查看: 10257|回复: 3
[求助] LPC55S69进入deep sleep模式后, 如何通过CTIMER3唤醒?
    2020-7-20 09:38
    发表于 2021-3-16 00:00:26 | 显示全部楼层 |阅读模式
    LPC55S69进入深度睡眠模式是调用如下接口:
    void POWER_EnterDeepSleep(uint32_t exclude_from_pd,
                              uint32_t sram_retention_ctrl,
                              uint64_t wakeup_interrupts,
                              uint32_t hardware_wake_ctrl);
    如果要通过CTIMER3唤醒, wakeup_interrupts = W***EUP_CTIMER3,
    W***EUP_CTIMER3的时钟配置为FRO_1M,  exclude_from_pd = kPDRUNCFG_PD_FRO1M
    求助其他几个参数需要怎么设置?
    sram_retention_ctrl尝试设置为0
    hardware_wake_ctrl尝试设置了LOWPOWER_HWW***E_PERIPHERALS或者LOWPOWER_HWW***E_FORCED;
    都没有通过CTIMER3唤醒
    另外尝试POWER_EnterSleep();进入睡眠模式, 是可以通过CTIMER3中断唤醒的.
    [attach]495527[/attach] 给你个例子, 注意一下几个点 这里要保持住CTIMER3的时钟         SYSCON->AHBCLKCTRLX[2] = SYSCON_AHBCLKCTRL2_ANALOG_CTRL_MASK|SYSCON_AHBCLKCTRL2 ...
  • 签到天数: 392 天
    发表于 2021-3-16 08:12:20 | 显示全部楼层
    回帖奖励 +1 NXP金币
    你看一下这个图 81fab5e3657f1a45b16cf27c215ecd23.png 中断条件要与上W***EUP_CTIMER3,#define W***EUP_CTIMER3 (1ULL << 13)        /*!< [SLEEP, DEEP SLEEP                             ] */DEEP SLEEP是可以唤醒的
    今天天气不错!签到!
    发表于 2021-3-17 16:26:12 | 显示全部楼层
    楼主您好,
    1) 可以通过CTIMER3唤醒 DEEP SLEEP.
    2)W***EUP_CTIMER3的时钟配置为FRO_12M 试一下。
    3) 注意一下注意事项在使用函数POWER_EnterDeepSleep():
    * @brief   Configures and enters in DEEP-SLEEP low power mode
    * @param   exclude_from_pd:
    * @param   sram_retention_ctrl:
    * @param   wakeup_interrupts:
    * @param   hardware_wake_ctrl:
    * @return  Nothing
    *          !!! IMPORTANT NOTES :
    0 - CPU0 & System CLock frequency is switched to FRO12MHz and is NOT restored back by the API.
    *           1 - CPU0 Interrupt Enable registers (NVIC->ISER) are modified by this function. They are restored back in
    case of CPU retention or if POWERDOWN is not taken (for instance because an interrupt is pending).
    *           2 - The Non Maskable Interrupt (NMI) is disabled and its configuration before calling this function will be
    restored back if POWERDOWN is not taken (for instance because an RTC or OSTIMER interrupt is pending).
    *           3 - The HARD FAULT handler should execute from SRAM. (The Hard fault handler should initiate a full chip
    reset) reset)
    2016-12-2 08:40
  • 签到天数: 3 天
    发表于 2021-3-21 19:34:14 | 显示全部楼层
    lpc55s69_seekfree_iot_mdk.zip (708.58 KB, 下载次数: 9)
    GMT+8, 2026-4-15 17:40 , Processed in 0.097966 second(s), 26 queries , Redis On.
