查看: 6578|回复: 1
[求助] IMX6 SOLO/DUALLITE 的PARALLEL-CSI接口问题
发表于 2021-2-8 11:58:20 | 显示全部楼层 |阅读模式
看手册PARALLEL-CSI 没有写支持bayer 的CMOS信号,请问10bit的并行数据怎么接?是否可以接2个10bit的cmos?是不是共用PIX_CLK,HSYNC,VSYNC?
我知道答案 目前已有1人回答
发表于 2021-3-2 11:19:45 | 显示全部楼层
camera input signal.PNG Although there will be 10 bits YUV422 data input from CSI parallel interface, I still suggest you set CSI to 8 bits mode to capture it. Because in IPU internal, it always handle Y,U,V data in 8 bits mode, if you let CSI capture data in 10 bits mode, no post process can be supported, you can only capture the data into memory.
There is no hardware impact for 8 bits setting, your camera sensor can still output YUV 10 bits data to iMX6, but iMX6 drops the lower two bits
GMT+8, 2025-10-26 17:21 , Processed in 0.083169 second(s), 23 queries , MemCache On.
