查看: 5399|回复: 0
[原创] LPC55S16板子 -- 外部中断
  • 签到天数: 1615 天
    连续签到: 3 天
    发表于 2020-11-18 17:17:13 | 显示全部楼层 |阅读模式
            这节学习下LPC55S16芯片的外部中断,使用板子上面的开关做测试。
        一、硬件电路
        板子上开关使用到单片机引脚PIO0_15, PIO0_16, PIO0_17。
        二、程序部分
        INT0 -- 上升沿中断
        INT1 -- 下降沿中断
        INT2 --  下降沿中断
        2.1、pint.c
    1. <font size="3">#include "fsl_pint.h"
    2. #include "fsl_inputmux.h"
    3. #include "fsl_debug_console.h"
    4. /*******************************************************************************
    5. * Definitions
    6. ******************************************************************************/
    7. #define KEY0_PIN_INT0_SRC                     kINPUTMUX_GpioPort0Pin15ToPintsel
    8. #define KEY1_PIN_INT1_SRC                     kINPUTMUX_GpioPort0Pin16ToPintsel
    9. #define KEY2_PIN_INT2_SRC                     kINPUTMUX_GpioPort0Pin17ToPintsel
    10. //#define KEY0_PINT_PIN_INT0_SRC                 kINPUTMUX_GpioPort0Pin15ToPintSecsel
    11. void pint_intr_callback(pint_pin_int_t pintr, uint32_t pmatch_status)
    12. {
    13.         if(pintr==kPINT_PinInt0)
    14.         {
    15.                 PRINTF("\r\nPINT Pin key0 Interrupt %d event detected.", pintr);
    16.         }
    17.         if(pintr==kPINT_PinInt1)
    18.         {
    19.                 PRINTF("\r\nPINT Pin key1 Interrupt %d event detected.", pintr);
    20.         }
    21.         if(pintr==kPINT_PinInt2)
    22.         {
    23.                 PRINTF("\r\nPINT Pin key2 Interrupt %d event detected.", pintr);
    24.         }
    25. }
    26. void InitPint(void)
    27. {
    28.         /* Connect trigger sources to PINT */
    29.         INPUTMUX_Init(INPUTMUX);
    30.         INPUTMUX_AttachSignal(INPUTMUX, kPINT_PinInt0, KEY0_PIN_INT0_SRC);
    31.         INPUTMUX_AttachSignal(INPUTMUX, kPINT_PinInt1, KEY1_PIN_INT1_SRC);
    32.         INPUTMUX_AttachSignal(INPUTMUX, kPINT_PinInt2, KEY2_PIN_INT2_SRC);
    33.         //INPUTMUX_AttachSignal(INPUTMUX, kPINT_PinInt0, KEY0_PINT_PIN_INT0_SRC);
    34.         /* Turnoff clock to inputmux to save power. Clock is only needed to make changes */
    35.         INPUTMUX_Deinit(INPUTMUX);
    36.         /* Initialize PINT */
    37.         PINT_Init(PINT);
    38.         //INT0
    39.         /* Setup Pin Interrupt 0 for rising edge */
    40.         PINT_PinInterruptConfig(PINT, kPINT_PinInt0, kPINT_PinIntEnableRiseEdge, pint_intr_callback);
    41.         /* Enable callbacks for PINT0 by Index */
    42.         PINT_EnableCallbackByIndex(PINT, kPINT_PinInt0);
    43.         //INT1
    44.         PINT_PinInterruptConfig(PINT, kPINT_PinInt1, kPINT_PinIntEnableFallEdge, pint_intr_callback);
    45.         PINT_EnableCallbackByIndex(PINT, kPINT_PinInt1);
    46.         //INT2
    47.         PINT_PinInterruptConfig(PINT, kPINT_PinInt2, kPINT_PinIntEnableFallEdge, pint_intr_callback);
    48.         PINT_EnableCallbackByIndex(PINT, kPINT_PinInt2);
    49. }</font>
        2.2、pint.h
    1. <font size="3">#ifndef __PINT_H_
    2. #define __PINT_H_
    3. void InitPint(void);
    4. #endif</font>
        2.3、main.c
    1. <font size="3">//main
    2. int main(void)
    3. {
    4.         uint8_t x=0;
    5.         uint32_t port_state = 0;
    6.         POWER_SetBodVbatLevel(kPOWER_BodVbatLevel1650mv, kPOWER_BodHystLevel50mv, false);  /* set BOD VBAT level to 1.65V */
    7.         BOARD_BootClockPLL150M();
    8.
    9.         InitSystick();
    10.         InitUart();
    11.         InitKey();
    12.         InitLed();
    13.         InitLcd();
    14.         InitSpi();
    15.         Init_mcp2515();
    16.         InitPint();
    17.
    18.         LED0_OFF();
    19.         LED1_ON();
    20.
    21.         while (1)
    22.         {
    23.                 LED0_TOG();
    24.                 LED1_TOG();
    25.                 SysTick_DelayTicks(100U);
    26.         }
    27. }</font>
        三、执行结果
    GMT+8, 2026-4-7 03:09 , Processed in 0.090383 second(s), 22 queries , Redis On.
