查看: 6445|回复: 0
[原创] LPC55S69的SCT/PWM模块的捕获功能详解
发表于 2020-12-14 15:36:36 | 显示全部楼层 |阅读模式
这个例子是基于LPC55S69-EVK board, 用MCUXpresso tools来编译调试,由于是直接写外设寄存器,此例子没有用到SDK.
在LPC55S69-EVK board有一个S1按键开关(ISP), 此开关连接到P0_5引脚。
根据LPC55S69用户手册提供的管脚复用图, P0_5和SCT_GP5管脚复用。 因此可以用S1开关产生信号触发SCT模块的捕获功能,使当前SCT的计数值锁存入capture register,且触发中断。
在SCT中断服务程序中, 判断是否是由SCT_GP5产生的event所触发的中断, 如果是,读取capture register, toggleLED pin.
结果:每一次按下S1开关,都可以看到蓝色LED灯或亮或灭,故此代码运行良好。
附代码如下:
int main(void)
    /* Init output LED GPIO. */
    //GPIO_PortInit(GPIO, BOARD_LED_PORT);
    /* Board pin init */
    //BOARD_InitPins();
    LEDInit();
    PwmInit();
    while (1)
void LEDInit()
    //set IOCON bit
    SYSCON->AHBCLKCTRLX[0]|=1<<13;
    IOCON->PIO[1][4]=0x100;
    //set GPIO1 clock
    SYSCON->AHBCLKCTRLX[0]|=1<<15;
    GPIO->DIR[1]|=1<<4;
    GPIO->NOT[1]=1<<4;
    GPIO->NOT[1]=1<<4;
    GPIO->NOT[1]=1<<4;
    GPIO->NOT[1]=1<<4;
void PwmInit(void)
    //set PIO0_5 as SCT trigger signal
    //set PIO0_5 as P0_5/FC4_RXD_SDA_MOSI/CT3MAT0/SCT_GPI5(Func4)
    //enable IOCON bit
    IOCON->PIO[0][5]=0x104;
    //enable gated clock for MUX
    //P0_5(SCT_GPI5) is routed to SCT0_INPUT3 signal
    SYSCON->AHBCLKCTRLX[0]|=1<<11;
    INPUTMUX->SCT0_INMUX[3]=5;
    //enable SCT0 gated clock
    SYSCON->AHBCLKCTRLX[1]|=1<<2;
    SCT0->CTRL |= (SystemCoreClock/1000000-1) << 5; // set prescaler,SCTimer/PWM clock = 1 MHz
    SCT0->CONFIG|=1<<0|1<<17;
    SCT0->REGMODE = (1 <<2); // register pair 1 and 2 are capture
    SCT0->MATCH[0]= 12000; // match 0 @ 12000/1MHz = 12 msec(timeout)
    SCT0->MATCHREL[0] = 12000;
    SCT0->EV[0].STATE = 0xFFFF; // event 0 only happens in state 0
    SCT0->EV[0].CTRL = (0 <<0) | //MATCHSEL[3:0] = related to match 0
           (1 << 12) | // COMBMODE[13:12] = uses matchcondition only
           (1 << 14) | // STATELD [14] = STATEV is loadedinto state
           (0 << 15); // STATEV [15] = new state is 0
    SCT0->EV[1].STATE = 0xFFFF; // event 1 only happens in state 0
    SCT0->EV[1].CTRL = (0 <<5) |
           (3 << 6) | // IOSEL [9:6] = SCT_IN3
           (2 << 10) | // IOCOND [11:10] = falling edge
           (2 << 12) | // COMBMODE[13:12] = uses IOcondition only
           (0 << 15); // STATEV[ 15] = new state is 0
#if 0
    SCT0->EV[2].STATE= 0xFFFF; // event 2 only happens in state 0
    SCT0->EV[2].CTRL= (0 << 5) |
           (6<< 6) | // IOSEL [9:6] = SCT_IN6
           (1<< 10) | // IOCOND [11:10] = rising edge
           (2<< 12) | // COMBMODE[13:12] = uses IO condition only
           (1<< 14) | // STATELD [14] = STATEV is loaded into state
           (0<< 15); // STATEV [15] = new state is 0
#endif
    SCT0->CAPCTRL[2] = (1 << 1); // event 1 causes capture 0 to beloaded
    //SCT0->CAPCTRL[2] = (1 << 2); // event 2 causescapture 2 to be loaded
    SCT0->LIMIT=0x00;
    //SCT0->LIMIT = 0x0007; // events 0, 1 and 2 are usedas counter limit
    SCT0->EVEN = 0x02; // events 0 and 2 generate interrupts
    //NVIC_EnableIRQ(SCT_IRQn); // enable SCTimer/PWMinterrupt
    //Chip_SCTPWM_Start(SCT_PWM);
    //SCT0 interrupt vector is 12
    NVIC->ISER[0]|=1<<12;
    NVIC->ICPR[0]|=1<<12;
    NVIC->IPR[12]=0x00;
    //start SCT0
    SCT0->CTRL&=~(1<<2);
uint32_t capture_Value;
void SCT0_DriverIRQHandler(void)
    if(SCT0->EVFLAG&0x02)
        SCT0->EVFLAG|=0x02;
        //toggle LED0
        capture_Value=SCT0->CAP[2];
        //GPIO_PortToggle(GPIO, BOARD_LED_PORT, 1u<< BOARD_LED_PIN);
        GPIO->NOT[1]=1<<4;
        __asm("nop");
GMT+8, 2026-11-23 02:14 , Processed in 0.084139 second(s), 22 queries , Redis On.
