查看: 3054|回复: 1
[求助] IMX8MM wifi可以连上,提示“已连接,但无法访问互联网”
    郁闷
    2020-11-6 10:15
    发表于 2020-11-5 15:41:19 | 显示全部楼层 |阅读模式
          我用的芯片是IMX8M mini ,  WIFI/BT二合一模块用的是AP6255,现在的问题是我WIFI可以连上也可以上网,但是wifi界面提示“已连接,但无法访问互联网”,各位大神指导一下
      串口打印如下:
    01-15 05:17:53.037  3525  3525 I wpa_supplicant: wlan0: Associated with fc:d7:33:bf:0f:ec
    01-15 05:17:53.037  3525  3525 I wpa_supplicant: wlan0: WPA: RX message 1 of 4-Way Handshake from fc:d7:33:bf:0f:ec (ver=2)
    01-15 05:17:53.037  3525  3525 I wpa_supplicant: wlan0: WPA: Sending EAPOL-Key 2/4
    01-15 05:17:53.037  3525  3525 I wpa_supplicant: wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
    01-15 05:17:53.039  3228  3253 I EthernetTracker: interfaceLinkStateChanged, iface: wlan0, up: true
    01-15 05:17:53.041  3228  3253 I EthernetTracker: interfaceLinkStateChanged, iface: wlan0, up: true
    01-15 05:17:53.042  4085  4085 I ==WIFIChangeListenerReceiver==: >>>action:android.net.wifi.STATE_CHANGE
    01-15 05:17:53.042  4085  4085 I ==WIFIChangeListenerReceiver==: wifi[NETWORK_STATE_CHANGED_ACTION] isConnected:false
    01-15 05:17:53.043  3228  3253 I EthernetTracker: interfaceLinkStateChanged, iface: wlan0, up: true
    01-15 05:17:53.044  3525  3525 I wpa_supplicant: wlan0: WPA: RX message 3 of 4-Way Handshake from fc:d7:33:bf:0f:ec (ver=2)
    01-15 05:17:53.044  3525  3525 I wpa_supplicant: wlan0: WPA: Sending EAPOL-Key 4/4
    01-15 05:17:53.045  3228  3253 I EthernetTracker: interfaceLinkStateChanged, iface: wlan0, up: true
    01-15 05:17:53.046  3615  3615 D WifiSettings: onAccessPointChanged (singular) callback initiated
    01-15 05:17:53.048  3525  3525 I wpa_supplicant: wlan0: WPA: Key negotiation completed with fc:d7:33:bf:0f:ec [PTK=CCMP GTK=CCMP]
    01-15 05:17:53.048  3525  3525 I wpa_supplicant: wlan0: CTRL-EVENT-CONNECTED - Connection to fc:d7:33:bf:0f:ec completed [id=0 id_str=%7B%22configKey%22%3A%22%5C%22youjian_wifi%5C%22WPA_PSK%22%2C%22creatorUid%22%3A%221000%22%7D]
    01-15 05:17:53.049  3615  3615 D WifiSettings: onAccessPointsChanged (WifiTracker) callback initiated
    01-15 05:17:53.050  3228  3344 E SupplicantStaIfaceHal: ISupplicantStaIface.getMacAddress failed: {.code = FAILURE_UNKNOWN, .debugMessage = }
    01-15 05:17:53.052  3228  3253 I EthernetTracker: interfaceLinkStateChanged, iface: wlan0, up: true
    01-15 05:17:53.053  4085  4085 I ==WIFIChangeListenerReceiver==: >>>action:android.net.wifi.STATE_CHANGE
    01-15 05:17:53.053  4085  4085 I ==WIFIChangeListenerReceiver==: wifi[NETWORK_STATE_CHANGED_ACTION] isConnected:false
    01-15 05:17:53.056  4085  4085 I ==WIFIChangeListenerReceiver==: >>>action:android.net.wifi.STATE_CHANGE
    01-15 05:17:53.056  3228  3344 D ConnectivityService: registerNetworkAgent NetworkAgentInfo{ ni{[type: WIFI[], state: CONNECTING/CONNECTING, reason: (unspecified), extra: (none), failover: false, available: true, roaming: false]}  network{101}  nethandle{437197393933}  lp{{LinkAddresses: []  Routes: [] DnsAddresses: [] UsePrivateDns: false PrivateDnsServerName: null Domains: null MTU: 0}}  nc{[ Transports: WIFI Capabilities: NOT_METERED&INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN&NOT_ROAMING&FOREGROUND&NOT_CONGESTED&NOT_SUSPENDED Unwanted:  LinkUpBandwidth>=1048576Kbps LinkDnBandwidth>=1048576Kbps SSID: "youjian_wifi"]}  Score{20}  everValidated{false}  lastValidated{false}  created{false} lingering{false} explicitlySelected{false} acceptUnvalidated{false} everCaptivePortalDetected{false} lastCaptivePortalDetected{false} clat{null} }
    01-15 05:17:53.056  4085  4085 I ==WIFIChangeListenerReceiver==: wifi[NETWORK_STATE_CHANGED_ACTION] isConnected:false
    01-15 05:17:53.057  3228  3347 D ConnectivityService: NetworkAgentInfo [WIFI () - 101] EVENT_NETWORK_INFO_CHANGED, going from null to CONNECTING
    01-15 05:17:53.060  4085  4085 I ==WIFIChangeListenerReceiver==: >>>action:android.net.wifi.STATE_CHANGE
    01-15 05:17:53.060  4085  4085 I ==WIFIChangeListenerReceiver==: wifi[NETWORK_STATE_CHANGED_ACTION] isConnected:false
    01-15 05:17:53.061  3228  3344 E SupplicantStaIfaceHal: ISupplicantStaIface.setBtCoexistenceMode failed: {.code = FAILURE_UNKNOWN, .debugMessage = }
    01-15 05:17:53.063  3102  3102 E WifiHAL : wifi_get_packet_filter_capabilities: requestResponse() error: -3
    01-15 05:17:53.063  3102  3102 I WifiHAL : Packet filtering is not supprted
    01-15 05:17:53.067  3102  3102 E WifiHAL : wifi_get_link_stats: requestResponse Error:-3
    01-15 05:17:53.067  3228  3344 E WifiVendorHal: getWifiLinkLayerStats(l.937) failed {.code = ERROR_NOT_SUPPORTED, .description = }
    01-15 05:17:53.069  3102  3102 E WifiHAL : wifi_get_link_stats: requestResponse Error:-3
    01-15 05:17:53.070  3615  3615 D WifiSettings: onAccessPointChanged (singular) callback initiated
    01-15 05:17:53.070  3615  3615 I chatty  : uid=1000(system) com.android.settings identical 4 lines
    01-15 05:17:53.070  3228  3344 E WifiVendorHal: getWifiLinkLayerStats(l.937) failed {.code = ERROR_NOT_SUPPORTED, .description = }
    01-15 05:17:53.075  3615  3615 I chatty  : uid=1000(system) com.android.settings identical 3 lines
    01-15 05:17:53.075  3615  3615 D WifiSettings: onAccessPointChanged (singular) callback initiated
    01-15 05:17:53.076  3615  3615 D WifiSettings: onAccessPointsChanged (WifiTracker) callback initiated
    01-15 05:17:53.095  3228  3347 D ConnectivityService: NetworkAgentInfo [WIFI () - 101] EVENT_NETWORK_INFO_CHANGED, going from CONNECTING to CONNECTING
    01-15 05:17:53.098  3228  3344 E WifiVendorHal: configureNeighborDiscoveryOffload(l.2491) failed {.code = ERROR_NOT_SUPPORTED, .description = }
    01-15 05:17:53.099  3228  3344 E SupplicantStaIfaceHal: ISupplicantStaIface.stopRxFilter failed: {.code = FAILURE_UNKNOWN, .debugMessage = }
    01-15 05:17:53.127  3228  5368 D DhcpClient: Receive thread started
    01-15 05:17:53.128  3228  3344 E SupplicantStaIfaceHal: ISupplicantStaIface.setBtCoexistenceMode failed: {.code = FAILURE_UNKNOWN, .debugMessage = }
    01-15 05:17:53.129  3615  3615 D WifiSettings: onAccessPointChanged (singular) callback initiated
    01-15 05:17:53.129  3615  3615 D WifiSettings: onAccessPointsChanged (WifiTracker) callback initiated
    01-15 05:17:53.129  3615  3615 I chatty  : uid=1000(system) com.android.settings identical 9 lines
    01-15 05:17:53.130  3615  3615 D WifiSettings: onAccessPointsChanged (WifiTracker) callback initiated
    01-15 05:17:53.130  3615  3615 D WifiSettings: onAccessPointChanged (singular) callback initiated
    01-15 05:17:53.131  3228  3344 E SupplicantStaIfaceHal: ISupplicantStaIface.setSuspendModeEnabled failed: {.code = FAILURE_UNKNOWN, .debugMessage = }
    01-15 05:17:53.131  3615  3615 D WifiSettings: onAccessPointChanged (singular) callback initiated
    01-15 05:17:53.131  3615  3615 I chatty  : uid=1000(system) com.android.settings identical 9 lines
    01-15 05:17:53.131  3615  3615 D WifiSettings: onAccessPointsChanged (WifiTracker) callback initiated
    01-15 05:17:53.132  3615  3615 D WifiSettings: onAccessPointChanged (singular) callback initiated
    01-15 05:17:53.132  3615  3615 D WifiSettings: onAccessPointsChanged (WifiTracker) callback initiated
    01-15 05:17:53.140  3102  3102 E WifiHAL : wifi_get_link_stats: requestResponse Error:-3
    01-15 05:17:53.141  3228  3344 E WifiVendorHal: getWifiLinkLayerStats(l.937) failed {.code = ERROR_NOT_SUPPORTED, .description = }
    我知道答案 目前已有1人回答
    发表于 2020-11-30 11:31:03 | 显示全部楼层
    请问现在wifi可以正常工作了吗?你这里使用的是哪个版本的BSP?
    GMT+8, 2025-10-26 17:42 , Processed in 0.090285 second(s), 23 queries , MemCache On.
