查看: 2135|回复: 3
[求助] MKV30如何使用ADC的差分模式
    无聊
    2021-1-15 10:56
  • 签到天数: 39 天
    发表于 2020-11-12 15:56:42 | 显示全部楼层 |阅读模式
    MKV30这款芯片支不支持ADC的差分输入,例程中没有,如果有,如何配置成差分模式呢
    https://www.nxpic.org.cn/module/ ... =%E5%B7%AE%E5%88%86
    发表于 2020-11-13 08:51:46 | 显示全部楼层
    无聊
    2021-1-15 10:56
  • 签到天数: 39 天
     楼主| 发表于 2020-11-13 13:12:35 | 显示全部楼层
    小恩GG 发表于 2020-11-13 08:51
    https://www.nxpic.org.cn/module/forum/forum.php?mod=viewthread&tid=614978&highlight=%E5%B7%AE%E5%88% ...
    借鉴了链接的代码。和我的没啥区别,但是没有效果。咋回事
    #include "ADC.h"
    * BOARD_InitPeripherals functional group
    #define ADC16_RESULT_REG_ADDR    0x4003b010U
    #define DEMO_ADC16_SAMPLE_COUNT 16U /* The ADC16 sample count. */
    volatile bool g_Transfer_Done = false; /* DMA transfer completion flag. */
    edma_transfer_config_t g_transferConfig;
    uint32_t g_adc16SampleDataArray[DEMO_ADC16_SAMPLE_COUNT];
    * DMA initialization code
    static void Edma_Callback(edma_handle_t *handle, void *userData, bool transferDone, uint32_t tcds)
        /* Clear Edma interrupt flag. */
        EDMA_ClearChannelStatusFlags(DMA_DMA_BASEADDR, DMA_CH1_DMA_CHANNEL, kEDMA_InterruptFlag);
        /* Setup transfer */
        EDMA_PrepareTransfer(&g_transferConfig, (void *)ADC16_RESULT_REG_ADDR, sizeof(uint32_t),
                             (void *)g_adc16SampleDataArray, sizeof(uint32_t), sizeof(uint32_t),
                             sizeof(g_adc16SampleDataArray), kEDMA_PeripheralToMemory);
        EDMA_SetTransferConfig(DMA_DMA_BASEADDR, DMA_CH1_DMA_CHANNEL, &g_transferConfig, NULL);
        /* Enable transfer. */
        EDMA_StartTransfer(&DMA_CH1_Handle);
        g_Transfer_Done = true;
    const edma_config_t DMA_config = {
      .enableContinuousLinkMode = false,
      .enableHaltOnError = false,
      .enableRoundRobinArbitration = false,
      .enableDebugMode = false
    edma_handle_t DMA_CH1_Handle;
    edma_handle_t DMA_CH2_Handle;
    void ADC_DMA_init(void) {
      /* Channel CH1 initialization */
      /* Set the source kDmaRequestMux0ADC0 request in the DMAMUX */
      DMAMUX_SetSource(DMA_DMAMUX_BASEADDR, DMA_CH1_DMA_CHANNEL, DMA_CH1_DMA_REQUEST);
      /* Enable the channel 1 in the DMAMUX */
      DMAMUX_EnableChannel(DMA_DMAMUX_BASEADDR, DMA_CH1_DMA_CHANNEL);
      /* Create the eDMA DMA_CH1_Handle handle */
      EDMA_CreateHandle(&DMA_CH1_Handle, DMA_DMA_BASEADDR, DMA_CH1_DMA_CHANNEL);
      /* Channel CH2 initialization */
      /* Set the source kDmaRequestMux0ADC1 request in the DMAMUX */
      DMAMUX_SetSource(DMA_DMAMUX_BASEADDR, DMA_CH2_DMA_CHANNEL, DMA_CH2_DMA_REQUEST);
      /* Enable the channel 2 in the DMAMUX */
      DMAMUX_EnableChannel(DMA_DMAMUX_BASEADDR, DMA_CH2_DMA_CHANNEL);
      /* Create the eDMA DMA_CH2_Handle handle */
      EDMA_CreateHandle(&DMA_CH2_Handle, DMA_DMA_BASEADDR, DMA_CH2_DMA_CHANNEL);
    void EDMA_Configuration(void)
            edma_config_t userConfig;
        EDMA_GetDefaultConfig(&userConfig);
        EDMA_Init(DMA_DMA_BASEADDR, &DMA_config);
        EDMA_SetCallback(&DMA_CH1_Handle, Edma_Callback, NULL);
        EDMA_SubmitTransfer(&DMA_CH1_Handle, &g_transferConfig);
        /* Enable interrupt when transfer is done. */
        EDMA_EnableChannelInterrupts(DMA_DMA_BASEADDR, DMA_CH1_DMA_CHANNEL, kEDMA_MajorInterruptEnable);
    #if defined(FSL_FEATURE_EDMA_ASYNCHRO_REQUEST_CHANNEL_COUNT) && FSL_FEATURE_EDMA_ASYNCHRO_REQUEST_CHANNEL_COUNT
        /* Enable async DMA request. */
        EDMA_EnableAsyncRequest(DMA_DMA_BASEADDR, DMA_CH1_DMA_CHANNEL, true);
    #endif /* FSL_FEATURE_EDMA_ASYNCHRO_REQUEST_CHANNEL_COUNT */
    * ADC0 initialization code
    adc16_channel_config_t ADC0_channelsConfig[1] = {
        .channelNumber = 1U,
        .enableDifferentialConversion = false,
        .enableInterruptOnConversionCompleted = false,
    const adc16_config_t ADC0_config = {
      .referenceVoltageSource = kADC16_ReferenceVoltageSourceVref,
      .clockSource = kADC16_ClockSourceAsynchronousClock,
      .enableAsynchronousClock = true,
      .clockDivider = kADC16_ClockDivider8,
      .resolution = kADC16_ResolutionSE16Bit,
      .longSampleMode = kADC16_LongSampleDisabled,
      .enableHighSpeed = false,
      .enableLowPower = false,
      .enableContinuousConversion = true
    const adc16_channel_mux_mode_t ADC0_muxMode = kADC16_ChannelMuxA;
    const adc16_hardware_average_mode_t ADC0_hardwareAverageMode = kADC16_HardwareAverageCount8;
    void ADC0_init(void) {
      /* Initialize ADC16 converter */
      ADC16_Init(ADC0_PERIPHERAL, &ADC0_config);
      /* Make sure, that software trigger is used */
      ADC16_EnableHardwareTrigger(ADC0_PERIPHERAL, false);
      /* Configure hardware average mode */
      ADC16_SetHardwareAverage(ADC0_PERIPHERAL, ADC0_hardwareAverageMode);
      /* Configure channel multiplexing mode */
      ADC16_SetChannelMuxMode(ADC0_PERIPHERAL, ADC0_muxMode);
      /* Initialize channel */
      ADC16_SetChannelConfig(ADC0_PERIPHERAL, 0U, &ADC0_channelsConfig[0]);
      /* Enable DMA. */
      ADC16_EnableDMA(ADC0_PERIPHERAL, true);
    * ADC1 initialization code
    adc16_channel_config_t ADC1_channelsConfig[1] = {
        .enableDifferentialConversion = true,
    const adc16_config_t ADC1_config = {
      .enableContinuousConversion = false
    const adc16_channel_mux_mode_t ADC1_muxMode = kADC16_ChannelMuxA;
    const adc16_hardware_average_mode_t ADC1_hardwareAverageMode = kADC16_HardwareAverageDisabled;
    void ADC1_init(void) {
      ADC16_Init(ADC1_PERIPHERAL, &ADC1_config);
      ADC16_EnableHardwareTrigger(ADC1_PERIPHERAL, false);
      ADC16_SetHardwareAverage(ADC1_PERIPHERAL, ADC1_hardwareAverageMode);
      ADC16_SetChannelMuxMode(ADC1_PERIPHERAL, ADC1_muxMode);
      ADC16_SetChannelConfig(ADC1_PERIPHERAL, 0U, &ADC1_channelsConfig[0]);
       /* Enable DMA. */
       ADC16_EnableDMA(ADC1_PERIPHERAL, true);
    uint32_t ADC_Value = 0;
    void DifferentialSample_DC(void)
            while (0U == (kADC16_ChannelConversionDoneFlag & ADC16_GetChannelStatusFlags(ADC0, 0)))
            ADC_Value = ADC16_GetChannelConversionValue(ADC0, 0);
            ADC_Value = ADC_Value*3000/4095;
    * Initialization functions
    void ADC_InitPeripherals(void)
      /* Global initialization */
      DMAMUX_Init(DMAMUX);
      EDMA_Configuration();
      /* Initialize components */
      ADC_DMA_init();
      ADC0_init();
      ADC1_init();
            DifferentialSample_DC();
    * BOARD_InitBootPeripherals function
    void ADC_InitBootPeripherals(void)
      ADC_InitPeripherals();
    无聊
    2021-1-15 10:56
  • 签到天数: 39 天
     楼主| 发表于 2020-11-13 15:32:54 | 显示全部楼层
    我现在使用SDK里面的例程移植过来,可以采集出AD,但是16个大小的数组,只有第一个有数据其他都是0
    GMT+8, 2026-4-8 03:05 , Processed in 0.098319 second(s), 26 queries , Redis On.
