查看: 5662|回复: 0
[求助] S32K144 低功耗休眠问题
    发表于 2020-11-17 13:16:57 | 显示全部楼层 |阅读模式
    大家好,
    最近在调试S32K144 的低功耗和唤醒功能,请问有好的程序或者建议使得S32K144 进入VLPS模式吗?我的程序进入相应得指令就老是会复位一次,然后电流才下降;附上我的程序
    void Power_RUN_to_STOP (void)
    #if 0
    /* Set the SLEEPDEEP bit to enable deep sleep mode (STOP) */
            S32_SCB->SCR |= S32_SCB_SCR_SLEEPDEEP_MASK;
    /*select stop mode*/
            SMC->PMCTRL = SMC_PMCTRL_STOPM(0b00);
            SMC->STOPCTRL = SMC_STOPCTRL_STOPO(0b01);
            if(SMC->PMSTAT == 0x01)
                    asm("WFI");
    #else
            /* Disable the JTAG port pins */
            /* Disable Adc Pins */
            PMC->REGSC |= PMC_REGSC_BIASEN(1); // [1] CLKBIASDIS = 1 In VLPS mode, the bias current for SIRC, FIRC, PLL is disabled
            /* Disable the Fosc and Sosc from chip*/
            SCG->FIRCCSR = SCG_FIRCCSR_FIRCEN(0);
            while(SCG->FIRCCSR & (1 << 24));
            SCG->SOSCCSR = SCG_SOSCCSR_SOSCEN(0);
            S32_SCB->SCR |= S32_SCB_SCR_SLEEPDEEP_MASK|0x2; /* allow deep sleep mode0 */
            SMC->PMPROT = SMC_PMPROT_AVLP(1); /* allow very low power mode*/
            SMC->PMCTRL = SMC_PMCTRL_STOPM(2);
                    asm("WFI");
    #endif
    void init_NVIC(void)
            power_cp_wakeup_set();
            INT_SYS_ClearPending(PORTE_IRQn);
            INT_SYS_SetPriority(PORTE_IRQn, 0);
            // PORTE_interrupt
            S32_NVIC-> ICPR [1] = (1 <<(63%32));
            S32_NVIC-> ISER [1] = (1 <<(63%32));
            S32_NVIC-> IP [63] = 0x00;
            //PORTE-> DFER |= (1 << 5);
    void power_set_mode(POWER_SYS_TYPE mod)
        init_NVIC();
        Power_RUN_to_STOP();
    我知道答案 目前已有0人回答
    哎,代码总出bug,签到求保佑!
    GMT+8, 2026-4-8 03:07 , Processed in 0.091502 second(s), 22 queries , Redis On.
