查看: 7662|回复: 4
[求助] 有没有大佬做过MKV30的ADC的DMA差分输入,卡了几天了
    无聊
    2021-1-15 10:56
  • 签到天数: 39 天
    发表于 2020-11-16 14:38:38 | 显示全部楼层 |阅读模式
    结合SDK以及论坛的帖子写了一个MKV30的ADC的DMA差分输入,debug时候发现可以采集到电压,但是DMA的接收缓存数组g_adc16SampleDataArray[16]只有第一个有数据,后面都是空的。我在主函数循环void DifferentialSample_DC(void)这个函数,ADC_Value是有值的。
    小恩GG可以帮一下吗?或者哪里有这个驱动,可以有偿。卡了好几天,最后一步走不下去了
    #include "ADC.h"
    * BOARD_InitPeripherals functional group
    #define ADC16_RESULT_REG_ADDR    0x4003b010U
    #define DEMO_ADC16_SAMPLE_COUNT 16U /* The ADC16 sample count. */
    volatile bool g_Transfer_Done = false; /* DMA transfer completion flag. */
    edma_transfer_config_t g_transferConfig;
    uint32_t g_adc16SampleDataArray[DEMO_ADC16_SAMPLE_COUNT];
    * DMA initialization code
    static void Edma_Callback(edma_handle_t *handle, void *userData, bool transferDone, uint32_t tcds)
        /* Clear Edma interrupt flag. */
        EDMA_ClearChannelStatusFlags(DMA_DMA_BASEADDR, DMA_CH1_DMA_CHANNEL, kEDMA_InterruptFlag);
        /* Setup transfer */
        EDMA_PrepareTransfer(&g_transferConfig, (void *)ADC16_RESULT_REG_ADDR, sizeof(uint32_t),
                             (void *)g_adc16SampleDataArray, sizeof(uint32_t), sizeof(uint32_t),
                             sizeof(g_adc16SampleDataArray), kEDMA_PeripheralToMemory);
        EDMA_SetTransferConfig(DMA_DMA_BASEADDR, DMA_CH1_DMA_CHANNEL, &g_transferConfig, NULL);
        /* Enable transfer. */
        EDMA_StartTransfer(&DMA_CH1_Handle);
        g_Transfer_Done = true;
    const edma_config_t DMA_config = {
      .enableContinuousLinkMode = false,
      .enableHaltOnError = false,
      .enableRoundRobinArbitration = false,
      .enableDebugMode = false
    edma_handle_t DMA_CH1_Handle;
    edma_handle_t DMA_CH2_Handle;
    void ADC_DMA_init(void) {
      /* Channel CH1 initialization */
            DMAMUX_Init(DMAMUX);
      /* Set the source kDmaRequestMux0ADC0 request in the DMAMUX */
      DMAMUX_SetSource(DMA_DMAMUX_BASEADDR, DMA_CH1_DMA_CHANNEL, 40);
      /* Enable the channel 1 in the DMAMUX */
      DMAMUX_EnableChannel(DMA_DMAMUX_BASEADDR, DMA_CH1_DMA_CHANNEL);
      /* Create the eDMA DMA_CH1_Handle handle */
      EDMA_CreateHandle(&DMA_CH1_Handle, DMA_DMA_BASEADDR, DMA_CH1_DMA_CHANNEL);
    void EDMA_Configuration(void)
            edma_config_t userConfig;
        EDMA_GetDefaultConfig(&userConfig);
        EDMA_Init(DMA_DMA_BASEADDR, &userConfig);
        EDMA_SetCallback(&DMA_CH1_Handle, Edma_Callback, NULL);
        EDMA_SubmitTransfer(&DMA_CH1_Handle, &g_transferConfig);
        /* Enable interrupt when transfer is done. */
        EDMA_EnableChannelInterrupts(DMA_DMA_BASEADDR, DMA_CH1_DMA_CHANNEL, kEDMA_MajorInterruptEnable);
    #if defined(FSL_FEATURE_EDMA_ASYNCHRO_REQUEST_CHANNEL_COUNT) && FSL_FEATURE_EDMA_ASYNCHRO_REQUEST_CHANNEL_COUNT
        /* Enable async DMA request. */
        EDMA_EnableAsyncRequest(DMA_DMA_BASEADDR, DMA_CH1_DMA_CHANNEL, true);
    #endif /* FSL_FEATURE_EDMA_ASYNCHRO_REQUEST_CHANNEL_COUNT */
    * ADC0 initialization code
    adc16_channel_config_t ADC0_channelsConfig[1] = {
        .channelNumber = 1U,
        .enableDifferentialConversion = true,
        .enableInterruptOnConversionCompleted = true,
    const adc16_config_t ADC0_config = {
      .referenceVoltageSource = kADC16_ReferenceVoltageSourceVref,
      .clockSource = kADC16_ClockSourceAsynchronousClock,
      .enableAsynchronousClock = true,
      .clockDivider = kADC16_ClockDivider8,
      .resolution = kADC16_ResolutionSE16Bit,
      .longSampleMode = kADC16_LongSampleDisabled,
      .enableHighSpeed = true,
      .enableLowPower = false,
      .enableContinuousConversion = true
    const adc16_channel_mux_mode_t ADC0_muxMode = kADC16_ChannelMuxA;
    const adc16_hardware_average_mode_t ADC0_hardwareAverageMode = kADC16_HardwareAverageCount8;
    void ADC0_init(void) {
      /* Initialize ADC16 converter */
      ADC16_Init(ADC0_PERIPHERAL, &ADC0_config);
      /* Make sure, that software trigger is used */
      ADC16_EnableHardwareTrigger(ADC0_PERIPHERAL, false);
      /* Configure hardware average mode */
      ADC16_SetHardwareAverage(ADC0_PERIPHERAL, ADC0_hardwareAverageMode);
      /* Configure channel multiplexing mode */
      ADC16_SetChannelMuxMode(ADC0_PERIPHERAL, ADC0_muxMode);
      /* Initialize channel */
      ADC16_SetChannelConfig(ADC0_PERIPHERAL, 0U, &ADC0_channelsConfig[0]);
      /* Enable DMA. */
      ADC16_EnableDMA(ADC0_PERIPHERAL, true);
    void ADC_Differential_DC_Channel_Config(void)
            ADC0_channelsConfig[0].channelNumber = 0;
            ADC0_channelsConfig[0].enableDifferentialConversion =true;
            ADC0_channelsConfig[0].enableInterruptOnConversionCompleted = true;
    uint32_t ADC_Value = 0;
           ADC_Differential_DC_Channel_Config();
    //        while (0U == (kADC16_ChannelConversionDoneFlag & ADC16_GetChannelStatusFlags(ADC0, 0)))
            ADC_Value = ADC16_GetChannelConversionValue(ADC0, 0);
            ADC_Value = ADC_Value*3000/4095;
    * Initialization functions
    void ADC_InitPeripherals(void)
            ADC_DMA_init();
      EDMA_Configuration();
      ADC0_init();
    * BOARD_InitBootPeripherals function
    void ADC_InitBootPeripherals(void)
      ADC_InitPeripherals();
    先测试你的edma,能否将一个内存数据转移到另一个内存,用memorytomemory. 然后正常的adc能不能实现dma转移,最后再使用差分。分三步一步一步来。
    发表于 2020-11-17 09:15:01 | 显示全部楼层
    无聊
    2021-1-15 10:56
  • 签到天数: 39 天
     楼主| 发表于 2020-11-17 14:03:42 | 显示全部楼层
    小恩GG 发表于 2020-11-17 09:15
    先测试你的edma,能否将一个内存数据转移到另一个内存,用memorytomemory. 然后正常的adc能不能实现dma转移 ...
    今天一直在调,一直是只有数组的第一个有数据,刚才使用SDK里面的eDMA例程移植了一下,结果还是一样,应该打印01 02 03 04,但是串口只打印出来03.在debug模式下能看到接收数组只有destAddr[0]有一个数据04。到底是什么原因呢?
    无聊
    2021-1-15 10:56
  • 签到天数: 39 天
     楼主| 发表于 2020-11-17 16:48:51 | 显示全部楼层
    此问题已解决,原因是我在写串口DMA的时候因为需要最大速度的串口响应,我将库函数里面的一些代码做了删减。有点呆了
    发表于 2021-12-21 18:23:45 | 显示全部楼层
    鹰宫璞爱惟 发表于 2020-11-17 16:48
    此问题已解决,原因是我在写串口DMA的时候因为需要最大速度的串口响应,我将库函数里面的一些代码做了删减 ...
    兄弟!你是人才!别动库啊   不用的话 直接寄存器,要不然以后出问题都不知道哪里出的
    GMT+8, 2026-4-9 03:20 , Processed in 0.099187 second(s), 29 queries , Redis On.
