.0.8-EmbedSky/
lib/modules/3.0.8-EmbedSky/modules.dep.bb
lib/modules/3.0.8-EmbedSky/kernel/
lib/modules/3.0.8-EmbedSky/kernel/drivers/
lib/modules/3.0.8-EmbedSky/kernel/drivers/net/
lib/modules/3.0.8-EmbedSky/kernel/drivers/net/wireless/
lib/modules/3.0.8-EmbedSky/kernel/drivers/net/wireless/rt5370sta.ko
tar: invalid tar magic
g_file_storage gadget: high speed config #1
烧写emmc时,在解压文件系统时出现错误
开发板上电emmc启动:
MMC read: dev # 3, block # 2048, count 12288 ... 12288 blocks read: OK
## Booting kernel from Legacy Image at 10800000 ...
Image Name: Linux-3.0.35
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 4512432 Bytes = 4.3 MB
Load Address: 10008000
Entry Point: 10008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Initializing cgroup subsys cpu
Linux version 3.0.35 (lxs@lxs-ThinkPad-X240) (gcc version 4.7.2 20120910 (prerelease) (crosstool-NG linaro-1.13.1-2012.09-20120921 - Linaro GCC 2012.09) ) #37 SMP PREEMPT Wed May 16 09:52:35 CST 2018
CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: Freescale i.MX 6Quad/DualLite/Solo Sabre-SD Board
Ignoring unrecognised tag 0x54410008
mmcblk0boot1: unknown partition table
DVFS driver module loaded
drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
mmcblk0boot0: unknown partition table
EXT3-fs: barriers not enabled
kjournald starting. Commit interval 5 seconds
EXT3-fs (mmcblk0p1): using internal journal
EXT3-fs (mmcblk0p1): recovery complete
EXT3-fs (mmcblk0p1): mounted filesystem with writeback data mode
VFS: Mounted root (ext3 filesystem) on device 179:1.
Freeing init memory: 228K
Kernel panic - not syncing: No init found. Try passing init= option to kernel. See Linux Documentation/init.txt for guidance.
[<c0639c28>] (panic+0x74/0x18c) from [<c063993c>] (init_post+0xa0/0xc4)
[<c063993c>] (init_post+0xa0/0xc4) from [<c0008a18>] (kernel_init+0x10c/0x13c)
[<c0008a18>] (kernel_init+0x10c/0x13c) from [<c0048a88>] (kernel_thread_exit+0x0/0x8)
CPU0: stopping
[<c004f9fc>] (unwind_backtrace+0x0/0x138) from [<c00413a8>] (do_IPI+0x1d4/0x208)
[<c00413a8>] (do_IPI+0x1d4/0x208) from [<c004738c>] (__irq_svc+0x4c/0xe8)
Exception stack(0xc0861f68 to 0xc0861fb0)
1f60: c08da8a0 80000093 00000001 00000000 c0860000 c08d3504
1f80: c06438d0 c087dbc4 1000406a 412fc09a 00000000 00000000 00000000 c0861fb0
1fa0: c0057b28 c0048ae8 40000013 ffffffff
[<c004738c>] (__irq_svc+0x4c/0xe8) from [<c0048ae8>] (default_idle+0x24/0x28)
[<c0048ae8>] (default_idle+0x24/0x28) from [<c0048df8>] (cpu_idle+0xc8/0x108)
[<c0048df8>] (cpu_idle+0xc8/0x108) from [<c00088bc>] (start_kernel+0x29c/0x2ec)
[<c00088bc>] (start_kernel+0x29c/0x2ec) from [<10008040>] (0x10008040)
CPU3: stopping
