查看: 6068|回复: 2
[求助] IMX6QP SDK 启动失败问题
发表于 2021-1-22 20:43:26 | 显示全部楼层 |阅读模式
我想请教一下,我使用的是IMX6QP核心板,使用SDK是 uboot-imx-imx_v2016.03-r0   , linux-imx_4.1.15-r0.tar.gz;我们使用启动方式是SD卡启动,但是在启动过程中停止在如图片附件所示;
Waiting on root device /dev/mmcblk1p2...
之后我根据 i.MX_Linux_User's_Guide 文档执行 setenv 如下指令
setenv mmcargs 'setenv bootargs ${bootargs}
root=/dev/mmcblk2p2 rootwait rw video=mxcfb0:dev=lcd,CLAA-WVGA,if=RGB565 ip=dhcp'
之后系统启动后就出现如下情况,请问使用什么办法可以恢复flash,并且能让我的板子能正常启动,非常感谢!
U-Boot 2016.03-imx_v2016.03_4.1.15_2.0.0_ga+ga57b13b (Jan 21 2021 - 22:19:33 +0800)
CPU:   Freescale i.MX6QP rev1.0 996 MHz (running at 792 MHz)
CPU:   Automotive temperature grade (-40C to 125C) at 50C
Reset cause: WDOG
Board: MX6QP-AVM718-MB revV20
I2C:   ready
DRAM:  2 GiB
MMC:   FSL_SDHC: 0, FSL_SDHC: 1
No panel detected: default to HD700-CLAA
Display: HD700-CLAA (1200x800)
In:    serial
Out:   serial
Err:   serial
switch to partitions #0, OK
mmc0 is current device
Net:   Board Net Initialization Failed
No ethernet found.
Normal Boot
WARNING: Could not determine dtb to use
reading boot.scr
** Unable to read file boot.scr **
reading zImage
6634912 bytes read in 321 ms (19.7 MiB/s)
Booting from mmc ...
Unknown command 'rw' - try 'help'
reading undefined
** Unable to read file undefined **
Kernel image @ 0x12000000 [ 0x000000 - 0x653da0 ]
Starting kernel ...
thanks!
我知道答案 目前已有2人回答
发表于 2021-2-6 21:13:31 | 显示全部楼层
你这是boot device 没有设置正确,root=/dev/mmcblk2p2,你要看一下你板子上SD对应的是那个device.
发表于 2021-2-6 21:14:03 | 显示全部楼层
请问你板子是NXP购买的开发板吗?还是自己设计的板子呢?
GMT+8, 2025-10-26 17:34 , Processed in 0.082390 second(s), 24 queries , MemCache On.
