在线时间109 小时
UID222461
注册时间2018-11-19
NXP金币36
 TA的每日心情|  | 开心 2020-12-18 10:54
 签到天数: 8 天 连续签到: 1 天 [LV.3]偶尔看看II 高级会员
	积分987
最后登录2025-4-2 |
 楼主|
发表于 2021-1-20 20:48:14
显示全部楼层
| 复制代码CM3_ROOT
void UART3_IRQHandler(void)
    uint32_t intsrc, tmp, tmp1;
    uint8_t tmpc, i;
    NVIC_ClearPendingIRQ(UART3_IRQn);
    /* Determine the interrupt source */
    intsrc = UART_GetIntId(LPC_UART3);
    tmp = intsrc & UART_IIR_INTID_MASK;
#if 0
    // Receive Line Status
    if (tmp == UART_IIR_INTID_RLS)
        // Check line status
        tmp1 = UART_GetLineStatus(LPC_UART3);
        // Mask out the Receive Ready and Transmit Holding empty status
        tmp1 &= (UART_LSR_OE | UART_LSR_PE | UART_LSR_FE \
                 | UART_LSR_BI | UART_LSR_RXFE);
        // If any error exist
        if (tmp1)
            _MSG_DBG("tmp1=%x\n", tmp1);
            UART3_IntErr(tmp1);
#endif
#if 1
    // Receive Data Available or Character time-out
    if ((tmp == UART_IIR_INTID_RDA) || (tmp == UART_IIR_INTID_CTI))
        //UART_IntReceive();
        //直接发送会上位机,232是全双工通信
        //UART_SendByte(LPC_UART3, UART_ReceiveByte(LPC_UART3));
        //上一句和下面两个语句等价
        //UART_Receive((LPC_UART_TypeDef *)LPC_UART3, &tmpc, 1, NONE_BLOCKING);
        //UART_SendByte(LPC_UART3, tmpc);
        Uart_Receive_FSM(&uart_data_to_linux);
#endif
#if 0
    if (tmp == UART_IIR_INTID_RDA)
        //上一句和下面两个语句等价
        //        UART_Receive((LPC_UART_TypeDef *)LPC_UART3, &tmpc, 1, NONE_BLOCKING);
        //        UART_SendByte(LPC_UART3, tmpc);
        for (i = 0; i < 7; i++)     /*  连续接收7个字节   剩余1个触发cti中断来读取,避免了接收8及8整数倍的字节数数据*/
            //GucRcvBuf[i] = LPC_UART2->RBR;
            GucRcvBuf3[cti_cnt_2] = UART_ReceiveByte(LPC_UART3);
            cti_cnt_2++;
    if (tmp == UART_IIR_INTID_CTI)
        //        UART3_Flag = 1;
        //        UART_SendByte(LPC_UART3, UART_ReceiveByte(LPC_UART3));
        while ((LPC_UART3->LSR & UART_LSR_RDR) == UART_LSR_RDR)    /*  判断数据是否接收完毕  */
            //            cti_cnt++;
            //            _MSG_DBG("cti=%d\n", cti_cnt);
            cti_cnt_2++;
        UART3_Flag = 1;
#endif
