查看: 7502|回复: 1
[分享] 逐飞LPC55S69 IOT开发板之IIC OLED之u8g2移植
    怒
    4 天前
  • 签到天数: 706 天
    热心会员
    发表于 2020-12-25 13:14:01 | 显示全部楼层 |阅读模式
    u8g2是目前用在ardunio上面比较广泛的图形界面,它有着占用空间小,易于配置的有点,很适合单色屏的场合。
    今天我们来移植一下U8G2,并通过IIC OLED把它显示出来。
    我们下来配对GPIO模拟驱动的IIC接口的OLED:
    然后直接上代码,这都是比较成熟的芯片了:
    我们先把OLED点亮:
    ss1306_oled.c
    1. /*
    2. * ss1306_oled.c
    3. *
    4. *  Created on: 2020年12月24日
    5. *      Author: Administrator
    6. */
    7. #include "ss1306_oled.h"
    8. #include "oledfont.h"
    9. #include "delay.h"
    10. uint8_t OLED_GRAM[144][8];
    11. void OLED_I2C_GPIO_Init(void)
    12. {
    13.         /* Enables the clock for the I/O controller.: Enable Clock. */
    14.         CLOCK_EnableClock(kCLOCK_Iocon);
    15.         /* Enables the clock for the GPIO0 module */
    16.         CLOCK_EnableClock(kCLOCK_Gpio0);
    17.         /* Enables the clock for the GPIO1 module */
    18.         CLOCK_EnableClock(kCLOCK_Gpio1);
    19.         gpio_pin_config_t oled_sda_config = {
    20.                 .pinDirection = kGPIO_DigitalOutput,
    21.                 .outputLogic = 0U
    22.         };
    23.         /* Initialize GPIO functionality on pin PIO0_23 (pin 20)  */
    24.         GPIO_PinInit(BOARD_INITPINS_oled_sda_GPIO, BOARD_INITPINS_oled_sda_PORT, BOARD_INITPINS_oled_sda_PIN, &oled_sda_config);
    25.         gpio_pin_config_t oled_scl_config = {
    26.                 .pinDirection = kGPIO_DigitalOutput,
    27.                 .outputLogic = 0U
    28.         };
    29.         /* Initialize GPIO functionality on pin PIO1_7 (pin 9)  */
    30.         GPIO_PinInit(BOARD_INITPINS_oled_scl_GPIO, BOARD_INITPINS_oled_scl_PORT, BOARD_INITPINS_oled_scl_PIN, &oled_scl_config);
    31.         IOCON->PIO[0][23] = ((IOCON->PIO[0][23] &
    32.                                                           /* Mask bits to zero which are setting */
    33.                                                           (~(IOCON_PIO_FUNC_MASK | IOCON_PIO_DIGIMODE_MASK | IOCON_PIO_OD_MASK)))
    34.                                                          /* Selects pin function.
    35.                                                           * : PORT023 (pin 20) is configured as PIO0_23. */
    36.                                                          | IOCON_PIO_FUNC(PIO0_23_FUNC_ALT0)
    37.                                                          /* Select Digital mode.
    38.                                                           * : Enable Digital mode.
    39.                                                           * Digital input is enabled. */
    40.                                                          | IOCON_PIO_DIGIMODE(PIO0_23_DIGIMODE_DIGITAL)
    41.                                                          /* Controls open-drain mode.
    42.                                                           * : Open-drain.
    43.                                                           * Simulated open-drain output (high drive disabled). */
    44.                                                          | IOCON_PIO_OD(PIO0_23_OD_OPEN_DRAIN));
    45.         IOCON->PIO[1][7] = ((IOCON->PIO[1][7] &
    46.                                                         /* Mask bits to zero which are setting */
    47.                                                         (~(IOCON_PIO_FUNC_MASK | IOCON_PIO_DIGIMODE_MASK | IOCON_PIO_OD_MASK)))
    48.                                                    /* Selects pin function.
    49.                                                         * : PORT17 (pin 9) is configured as PIO1_7. */
    50.                                                    | IOCON_PIO_FUNC(PIO1_7_FUNC_ALT0)
    51.                                                    /* Select Digital mode.
    52.                                                         * : Enable Digital mode.
    53.                                                         * Digital input is enabled. */
    54.                                                    | IOCON_PIO_DIGIMODE(PIO1_7_DIGIMODE_DIGITAL)
    55.                                                    /* Controls open-drain mode.
    56.                                                         * : Open-drain.
    57.                                                         * Simulated open-drain output (high drive disabled). */
    58.                                                    | IOCON_PIO_OD(PIO1_7_OD_OPEN_DRAIN));
    59. }
    60. //延时
    61. void IIC_delay(void)
    62. {
    63. //        uint8_t t=3;
    64. //        while(t--);
    65.         delay_us(4);
    66. }
    67. //起始信号
    68. void MyI2C_Start(void)
    69. {
    70.         OLED_SDA_Set();
    71.                 OLED_SCL_Set();
    72.                 IIC_delay();
    73.                 OLED_SDA_Clr();
    74.                 IIC_delay();
    75.                 OLED_SCL_Clr();
    76.                 IIC_delay();
    77. }
    78. //结束信号
    79. void MyI2C_Stop(void)
    80. {
    81.         OLED_SDA_Clr();
    82.                 OLED_SCL_Set();
    83.                 IIC_delay();
    84.                 OLED_SDA_Set();
    85. }
    86. //等待信号响应
    87. uint32_t MyI2C_WaitAck(void) //测数据信号的电平
    88. {
    89.         OLED_SDA_Set();
    90.                 IIC_delay();
    91.                 OLED_SCL_Set();
    92.                 IIC_delay();
    93.                 OLED_SCL_Clr();
    94.                 IIC_delay();
    95. }
    96. //写入一个字节
    97. void MySend_Byte(uint8_t dat)
    98. {
    99.         uint8_t i;
    100.         for(i=0;i<8;i++)
    101.         {
    102.                 if(dat&0x80)//将dat的8位从最高位依次写入
    103.                 {
    104.                         OLED_SDA_Set();
    105.     }
    106.                 else
    107.                 {
    108.                         OLED_SDA_Clr();
    109.     }
    110.                 IIC_delay();
    111.                 OLED_SCL_Set();
    112.                 IIC_delay();
    113.                 OLED_SCL_Clr();//将时钟信号设置为低电平
    114.                 dat<<=1;
    115.   }
    116. }
    117. //反显函数
    118. void OLED_ColorTurn(uint8_t i)
    119. {
    120.         if(i==0)
    121.         {
    122.                 OLED_WR_Byte(0xA6,OLED_CMD);//正常显示
    123.         }
    124.         if(i==1)
    125.         {
    126.                 OLED_WR_Byte(0xA7,OLED_CMD);//反色显示
    127.         }
    128. }
    129. //屏幕***180度
    130. void OLED_DisplayTurn(uint8_t i)
    131. {
    132.         if(i==0)
    133.         {
    134.                 OLED_WR_Byte(0xC8,OLED_CMD);//正常显示
    135.                 OLED_WR_Byte(0xA1,OLED_CMD);
    136.         }
    137.         if(i==1)
    138.         {
    139.                 OLED_WR_Byte(0xC0,OLED_CMD);//反转显示
    140.                 OLED_WR_Byte(0xA0,OLED_CMD);
    141.         }
    142. }
    143. //发送一个字节
    144. //mode:数据/命令标志 0,表示命令;1,表示数据;
    145. void OLED_WR_Byte(uint8_t dat,uint8_t mode)
    146. {
    147.         MyI2C_Start();
    148.         MySend_Byte(0x78);
    149.         MyI2C_WaitAck();
    150.         if(mode){MySend_Byte(0x40);}
    151.   else{MySend_Byte(0x00);}
    152.         MyI2C_WaitAck();
    153.         MySend_Byte(dat);
    154.         MyI2C_WaitAck();
    155.         MyI2C_Stop();
    156. }
    157. //开启OLED显示
    158. void OLED_DisPlay_On(void)
    159. {
    160.         OLED_WR_Byte(0x8D,OLED_CMD);//电荷泵使能
    161.         OLED_WR_Byte(0x14,OLED_CMD);//开启电荷泵
    162.         OLED_WR_Byte(0xAF,OLED_CMD);//点亮屏幕
    163. }
    164. //关闭OLED显示
    165. void OLED_DisPlay_Off(void)
    166. {
    167.         OLED_WR_Byte(0x8D,OLED_CMD);//电荷泵使能
    168.         OLED_WR_Byte(0x10,OLED_CMD);//关闭电荷泵
    169.         OLED_WR_Byte(0xAE,OLED_CMD);//关闭屏幕
    170. }
    171. //更新显存到OLED
    172. void OLED_Refresh(void)
    173. {
    174.         uint8_t i,n;
    175.         for(i=0;i<8;i++)
    176.         {
    177.                 OLED_WR_Byte(0xb0+i,OLED_CMD); //设置行起始地址
    178.                 OLED_WR_Byte(0x00,OLED_CMD);   //设置低列起始地址
    179.                 OLED_WR_Byte(0x10,OLED_CMD);   //设置高列起始地址
    180.                 MyI2C_Start();
    181.                 MySend_Byte(0x78);
    182.                 MyI2C_WaitAck();
    183.                 MySend_Byte(0x40);
    184.                 MyI2C_WaitAck();
    185.                 for(n=0;n<128;n++)
    186.                 {
    187.                         MySend_Byte(OLED_GRAM[n][i]);
    188.                         MyI2C_WaitAck();
    189.                 }
    190.                 MyI2C_Stop();
    191.   }
    192. }
    193. //清屏函数
    194. void OLED_Clear(void)
    195. {
    196.         uint8_t i,n;
    197.         for(i=0;i<8;i++)
    198.         {
    199.            for(n=0;n<128;n++)
    200.                         {
    201.                          OLED_GRAM[n][i]=0;//清除所有数据
    202.                         }
    203.   }
    204.         OLED_Refresh();//更新显示
    205. }
    206. //画点
    207. //x:0~127
    208. //y:0~63
    209. //t:1 填充 0,清空
    210. void OLED_DrawPoint(uint8_t x,uint8_t y,uint8_t t)
    211. {
    212.         uint8_t i,m,n;
    213.         i=y/8;
    214.         m=y%8;
    215.         n=1<<m;
    216.         if(t){OLED_GRAM[x][i]|=n;}
    217.         else
    218.         {
    219.                 OLED_GRAM[x][i]=~OLED_GRAM[x][i];
    220.                 OLED_GRAM[x][i]|=n;
    221.                 OLED_GRAM[x][i]=~OLED_GRAM[x][i];
    222.         }
    223. }
    224. //画线
    225. //x1,y1:起点坐标
    226. //x2,y2:结束坐标
    227. void OLED_DrawLine(uint8_t x1,uint8_t y1,uint8_t x2,uint8_t y2,uint8_t mode)
    228. {
    229.         uint16_t t;
    230.         int xerr=0,yerr=0,delta_x,delta_y,distance;
    231.         int incx,incy,uRow,uCol;
    232.         delta_x=x2-x1; //计算坐标增量
    233.         delta_y=y2-y1;
    234.         uRow=x1;//画线起点坐标
    235.         uCol=y1;
    236.         if(delta_x>0)incx=1; //设置单步方向
    237.         else if (delta_x==0)incx=0;//垂直线
    238.         else {incx=-1;delta_x=-delta_x;}
    239.         if(delta_y>0)incy=1;
    240.         else if (delta_y==0)incy=0;//水平线
    241.         else {incy=-1;delta_y=-delta_x;}
    242.         if(delta_x>delta_y)distance=delta_x; //选取基本增量坐标轴
    243.         else distance=delta_y;
    244.         for(t=0;t<distance+1;t++)
    245.         {
    246.                 OLED_DrawPoint(uRow,uCol,mode);//画点
    247.                 xerr+=delta_x;
    248.                 yerr+=delta_y;
    249.                 if(xerr>distance)
    250.                 {
    251.                         xerr-=distance;
    252.                         uRow+=incx;
    253.                 }
    254.                 if(yerr>distance)
    255.                 {
    256.                         yerr-=distance;
    257.                         uCol+=incy;
    258.                 }
    259.         }
    260. }
    261. //x,y:圆心坐标
    262. //r:圆的半径
    263. void OLED_DrawCircle(uint8_t x,uint8_t y,uint8_t r)
    264. {
    265.         int Na, Nb,num;
    266.     Na = 0;
    267.     Nb = r;
    268.     while(2 * Nb * Nb >= r * r)
    269.     {
    270.         OLED_DrawPoint(x + Na, y - Nb,1);
    271.         OLED_DrawPoint(x - Na, y - Nb,1);
    272.         OLED_DrawPoint(x - Na, y + Nb,1);
    273.         OLED_DrawPoint(x + Na, y + Nb,1);
    274.         OLED_DrawPoint(x + Nb, y + Na,1);
    275.         OLED_DrawPoint(x + Nb, y - Na,1);
    276.         OLED_DrawPoint(x - Nb, y - Na,1);
    277.         OLED_DrawPoint(x - Nb, y + Na,1);
    278.         Na++;
    279.         num = (Na * Na + Nb * Nb) - r*r;//计算画的点离圆心的距离
    280.         if(num > 0)
    281.         {
    282.             Nb--;
    283.             Na--;
    284.         }
    285.     }
    286. }
    287. //在指定位置显示一个字符,包括部分字符
    288. //x:0~127
    289. //y:0~63
    290. //size1:选择字体 6x8/6x12/8x16/12x24
    291. //mode:0,反色显示;1,正常显示
    292. void OLED_ShowChar(uint8_t x,uint8_t y,uint8_t chr,uint8_t size1,uint8_t mode)
    293. {
    294.         uint8_t i,m,temp,size2,chr1;
    295.         uint8_t x0=x,y0=y;
    296.         if(size1==8)size2=6;
    297.         else size2=(size1/8+((size1%8)?1:0))*(size1/2);  //得到字体一个字符对应点阵集所占的字节数
    298.         chr1=chr-' ';  //计算偏移后的值
    299.         for(i=0;i<size2;i++)
    300.         {
    301.                 if(size1==8)
    302.                           {temp=asc2_0806[chr1][i];} //调用0806字体
    303.                 else if(size1==12)
    304.         {temp=asc2_1206[chr1][i];} //调用1206字体
    305.                 else if(size1==16)
    306.         {temp=asc2_1608[chr1][i];} //调用1608字体
    307.                 else if(size1==24)
    308.         {temp=asc2_2412[chr1][i];} //调用2412字体
    309.                 else return;
    310.                 for(m=0;m<8;m++)
    311.                 {
    312.                         if(temp&0x01)OLED_DrawPoint(x,y,mode);
    313.                         else OLED_DrawPoint(x,y,!mode);
    314.                         temp>>=1;
    315.                         y++;
    316.                 }
    317.                 x++;
    318.                 if((size1!=8)&&((x-x0)==size1/2))
    319.                 {x=x0;y0=y0+8;}
    320.                 y=y0;
    321.   }
    322. }
    323. //显示字符串
    324. //x,y:起点坐标
    325. //size1:字体大小
    326. //*chr:字符串起始地址
    327. //mode:0,反色显示;1,正常显示
    328. void OLED_ShowString(uint8_t x,uint8_t y,uint8_t *chr,uint8_t size1,uint8_t mode)
    329. {
    330.         while((*chr>=' ')&&(*chr<='~'))//判断是不是非法字符!
    331.         {
    332.                 OLED_ShowChar(x,y,*chr,size1,mode);
    333.                 if(size1==8)x+=6;
    334.                 else x+=size1/2;
    335.                 chr++;
    336.   }
    337. }
    338. //m^n
    339. uint32_t OLED_Pow(uint8_t m,uint8_t n)
    340. {
    341.         uint32_t result=1;
    342.         while(n--)
    343.         {
    344.           result*=m;
    345.         }
    346.         return result;
    347. }
    348. //显示数字
    349. //x,y :起点坐标
    350. //num :要显示的数字
    351. //len :数字的位数
    352. //size:字体大小
    353. //mode:0,反色显示;1,正常显示
    354. void OLED_ShowNum(uint8_t x,uint8_t y,uint32_t num,uint8_t len,uint8_t size1,uint8_t mode)
    355. {
    356.         uint8_t t,temp,m=0;
    357.         if(size1==8)m=2;
    358.         for(t=0;t<len;t++)
    359.         {
    360.                 temp=(num/OLED_Pow(10,len-t-1))%10;
    361.                         if(temp==0)
    362.                         {
    363.                                 OLED_ShowChar(x+(size1/2+m)*t,y,'0',size1,mode);
    364.       }
    365.                         else
    366.                         {
    367.                           OLED_ShowChar(x+(size1/2+m)*t,y,temp+'0',size1,mode);
    368.                         }
    369.   }
    370. }
    371. //显示汉字
    372. //x,y:起点坐标
    373. //num:汉字对应的序号
    374. //mode:0,反色显示;1,正常显示
    375. void OLED_ShowChinese(uint8_t x,uint8_t y,uint8_t num,uint8_t size1,uint8_t mode)
    376. {
    377.         uint8_t m,temp;
    378.         uint8_t x0=x,y0=y;
    379.         uint16_t i,size3=(size1/8+((size1%8)?1:0))*size1;  //得到字体一个字符对应点阵集所占的字节数
    380.         for(i=0;i<size3;i++)
    381.         {
    382.                 if(size1==16)
    383.                                 {temp=Hzk1[num][i];}//调用16*16字体
    384.                 else if(size1==24)
    385.                                 {temp=Hzk2[num][i];}//调用24*24字体
    386.                 else if(size1==32)
    387.                                 {temp=Hzk3[num][i];}//调用32*32字体
    388.                 else if(size1==64)
    389.                                 {temp=Hzk4[num][i];}//调用64*64字体
    390.                 else return;
    391.                 for(m=0;m<8;m++)
    392.                 {
    393.                         if(temp&0x01)OLED_DrawPoint(x,y,mode);
    394.                         else OLED_DrawPoint(x,y,!mode);
    395.                         temp>>=1;
    396.                         y++;
    397.                 }
    398.                 x++;
    399.                 if((x-x0)==size1)
    400.                 {x=x0;y0=y0+8;}
    401.                 y=y0;
    402.         }
    403. }
    404. //num 显示汉字的个数
    405. //space 每一遍显示的间隔
    406. //mode:0,反色显示;1,正常显示
    407. void OLED_ScrollDisplay(uint8_t num,uint8_t space,uint8_t mode)
    408. {
    409.         uint8_t i,n,t=0,m=0,r;
    410.         while(1)
    411.         {
    412.                 if(m==0)
    413.                 {
    414.             OLED_ShowChinese(128,24,t,16,mode); //写入一个汉字保存在OLED_GRAM[][]数组中
    415.                         t++;
    416.                 }
    417.                 if(t==num)
    418.                         {
    419.                                 for(r=0;r<16*space;r++)      //显示间隔
    420.                                  {
    421.                                         for(i=1;i<144;i++)
    422.                                                 {
    423.                                                         for(n=0;n<8;n++)
    424.                                                         {
    425.        OLED_GRAM[i-1][n]=OLED_GRAM[i][n];
    426.                                                         }
    427.                                                 }
    428.            OLED_Refresh();
    429.                                  }
    430.         t=0;
    431.       }
    432.                 m++;
    433.                 if(m==16){m=0;}
    434.                 for(i=1;i<144;i++)   //实现左移
    435.                 {
    436.                         for(n=0;n<8;n++)
    437.                         {
    438.                                 OLED_GRAM[i-1][n]=OLED_GRAM[i][n];
    439.                         }
    440.                 }
    441.                 OLED_Refresh();
    442.         }
    443. }
    444. //x,y:起点坐标
    445. //sizex,sizey,图片长宽
    446. //BMP[]:要写入的图片数组
    447. //mode:0,反色显示;1,正常显示
    448. void OLED_ShowPicture(uint8_t x,uint8_t y,uint8_t sizex,uint8_t sizey,uint8_t BMP[],uint8_t mode)
    449. {
    450.         uint16_t j=0;
    451.         uint8_t i,n,temp,m;
    452.         uint8_t x0=x,y0=y;
    453.         sizey=sizey/8+((sizey%8)?1:0);
    454.         for(n=0;n<sizey;n++)
    455.         {
    456.                  for(i=0;i<sizex;i++)
    457.                  {
    458.                                 temp=BMP[j];
    459.                                 j++;
    460.                                 for(m=0;m<8;m++)
    461.                                 {
    462.                                         if(temp&0x01)OLED_DrawPoint(x,y,mode);
    463.                                         else OLED_DrawPoint(x,y,!mode);
    464.                                         temp>>=1;
    465.                                         y++;
    466.                                 }
    467.                                 x++;
    468.                                 if((x-x0)==sizex)
    469.                                 {
    470.                                         x=x0;
    471.                                         y0=y0+8;
    472.                                 }
    473.                                 y=y0;
    474.      }
    475.          }
    476. }
    477. //OLED的初始化
    478. void OLED_Init(void)
    479. {
    480.         OLED_I2C_GPIO_Init();
    481.         OLED_WR_Byte(0xAE,OLED_CMD);//--turn off oled panel
    482.         OLED_WR_Byte(0x00,OLED_CMD);//---set low column address
    483.         OLED_WR_Byte(0x10,OLED_CMD);//---set high column address
    484.         OLED_WR_Byte(0x40,OLED_CMD);//--set start line address  Set Mapping RAM Display Start Line (0x00~0x3F)
    485.         OLED_WR_Byte(0x81,OLED_CMD);//--set contrast control register
    486.         OLED_WR_Byte(0xCF,OLED_CMD);// Set SEG Output Current Brightness
    487.         OLED_WR_Byte(0xA1,OLED_CMD);//--Set SEG/Column Mapping     0xa0左右反置 0xa1正常
    488.         OLED_WR_Byte(0xC8,OLED_CMD);//Set COM/Row Scan Direction   0xc0上下反置 0xc8正常
    489.         OLED_WR_Byte(0xA6,OLED_CMD);//--set normal display
    490.         OLED_WR_Byte(0xA8,OLED_CMD);//--set multiplex ratio(1 to 64)
    491.         OLED_WR_Byte(0x3f,OLED_CMD);//--1/64 duty
    492.         OLED_WR_Byte(0xD3,OLED_CMD);//-set display offset        Shift Mapping RAM Counter (0x00~0x3F)
    493.         OLED_WR_Byte(0x00,OLED_CMD);//-not offset
    494.         OLED_WR_Byte(0xd5,OLED_CMD);//--set display clock divide ratio/oscillator frequency
    495.         OLED_WR_Byte(0x80,OLED_CMD);//--set divide ratio, Set Clock as 100 Frames/Sec
    496.         OLED_WR_Byte(0xD9,OLED_CMD);//--set pre-charge period
    497.         OLED_WR_Byte(0xF1,OLED_CMD);//Set Pre-Charge as 15 Clocks & Discharge as 1 Clock
    498.         OLED_WR_Byte(0xDA,OLED_CMD);//--set com pins hardware configuration
    499.         OLED_WR_Byte(0x12,OLED_CMD);
    500.         OLED_WR_Byte(0xDB,OLED_CMD);//--set vcomh
    501.         OLED_WR_Byte(0x40,OLED_CMD);//Set VCOM Deselect Level
    502.         OLED_WR_Byte(0x20,OLED_CMD);//-Set Page Addressing Mode (0x00/0x01/0x02)
    503.         OLED_WR_Byte(0x02,OLED_CMD);//
    504.         OLED_WR_Byte(0x8D,OLED_CMD);//--set Charge Pump enable/disable
    505.         OLED_WR_Byte(0x14,OLED_CMD);//--set(0x10) disable
    506.         OLED_WR_Byte(0xA4,OLED_CMD);// Disable Entire Display On (0xa4/0xa5)
    507.         OLED_WR_Byte(0xA6,OLED_CMD);// Disable Inverse Display On (0xa6/a7)
    508.         OLED_Clear();
    509.         OLED_WR_Byte(0xAF,OLED_CMD);
    510. }
    ss1306_oled.h
    1. /*
    2. * ss1306_oled.h
    3. *
    6. */
    7. #ifndef SS1306_OLED_H_
    8. #define SS1306_OLED_H_
    9. #include <stdio.h>
    10. #include "board.h"
    11. #include "peripherals.h"
    12. #include "pin_mux.h"
    13. #include "clock_config.h"
    14. #include "LPC55S69_cm33_core0.h"
    15. #include "fsl_gpio.h"
    16. #define oled_scl(x)  GPIO_PinWrite(BOARD_INITPINS_oled_scl_GPIO, BOARD_INITPINS_oled_scl_PORT, BOARD_INITPINS_oled_scl_PIN, x)
    17. #define oled_sda(x)  GPIO_PinWrite(BOARD_INITPINS_oled_sda_GPIO, BOARD_INITPINS_oled_sda_PORT, BOARD_INITPINS_oled_sda_PIN, x)
    18. #define OLED_SDA_Set() oled_sda(1)
    19. #define OLED_SDA_Clr() oled_sda(0)
    20. #define OLED_SCL_Set() oled_scl(1)
    21. #define OLED_SCL_Clr() oled_scl(0)
    22. #define OLED_ADDRESS        0x78 //通过调整0R电阻,屏可以选择0x78  0x7A两个地址   默认为0x78
    23. #define OLED_CMD  0        //写命令
    24. #define OLED_DATA 1        //写数据
    25. void MyI2C_Start(void);
    26. void MyI2C_Stop(void);
    27. uint32_t MyI2C_WaitAck(void);
    28. void MySend_Byte(uint8_t dat);
    29. void OLED_ClearPoint(uint8_t x,uint8_t y);
    30. void OLED_ColorTurn(uint8_t i);
    31. void OLED_DisplayTurn(uint8_t i);
    32. void OLED_WR_Byte(uint8_t dat,uint8_t mode);
    33. void OLED_DisPlay_On(void);
    34. void OLED_DisPlay_Off(void);
    35. void OLED_Refresh(void);
    36. void OLED_Clear(void);
    37. void OLED_DrawPoint(uint8_t x,uint8_t y,uint8_t t);
    38. void OLED_DrawLine(uint8_t x1,uint8_t y1,uint8_t x2,uint8_t y2,uint8_t mode);
    39. void OLED_DrawCircle(uint8_t x,uint8_t y,uint8_t r);
    40. void OLED_ShowChar(uint8_t x,uint8_t y,uint8_t chr,uint8_t size1,uint8_t mode);
    41. void OLED_ShowChar6x8(uint8_t x,uint8_t y,uint8_t chr,uint8_t mode);
    42. void OLED_ShowString(uint8_t x,uint8_t y,uint8_t *chr,uint8_t size1,uint8_t mode);
    43. void OLED_ShowNum(uint8_t x,uint8_t y,uint32_t num,uint8_t len,uint8_t size1,uint8_t mode);
    44. void OLED_ShowChinese(uint8_t x,uint8_t y,uint8_t num,uint8_t size1,uint8_t mode);
    45. void OLED_ScrollDisplay(uint8_t num,uint8_t space,uint8_t mode);
    46. void OLED_ShowPicture(uint8_t x,uint8_t y,uint8_t sizex,uint8_t sizey,uint8_t BMP[],uint8_t mode);
    47. void OLED_I2C_GPIO_Init(void);
    48. void OLED_Init(void);
    49. #endif /* SS1306_OLED_H_ */
    在main里面调用,显示图片:
    1. OLED_Init();
    2.         OLED_ColorTurn(0);//0正常显示,1 反色显示
    3.         OLED_DisplayTurn(0);//0正常显示 1 屏幕翻转显示
    编译查看现象:
    我们去这个网址:https://github.com/olikraus/u8g2 下载u8g2的文件包:
    解压下来,用里面的csrc文件夹,其余的不用。把这个文件夹及里面文件添加到工程中:
    我们按照之前gui的习惯,同样把配置文件写到一个叫u8g2_support.c和h文件里面:
    u8g2_support.h
    1. /*
    2. * u8g2_support.h
    3. *
    4. *  Created on: 2020年12月25日
    6. */
    7. #ifndef U8G2_SUPPORT_H_
    8. #define U8G2_SUPPORT_H_
    9. #include "u8g2.h"
    10. #include <stdio.h>
    11. #include "board.h"
    12. #include "peripherals.h"
    13. #include "pin_mux.h"
    14. #include "clock_config.h"
    15. #include "LPC55S69_cm33_core0.h"
    16. /* TODO: insert other include files here. */
    17. #include "delay.h"
    18. #include "ss1306_oled.h"
    19. #define DATA_BUFFER_SIZE 1024         //the size of buffer depends on how many pages are transfered at once e.g. one page are 128byte  1024
    20. #define I2C_TIMEOUT 1000
    21. #define DEVICE_ADDRESS 0x78         //device address is added
    22. uint8_t u8x8_byte_sw_i2c_lpc55s69(u8x8_t *u8x8, uint8_t msg, uint8_t arg_int, void *arg_ptr);
    23. uint8_t u8x8_gpio_and_delay_lpc55s69(u8x8_t *u8x8, uint8_t msg, uint8_t arg_int, void *arg_ptr);
    24. #endif /* U8G2_SUPPORT_H_ */
    u8g2_support.c
    1. /*
    2. * u8g2_support.c
    3. *
    6. */
    7. #include "u8g2_support.h"
    8. #include "u8g2.h"
    9. #include "u8x8.h"
    10. uint8_t u8x8_gpio_and_delay_lpc55s69(u8x8_t *u8x8, uint8_t msg, uint8_t arg_int, void *arg_ptr)
    11. {
    12.   switch(msg)
    13.   {
    14.     case U8X8_MSG_GPIO_AND_DELAY_INIT:
    15.       /* only support for software I2C*/
    16.             OLED_I2C_GPIO_Init();
    17.       break;
    18.     case U8X8_MSG_DELAY_NANO:
    19.       /* not required for SW I2C */
    20.       break;
    21.     case U8X8_MSG_DELAY_10MICRO:
    22.       /* not used at the moment */
    23.       break;
    24.     case U8X8_MSG_DELAY_100NANO:
    25.       /* not used at the moment */
    26.       break;
    27.     case U8X8_MSG_DELAY_MILLI:
    28.             delay_ms(arg_int);
    29.       break;
    30.     case U8X8_MSG_DELAY_I2C:
    31.       /* arg_int is 1 or 4: 100KHz (5us) or 400KHz (1.25us) */
    32.       delay_us(arg_int<=2?5:1);
    33.       break;
    34.     case U8X8_MSG_GPIO_I2C_CLOCK:
    35. /*      if ( arg_int == 0 )
    36.       {
    37.         Chip_GPIO_SetPinDIROutput(LPC_GPIO_PORT, I2C_CLOCK_PORT, I2C_CLOCK_PIN);
    38.         Chip_GPIO_SetPinOutLow(LPC_GPIO_PORT, I2C_CLOCK_PORT, I2C_CLOCK_PIN);
    39.       }
    40.       else
    41.       {
    42.         //Chip_GPIO_SetPinOutHigh(LPC_GPIO, I2C_CLOCK_PORT, I2C_CLOCK_PIN);
    43.         Chip_GPIO_SetPinDIRInput(LPC_GPIO_PORT, I2C_CLOCK_PORT, I2C_CLOCK_PIN);
    44.       }*/
    45.       break;
    46.     case U8X8_MSG_GPIO_I2C_DATA:
    47. /*      if ( arg_int == 0 )
    48.       {
    49.         Chip_GPIO_SetPinDIROutput(LPC_GPIO_PORT, I2C_DATA_PORT, I2C_DATA_PIN);
    50.         Chip_GPIO_SetPinOutLow(LPC_GPIO_PORT, I2C_DATA_PORT, I2C_DATA_PIN);
    51.       }
    52.       else
    53.       {
    54.         //Chip_GPIO_SetPinOutHigh(LPC_GPIO, I2C_DATA_PORT, I2C_DATA_PIN);
    55.         Chip_GPIO_SetPinDIRInput(LPC_GPIO_PORT, I2C_DATA_PORT, I2C_DATA_PIN);
    56.       }
    57.       break;*/
    58. /*
    59.     case U8X8_MSG_GPIO_MENU_SELECT:
    60.       u8x8_SetGPIOResult(u8x8, Chip_GPIO_GetPinState(LPC_GPIO, KEY_SELECT_PORT, KEY_SELECT_PIN));
    61.       break;
    62.     case U8X8_MSG_GPIO_MENU_NEXT:
    63.       u8x8_SetGPIOResult(u8x8, Chip_GPIO_GetPinState(LPC_GPIO, KEY_NEXT_PORT, KEY_NEXT_PIN));
    64.       break;
    65.     case U8X8_MSG_GPIO_MENU_PREV:
    66.       u8x8_SetGPIOResult(u8x8, Chip_GPIO_GetPinState(LPC_GPIO, KEY_PREV_PORT, KEY_PREV_PIN));
    67.       break;
    68.     case U8X8_MSG_GPIO_MENU_HOME:
    69.       u8x8_SetGPIOResult(u8x8, Chip_GPIO_GetPinState(LPC_GPIO, KEY_HOME_PORT, KEY_HOME_PIN));*/
    70.       break;
    71.     default:
    72.       //u8x8_SetGPIOResult(u8x8, 1);
    73.       break;
    74.   }
    75.   return 1;
    76. }
    77. uint8_t u8x8_byte_sw_i2c_lpc55s69(u8x8_t *u8x8, uint8_t msg, uint8_t arg_int, void *arg_ptr)
    78. {
    79.         uint8_t *ptr;
    80.         static uint8_t buffer_count;
    81.         static uint8_t buffer[DATA_BUFFER_SIZE+1];        //the size of buffer depends on how many pages are transfered at once
    82.        //e.g. one page are 128byte and one byte more for command
    83.         switch(msg)
    84.         {
    85.                 case U8X8_MSG_BYTE_SEND:                                        //collect
    86.                 {
    87.                         ptr = arg_ptr;
    88.                         while(arg_int>0)
    89.                         {
    90.                                 MySend_Byte(*(ptr++));
    91.                                 MyI2C_WaitAck();
    92.                                 arg_int--;
    93.                         }
    94.                 }
    95.                 break;
    96.                 case U8X8_MSG_BYTE_INIT:
    97.                 break;
    98.                 case U8X8_MSG_BYTE_SET_DC:
    99.                 break;
    100.                 case U8X8_MSG_BYTE_START_TRANSFER:
    101.                 MyI2C_Start();
    102.                 MySend_Byte(0x78);
    103.                 MyI2C_WaitAck();
    104.                 break;
    105.                 case U8X8_MSG_BYTE_END_TRANSFER:                        // send all at once
    106.                 MyI2C_Stop();
    107.                 break;
    108.                 default:
    109.                 return 0;
    110.         }
    111.         return 1;
    112. }
    其中最重要的就是重构这2个函数。 :
    引脚和延时 :uint8_t u8x8_gpio_and_delay_lpc55s69(u8x8_t *u8x8, uint8_t msg, uint8_t arg_int, void *arg_ptr)
    IIC读写:       uint8_t u8x8_byte_sw_i2c_lpc55s69(u8x8_t *u8x8, uint8_t msg, uint8_t arg_int, void *arg_ptr);
    然后在主函数里面调用,即可开启u8g2:
    1. /* setup display */
    2.         u8g2_Setup_ssd1306_i2c_128x64_noname_2(&u8g2, U8G2_R0, u8x8_byte_sw_i2c_lpc55s69, u8x8_gpio_and_delay_lpc55s69);
    3.         u8g2_InitDisplay(&u8g2);
    4.         u8g2_SetPowerSave(&u8g2, 0);
    我们写一个demo的例子:
    u8g2_demo.h
    1. /*
    2. * u8g2_demo.h
    3. *
    6. */
    7. #ifndef U8G2_DEMO_H_
    8. #define U8G2_DEMO_H_
    10. #include "u8g2_support.h"
    11. extern u8g2_t u8g2;
    12. void demo_u8g2_draw(u8g2_t *u8g2);
    13. void demo_u8g2_draw2(void);
    14. void demo_u8g2_init(void);
    15. void demo_u8g2_task(void);
    16. #endif /* U8G2_DEMO_H_ */
    u8g2_demo.c
    1. /*
    2. * u8g2.c
    3. *
    6. */
    7. #include "u8g2_demo.h"
    8. u8g2_t u8g2; // a structure which will contain all the data for one display
    9. uint8_t show_delay_max = 0;//等待最长时间
    10. uint8_t show_delay_cnt = 0;     //等待延时标志
    11. uint8_t show_picture_index =0;   //对应图片选择
    13. {
    14.     u8g2_SetFontMode(u8g2, 1);        // Transparent
    15.     u8g2_SetFontDirection(u8g2, 0);
    16.     u8g2_SetFont(u8g2, u8g2_font_inb24_mf);
    17.     u8g2_DrawStr(u8g2, 0, 30, "U");
    18.     u8g2_SetFontDirection(u8g2, 1);
    19.     u8g2_SetFont(u8g2, u8g2_font_inb30_mn);
    20.     u8g2_DrawStr(u8g2, 21,8,"8");
    21.     u8g2_SetFontDirection(u8g2, 0);
    22.     u8g2_SetFont(u8g2, u8g2_font_inb24_mf);
    23.     u8g2_DrawStr(u8g2, 51,30,"g");
    24.     u8g2_DrawStr(u8g2, 67,30,"\xb2");
    25.     u8g2_DrawHLine(u8g2, 2, 35, 47);
    26.     u8g2_DrawHLine(u8g2, 3, 36, 47);
    27.     u8g2_DrawVLine(u8g2, 45, 32, 12);
    28.     u8g2_DrawVLine(u8g2, 46, 33, 12);
    29.     u8g2_SetFont(u8g2, u8g2_font_4x6_tr);
    30.     u8g2_DrawStr(u8g2, 1,54,"github.com/olikraus/u8g2");
    31. }
    32. //////demo2
    33. #define hare1_width 25
    34. #define hare1_height 28
    35. static unsigned char hare1_bits[] = {
    36.    0x00, 0x08, 0x00, 0x00, 0x00, 0x77, 0x00, 0x00, 0x80, 0x80, 0x01, 0x00,
    37.    0x00, 0x01, 0x02, 0x00, 0x00, 0x0e, 0x0c, 0x00, 0x00, 0x01, 0x30, 0x00,
    38.    0x80, 0x00, 0x40, 0x00, 0x80, 0x00, 0x88, 0x00, 0x40, 0x1c, 0x1c, 0x01,
    39.    0x80, 0x23, 0x1c, 0x01, 0x00, 0x20, 0x08, 0x01, 0x00, 0x1c, 0x80, 0x00,
    40.    0x00, 0x03, 0x40, 0x00, 0x80, 0x00, 0x20, 0x00, 0x60, 0x00, 0x20, 0x00,
    41.    0x10, 0x00, 0x20, 0x00, 0x08, 0x00, 0x40, 0x00, 0x04, 0x00, 0x40, 0x00,
    42.    0x02, 0x80, 0x87, 0x00, 0x01, 0x40, 0x88, 0x00, 0x01, 0x20, 0x48, 0x00,
    43.    0x03, 0x20, 0x30, 0x00, 0x1c, 0xc0, 0x00, 0x00, 0x20, 0x00, 0x01, 0x00,
    44.    0x40, 0x00, 0x01, 0x00, 0x80, 0x80, 0x00, 0x00, 0x00, 0x67, 0x00, 0x00,
    45.    0x00, 0x18, 0x00, 0x00 };
    46. #define hare2_width 30
    47. #define hare2_height 28
    48. static unsigned char hare2_bits[] = {
    49.    0x00, 0xc0, 0x03, 0x00, 0x00, 0x20, 0x04, 0x00, 0x00, 0x20, 0x08, 0x00,
    50.    0x00, 0x40, 0x10, 0x00, 0x00, 0x80, 0x20, 0x00, 0x00, 0x70, 0x40, 0x00,
    51.    0x00, 0x08, 0x80, 0x01, 0x00, 0x04, 0x00, 0x02, 0x00, 0xf8, 0x00, 0x04,
    52.    0x00, 0x00, 0x81, 0x08, 0x00, 0x00, 0xc1, 0x11, 0x00, 0xfc, 0xc0, 0x11,
    53.    0x00, 0x03, 0x80, 0x10, 0x80, 0x00, 0x00, 0x08, 0x70, 0x00, 0x00, 0x04,
    54.    0x08, 0x00, 0x00, 0x03, 0x06, 0x00, 0xc0, 0x00, 0x01, 0x00, 0x20, 0x00,
    55.    0x01, 0x00, 0x10, 0x00, 0x01, 0x00, 0x10, 0x00, 0x06, 0x00, 0x20, 0x00,
    56.    0x08, 0x00, 0x40, 0x00, 0x08, 0xf0, 0x41, 0x00, 0x08, 0x08, 0x46, 0x00,
    57.    0x08, 0x04, 0x48, 0x00, 0x08, 0x08, 0x30, 0x00, 0x30, 0x10, 0x00, 0x00,
    58.    0xc0, 0x0f, 0x00, 0x00 };
    59. void u8g2_prepare()
    60. {
    61.   u8g2_SetFont(&u8g2, u8g2_font_courB10_tr);
    62.   u8g2_SetFontRefHeightExtendedText(&u8g2);
    63.   u8g2_SetDrawColor(&u8g2, 1);
    64.   u8g2_SetFontPosTop(&u8g2);
    65.   u8g2_SetFontDirection(&u8g2, 0);
    66. }
    67. void u8g2_drawLogo(void)
    68. {
    69.     u8g2_SetFontMode(&u8g2,1);        // Transparent
    70.     u8g2_SetDrawColor(&u8g2,1);
    71.    u8g2_SetFontDirection(&u8g2, 0);
    72.    u8g2_SetFont(&u8g2, u8g2_font_inb24_mf);
    73.    u8g2_DrawStr(&u8g2, 0, 5, "U");
    74.    u8g2_SetFontDirection(&u8g2, 1);
    75.    u8g2_SetFont(&u8g2, u8g2_font_inb30_mn);
    76.    u8g2_DrawStr(&u8g2, 51,8,"8");
    77.    u8g2_SetFontDirection(&u8g2, 0);
    78.    u8g2_SetFont(&u8g2, u8g2_font_inb24_mf);
    79.    u8g2_DrawStr(&u8g2, 51,5,"g");
    80.    u8g2_DrawStr(&u8g2, 67,5,"\xb2");
    81.    u8g2_DrawHLine(&u8g2, 2, 35, 47);
    82.    u8g2_DrawHLine(&u8g2, 3, 36, 47);
    83.    u8g2_DrawVLine(&u8g2, 45, 32, 12);
    84.    u8g2_DrawVLine(&u8g2, 46, 33, 12);
    85.    u8g2_SetFont(&u8g2, u8g2_font_5x8_tr);
    86.    u8g2_DrawStr(&u8g2, 1,54,"github.com/olikraus/u8g2");
    87. }
    88. void u8g2_box_frame(uint8_t a)
    89. {
    90.   u8g2_DrawStr(&u8g2, 0,0, "DrawBox");
    91.   u8g2_DrawBox(&u8g2,0,15,20,10);
    92.   u8g2_DrawBox(&u8g2,0+a,15,30,7);
    93.   u8g2_DrawStr(&u8g2, 0, 32, "DrawFrame");
    94.   u8g2_DrawFrame(&u8g2,0,15+32,20,10);
    95.   u8g2_DrawFrame(&u8g2,0+a,15+32,30,7);
    96. }
    97. void u8g2_disc_circle(uint8_t a)
    98. {
    99.   u8g2_DrawStr(&u8g2, 0, 0, "DrawDisc");
    100.   u8g2_DrawDisc(&u8g2,10,22,7,U8G2_DRAW_ALL);
    101.   u8g2_DrawDisc(&u8g2,24+a,20,5,U8G2_DRAW_ALL);
    102.   u8g2_DrawStr(&u8g2, 0, 32, "DrawCircle");
    103.   u8g2_DrawCircle(&u8g2,10,22+32,7,U8G2_DRAW_ALL);
    104.   u8g2_DrawCircle(&u8g2,24+a,20+32,5,U8G2_DRAW_ALL);
    105. }
    106. void u8g2_string(uint8_t a)
    107. {
    108.   u8g2_SetFontDirection(&u8g2,0);
    109.   u8g2_DrawStr(&u8g2,70+a,31, " 0");
    110.   u8g2_SetFontDirection(&u8g2,1);
    111.   u8g2_DrawStr(&u8g2,68,0+a, " 90");
    112.   u8g2_SetFontDirection(&u8g2,2);
    113.   u8g2_DrawStr(&u8g2,70-a,31, " 180");
    114.   u8g2_SetFontDirection(&u8g2,3);
    115.   u8g2_DrawStr(&u8g2,72,64-a, " 270");
    116. }
    117. void u8g2_line(uint8_t a)
    118. {
    119.   u8g2_DrawStr(&u8g2, 0, 0, "DrawLine");
    120.   u8g2_DrawLine(&u8g2,7+a, 15, 60-a, 60);
    121.   u8g2_DrawLine(&u8g2,7+a*2, 15, 80-a, 60);
    122.   u8g2_DrawLine(&u8g2,7+a*3, 15, 100-a, 60);
    123.   u8g2_DrawLine(&u8g2,7+a*4, 15, 120-a, 60);
    124. }
    125. void u8g2_hare(uint8_t a)
    126. {
    127.   u8g2_DrawStr(&u8g2, 0, 0,"DrawXBM");
    128.   if((a&1) == 0)
    129.           {
    130.                     u8g2_DrawXBM(&u8g2, 0+a, 30, hare1_width, hare1_height, hare1_bits);
    131.           }
    132.   else
    133.             {
    134.                  u8g2_DrawXBM(&u8g2, 0+a, 30, hare2_width, hare2_height, hare2_bits);
    135.             }
    136. }
    137. void demo_u8g2_draw2(void)
    138. {
    139.         u8g2_prepare();
    140.         switch(show_picture_index) {
    141.         case 0:
    142.                 //show_delay_max = 12;
    143.                 u8g2_drawLogo();
    144.         break;
    145.         case 1:
    146.                 show_delay_max = 150;
    147.                 u8g2_box_frame(show_delay_cnt);
    148.         break;
    149.         case 2:
    150.                 show_delay_max = 150;
    151.                 u8g2_disc_circle(show_delay_cnt);
    152.         break;
    153.         case 3:
    154.                 show_delay_max = 60;
    155.                 u8g2_string(show_delay_cnt);
    156.         break;
    157.         case 4:
    158.                 show_delay_max = 50;
    159.                 u8g2_line(show_delay_cnt);
    160.         break;
    161.         case 5:
    162.                 show_delay_max = 120;
    163.                 u8g2_hare(show_delay_cnt);
    164.         break;
    165.         }
    166. }
    167. //初始化
    168. void demo_u8g2_init(void)
    169. {
    170.         /* setup display */
    171.         u8g2_Setup_ssd1306_i2c_128x64_noname_2(&u8g2, U8G2_R0, u8x8_byte_sw_i2c_lpc55s69, u8x8_gpio_and_delay_lpc55s69);
    172.         u8g2_InitDisplay(&u8g2);
    173.         u8g2_SetPowerSave(&u8g2, 0);
    174. }
    175. //循环
    176. void demo_u8g2_task(void)
    177. {
    178.         u8g2_FirstPage(&u8g2);
    179.         do
    180.         {
    181.                 //demo_u8g2_draw(&u8g2);
    182.                 demo_u8g2_draw2();
    183.         } while( u8g2_NextPage(&u8g2) );
    184.         delay_ms(200);
    185.         if (show_delay_cnt <= show_delay_max)
    186.                 show_delay_cnt += 3;
    187.         else
    188.         {
    189.                 show_delay_cnt = 0;
    190.                 show_picture_index++;
    191.                 if ( show_picture_index >= 6)
    192.                         show_picture_index = 0;
    193.         }
    194. }
    我们在main函数里调用:
    1. int main(void) {
    2.           /* Init board hardware. */
    3.     BOARD_InitBootPins();
    4.     BOARD_InitBootClocks();
    5.     BOARD_InitBootPeripherals();
    6.         OLED_Init();
    7.         OLED_ColorTurn(0);//0正常显示,1 反色显示
    8.         OLED_DisplayTurn(0);//0正常显示 1 屏幕翻转显示
    9. demo_u8g2_init();
    10.     PRINTF("Hello World\n");
    11.     /* Enter an infinite loop, just incrementing a counter. */
    12.     while(1) {
    13.             demo_u8g2_task();
    14.     }
    15.     return 0 ;
    16. }
    编译查看:
    发表于 2020-12-25 22:00:39 | 显示全部楼层
    支持楼主,你这个屏还带颜色,真好!
    我的只是黑白的
    GMT+8, 2026-11-23 02:22 , Processed in 0.080581 second(s), 23 queries , Redis On.
