查看: 7712|回复: 2
[求助] imx6内核启动i2c问题
发表于 2021-4-13 10:16:19 | 显示全部楼层 |阅读模式
imx6,明明在内核源码中定义了i2c的相关挂载设备信息,但是在内核启动的打印信息中i2c还是启动失败,请问这是什么问题
内核相关源码:
static struct imxi2c_platform_data mx6q_sabresd_i2c_data = {
        .bitrate = 100000,
static struct fsl_mxc_lightsensor_platform_data ls_data = {
        .rext = 499,        /* calibration: 499K->700K */
static struct i2c_board_info mxc_i2c0_board_info[] __initdata = {
                I2C_BOARD_INFO("wm89**", 0x1a),
        //        I2C_BOARD_INFO("ov564x", 0x3c),
        //        .platform_data = (void *)&camera_data,
                I2C_BOARD_INFO("mma8451", 0x1c),
                .platform_data = (void *)&mma8451_position,
                // I2C_BOARD_INFO("myCam_mipi", 0x36),
                // .platform_data = (void *)&mipi_csi2_data,
static struct i2c_board_info mxc_i2c1_board_info[] __initdata = {
                I2C_BOARD_INFO("mxc_hdmi_i2c", 0x50),
        //        I2C_BOARD_INFO("ov5640_mipi", 0x3c),
                I2C_BOARD_INFO("adv7180", 0x21),
                .platform_data = (void *)&adv7180_data,
                I2C_BOARD_INFO("egalax_ts", 0x4),
                .irq = gpio_to_irq(SABRESD_CAP_TCH_INT0),
                I2C_BOARD_INFO("max11801", 0x48),
                .platform_data = (void *)&max11801_mode,
                .irq = gpio_to_irq(SABRESD_TS_INT),
        if (cpu_is_mx6q()) {
                mxc_iomux_v3_setup_multiple_pads(mx6q_sabresd_pads,
                        ARRAY_SIZE(mx6q_sabresd_pads));
                if (enet_to_gpio_6) {
                        iomux_v3_cfg_t enet_gpio_pad =
                                MX6Q_PAD_GPIO_6__ENET_IRQ_TO_GPIO_6;
                        mxc_iomux_v3_setup_pad(enet_gpio_pad);
                } else {
                        iomux_v3_cfg_t i2c3_pad =
                                MX6Q_PAD_GPIO_6__I2C3_SDA;
                        mxc_iomux_v3_setup_pad(i2c3_pad);
        } else if (cpu_is_mx6dl()) {
                mxc_iomux_v3_setup_multiple_pads(mx6dl_sabresd_pads,
                        ARRAY_SIZE(mx6dl_sabresd_pads));
                                MX6DL_PAD_GPIO_6__ENET_IRQ_TO_GPIO_6;
                } else {
                                MX6DL_PAD_GPIO_6__I2C3_SDA;
        imx6q_add_imx_i2c(0, &mx6q_sabresd_i2c_data);
        imx6q_add_imx_i2c(1, &mx6q_sabresd_i2c_data);
//        imx6q_add_imx_i2c(2, &mx6q_sabresd_i2c_data);
//        if (cpu_is_mx6dl())
//                imx6q_add_imx_i2c(3, &mx6q_sabresd_i2c_data);
        i2c_register_board_info(0, mxc_i2c0_board_info,
                        ARRAY_SIZE(mxc_i2c0_board_info));
        i2c_register_board_info(1, mxc_i2c1_board_info,
                        ARRAY_SIZE(mxc_i2c1_board_info));
//        i2c_register_board_info(2, mxc_i2c2_board_info,
//                        ARRAY_SIZE(mxc_i2c2_board_info));
内核打印相关信息:
mc_pfuze 1-0008: recv failed!:-5,80
mc_pfuze: probe of 1-0008 failed with error-1
i2c-core: driver [max17135] using legacysuspend method
i2c-core: driver [max17135] using legacyresume method
i2c-core: driver [isl29023] using legacysuspend method
i2c-core: driver [isl29023] using legacyresume method
snvs_rtc snvs_rtc.0: rtc core: registeredsnvs_rtc as rtc0
i2c /dev entries driver
我知道答案 目前已有2人回答
发表于 2021-4-27 12:04:15 | 显示全部楼层
你板子是哪块板子?是参考我们的开发板做的板子吗?
发表于 2022-11-6 21:58:16 | 显示全部楼层
感谢分享
按揭通
綠表按揭綠置居團隊擁有豐富的居屋按揭經驗,定會針對客人不同需要, 從而制定貼合你心意的計劃, 助你排解難題,
GMT+8, 2025-10-27 03:45 , Processed in 0.091580 second(s), 23 queries , MemCache On.
