查看: 2478|回复: 2
[原创] [原创] LPC55S16板子CAN1发送
  • 签到天数: 1615 天
    连续签到: 3 天
    发表于 2020-11-16 10:46:59 | 显示全部楼层 |阅读模式
        设计的板子是外扩的CAN芯片来实现CAN通信,先来测试下CAN1的发送通信。
       一、硬件电路
        CAN1通信使用到FC3-SPI功能。
        1.1、LPC55S16的SPI3引脚
        1.2、CAN部分电路图
        二、程序部分
        2.1、SPI部分程序
        spi.c
    1. <font size="3"><font size="3">#include "fsl_common.h"
    2. #include "fsl_iocon.h"
    3. #include "pin_mux.h"
    4. #include "fsl_gpio.h"
    5. #include "fsl_debug_console.h"
    6. #include "fsl_power.h"
    7. #include "fsl_spi.h"
    8. #include "spi.h"
    9. spi_master_config_t userConfig = {0};
    10. spi_transfer_t xfer            = {0};
    11. void SPI_InitPins(void)
    12. {
    13.         /* Define the init structure for the output CS pin*/
    14.         gpio_pin_config_t gpio_config = {
    15.                         kGPIO_DigitalOutput,
    16.                         0,
    17.         };
    18.     /* Enables the clock for the I/O controller.: Enable Clock. */
    19.         CLOCK_EnableClock(kCLOCK_Iocon);
    20.         const uint32_t port0_pin2_config = (/* Pin is configured as FC3_TXD_SCL_MISO_WS */
    21.        IOCON_PIO_FUNC1 |
    22.        /* Selects pull-up function */
    23.        IOCON_PIO_MODE_PULLUP |
    24.        /* Standard mode, output slew rate control is enabled */
    25.        IOCON_PIO_SLEW_STANDARD |
    26.        /* Input function is not inverted */
    27.        IOCON_PIO_INV_DI |
    28.        /* Enables digital function */
    29.        IOCON_PIO_DIGITAL_EN |
    30.        /* Open drain is disabled */
    31.        IOCON_PIO_OPENDRAIN_DI);
    32.         /* PORT0 PIN2  is configured as FC3_TXD_SCL_MISO_WS */
    33.         IOCON_PinMuxSet(IOCON, 0U, 2U, port0_pin2_config);
    34.         const uint32_t port0_pin3_config = (/* Pin is configured as FC3_RXD_SDA_MOSI_DATA */
    35.        IOCON_PIO_FUNC1 |
    36.        /* Selects pull-up function */
    37.        IOCON_PIO_MODE_PULLUP |
    38.        /* Standard mode, output slew rate control is enabled */
    39.        IOCON_PIO_SLEW_STANDARD |
    40.        /* Input function is not inverted */
    41.        IOCON_PIO_INV_DI |
    42.        /* Enables digital function */
    43.        IOCON_PIO_DIGITAL_EN |
    44.        /* Open drain is disabled */
    45.        IOCON_PIO_OPENDRAIN_DI);
    46.         /* PORT0 PIN3  is configured as FC3_RXD_SDA_MOSI_DATA */
    47.         IOCON_PinMuxSet(IOCON, 0U, 3U, port0_pin3_config);
    48.         const uint32_t port0_pin6_config = (/* Pin is configured as FC3_SCK */
    49.        IOCON_PIO_FUNC1 |
    50.        /* Selects pull-up function */
    51.        IOCON_PIO_MODE_PULLUP |
    52.        /* Standard mode, output slew rate control is enabled */
    53.        IOCON_PIO_SLEW_STANDARD |
    54.        /* Input function is not inverted */
    55.        IOCON_PIO_INV_DI |
    56.        /* Enables digital function */
    57.        IOCON_PIO_DIGITAL_EN |
    58.        /* Open drain is disabled */
    59.        IOCON_PIO_OPENDRAIN_DI);
    60.         /* PORT0 PIN6 is configured as FC3_SCK */
    61.         IOCON_PinMuxSet(IOCON, 0U, 6U, port0_pin6_config);
    62.         const uint32_t port0_pin4_config = (/* Pin is configured as cs */
    63.        IOCON_PIO_FUNC0 |
    64.        /* Selects pull-up function */
    65.        IOCON_PIO_MODE_PULLUP |
    66.        /* Standard mode, output slew rate control is enabled */
    67.        IOCON_PIO_SLEW_STANDARD |
    68.        /* Input function is not inverted */
    69.        IOCON_PIO_INV_DI |
    70.        /* Enables digital function */
    71.        IOCON_PIO_DIGITAL_EN |
    72.        /* Open drain is disabled */
    73.        IOCON_PIO_OPENDRAIN_DI);
    74.         IOCON_PinMuxSet(IOCON, 0U, 4U, port0_pin4_config);    //CAN1_CS
    75.         GPIO_PortInit(GPIO, 0U);
    76.         GPIO_PinInit(GPIO, 0U, 4U, &gpio_config);
    77. }
    78. void InitSpi(void)
    79. {
    80.         uint32_t sourceClock = 0U;
    81.
    82.         /* attach 12 MHz clock to SPI3 */
    83.         CLOCK_AttachClk(kFRO12M_to_FLEXCOMM3 );
    84.
    85.         /* reset FLEXCOMM for SPI3 */
    86.   RESET_PeripheralReset(kFC3_RST_SHIFT_RSTn);
    87.
    88.         SPI_InitPins();
    89.
    90.         SPI_MasterGetDefaultConfig(&userConfig);
    91.         sourceClock          = EXAMPLE_SPI_MASTER_CLK_FREQ;
    92.         userConfig.sselNum = (spi_ssel_t)EXAMPLE_SPI_SSEL;
    93.         userConfig.sselPol = (spi_spol_t)EXAMPLE_SPI_SPOL;
    94.         userConfig.baudRate_Bps = 500000;
    95.         SPI_MasterInit(EXAMPLE_SPI_MASTER, &userConfig, sourceClock);
    96. }
    97. void spi3_WriteDat(uint8_t dat)
    98. {
    99.         uint8_t srcBuff[2];
    100.         uint8_t destBuff[2];
    101.         srcBuff[0]=dat;
    102.         xfer.txData      = srcBuff;
    103.         xfer.rxData      = destBuff;
    104.         xfer.dataSize    = 1;//sizeof(destBuff);
    105.         xfer.configFlags = kSPI_FrameAssert;// kSPI_FrameDelay;//kSPI_FrameAssert;
    106.         SPI_MasterTransferBlocking(EXAMPLE_SPI_MASTER, &xfer);
    107. }</font></font>
           spi.h
    1. <font size="3"><font size="3">#ifndef __SPI_H_
    2. #define __SPI_H_
    3. #include "stdint.h"
    4. /*******************************************************************************
    5. * Definitions
    6. ******************************************************************************/
    7. #define EXAMPLE_SPI_MASTER          SPI3
    8. #define EXAMPLE_SPI_MASTER_IRQ      FLEXCOMM3_IRQn
    9. #define EXAMPLE_SPI_MASTER_CLK_SRC  kCLOCK_Flexcomm3
    10. #define EXAMPLE_SPI_MASTER_CLK_FREQ CLOCK_GetFlexCommClkFreq(3U)
    11. #define EXAMPLE_SPI_SSEL            1
    12. #define SPI_MASTER_IRQHandler       FLEXCOMM3_IRQHandler
    13. #define EXAMPLE_SPI_SPOL            kSPI_SpolActiveAllLow
    14. void InitSpi(void);
    15. void spi3_WriteDat(uint8_t dat);
    16. #endif</font></font>
        2.2、CAN部分程序
        mcp2515.c
    1. <font size="3">#include "fsl_common.h"
    4. #include "led.h"
    5. #include "fsl_gpio.h"
    6. #include "mcp2515.h"
    7. #include "spi.h"
    8. void MCP2515_Reset(void)
    9. {
    10.         can1_cs_l();
    11.         spi3_WriteDat(CAN_RESET);
    12.         can1_cs_h();
    13. }
    14. void MCP2515_BitModity(uchar addr, uchar msk, uchar dat)
    15. {
    16.         can1_cs_l();
    17.         spi3_WriteDat(CAN_BIT_MODIFY);
    18.         spi3_WriteDat(addr);
    19.         spi3_WriteDat(msk);
    20.         spi3_WriteDat(dat);
    21.         can1_cs_h();
    22. }
    23. void SPI_WriteByte(uchar adr,uchar dat)
    24. {
    25.         can1_cs_l();
    26.         spi3_WriteDat(CAN_WRITE);
    27.         spi3_WriteDat(adr);
    28.         spi3_WriteDat(dat);
    29.         can1_cs_h();
    30. }
    31. void CAN_Send(uchar *CAN_TX_Buf)
    32. {
    33.
    34.         MCP2515_BitModity(TXB0CTRL,0x08,0x00);
    35.         SPI_WriteByte(TXB0SIDH,0x55);
    36.         SPI_WriteByte(TXB0SIDL,0x08);
    37.         SPI_WriteByte(TXB0EID8,0x55);
    38.         SPI_WriteByte(TXB0EID0,0x88);
    39.         SPI_WriteByte(TXB0DLC,DLC_8);
    40.         SPI_WriteByte(TXB0D0,CAN_TX_Buf[0]);
    41.         SPI_WriteByte(TXB0D1,CAN_TX_Buf[1]);
    42.         SPI_WriteByte(TXB0D2,CAN_TX_Buf[2]);
    43.         SPI_WriteByte(TXB0D3,CAN_TX_Buf[3]);
    44.         SPI_WriteByte(TXB0D4,CAN_TX_Buf[4]);
    45.         SPI_WriteByte(TXB0D5,CAN_TX_Buf[5]);
    46.         SPI_WriteByte(TXB0D6,CAN_TX_Buf[6]);
    47.         SPI_WriteByte(TXB0D7,CAN_TX_Buf[7]);
    48.
    49.         can1_cs_l();
    50.         spi3_WriteDat(CAN_RTS | 0x01);
    51.         can1_cs_h();
    52. }
    53. void Init_mcp2515(void)
    54. {
    55.         MCP2515_Reset();
    56.
    57.         MCP2515_BitModity(CANCTRL,0xE0,0x80);
    58.         SPI_WriteByte(CNF1,0x04);         //100k
    59.         SPI_WriteByte(CNF2,0x80|PHSEG1_3TQ|PRSEG_1TQ);
    60.         SPI_WriteByte(CNF3,PHSEG2_3TQ);
    61.          SPI_WriteByte(CANINTF,0x00);
    62.          SPI_WriteByte(CANINTE,0x03);
    63.
    64.         SPI_WriteByte(RXB0CTRL,0x60);
    65.         SPI_WriteByte(RXM0SIDH,0xff);
    66.         SPI_WriteByte(RXM0SIDL,0xff);
    67.         SPI_WriteByte(RXM0EID8,0xff);
    68.         SPI_WriteByte(RXM0EID0,0xff);
    69.         SPI_WriteByte( BFPCTRL, 0 );
    70.         SPI_WriteByte( TXRTSCTRL, 0 );
    71.
    72.         MCP2515_BitModity(CANCTRL,0xE0,0x00);
    73. }
    74. uchar SPI0_ReadByte(uchar adr)
    75. {
    76.         uchar rxdat;
    77.         can1_cs_l();
    78.         spi3_WriteDat(CAN_READ);
    79.         spi3_WriteDat(adr);
    80.         //rxdat=SPI0_READ();
    81.         can1_cs_h();
    82.         return rxdat;
    83. }
    84. </font>
        2.3、主程序
        main.c
    1. <font size="3">int main(void)
    2. {
    3.         uint8_t x=0;
    4.         POWER_SetBodVbatLevel(kPOWER_BodVbatLevel1650mv, kPOWER_BodHystLevel50mv, false);  /* set BOD VBAT level to 1.65V */
    5.         BOARD_BootClockPLL150M();
    6.         InitUart();
    7.         InitLed();
    8.         LCD_Pins_Config();
    9.         if (SysTick_Config(SystemCoreClock / 1000U))
    10.         {
    11.                 while (1)
    12.                 {
    13.                 }
    14.         }
    15.         LED0_OFF();
    16.         LED1_ON();
    17.         InitSpi();
    18.         Init_mcp2515();
    19.         POINT_COLOR=RED;
    20.         while (1)
    21.         {
    22.                 x++;
    23.                 if(x==12)
    24.                 {
    25.                         x=0;
    26.                 }
    27.                 SysTick_DelayTicks(100U);
    28.                 can_rx_buf[0]=0Xff;
    29.                 can_rx_buf[1]=0xaa;
    30.                 can_rx_buf[2]=x;
    31.                 CAN_Send(can_rx_buf);
    32.
    33.         }
    34. }</font>
        三、运行结果
        使用CAN卡接收到板子数据
    5 天前
  • 签到天数: 1555 天
    发表于 2020-11-16 11:20:31 | 显示全部楼层
    楼主 厉害啊!
    羡慕有CAN卡的人啊
    2016-12-2 08:40
  • 签到天数: 3 天
    发表于 2020-11-16 14:27:25 | 显示全部楼层
    厉害了
    GMT+8, 2026-4-2 01:45 , Processed in 0.088499 second(s), 24 queries , Redis On.
