查看: 6341|回复: 3
[求助] imx6ull+DDR3L,系统能正常跑通,压力测试不过
发表于 2020-11-18 16:49:21 | 显示全部楼层 |阅读模式
imx6ull+DDR3L,系统能正常跑通,压力测试不过。
测试软件版本:ddr_stress_tester_v3.00
测试配置文件版本:I.MX6ULL_DDR3_Script_Aid_V0.01.xlsx    和    I.MX6UL_DDR3_Script_Aid_V0.02.xlsx 都试过。
进行DDR校准的时候报错如下:
        DDR Stress Test (3.0.0)
        Build: Dec 14 2018, 14:13:23
        NXP Semiconductors.
        Chip ID
CHIP ID = i.MX6 UltraLiteLite(0x65)
Internal Revision = TO1.1
        Boot Configuration
SRC_SBMR1(0x020d8004) = 0x10004961
SRC_SBMR2(0x020d801c) = 0x01000001
ARM Clock set to 528MHz
        DDR configuration
DDR type is DDR3
Data width: 16, bank num: 8
Row size: 14, col size: 10
Chip select CSD0 is used
Density per chip select: 256MB
Current Temperature: 38
DDR Freq: 396 MHz
ddr_mr1=0x00000000
Start write leveling calibration...
running Write level HW calibration
  MPWLHWERR register read out for factory diagnostics:
  MPWLHWERR PHY0 = 0x00000000
HW WL cal status: no suitable delay value found for byte 0
HW WL cal status: no suitable delay value found for byte 1
Write leveling calibration completed but failed, the following results were found:
    MMDC_MPWLDECTRL0 ch0 (0x021b080c) = 0x001F001F
Write DQS delay result:
   Write DQS0 delay: 31/256 CK
   Write DQS1 delay: 31/256 CK
Error: failed during write leveling calibration
希望各位专家不吝赐教
 楼主| 发表于 2020-11-20 09:39:38 | 显示全部楼层
顶上去
发表于 2020-12-9 15:01:41 | 显示全部楼层
压力测试跑不过,应该还是一些参数设置的不合理,需要做调整。
发表于 2023-10-24 14:50:05 | 显示全部楼层
楼主解决了吗,我也是这个问题
GMT+8, 2025-10-27 10:09 , Processed in 0.085458 second(s), 25 queries , MemCache On.
