在线时间1 小时
UID3723986
注册时间2021-4-26
NXP金币0
 该用户从未签到 新手上路
	积分15
最后登录2021-4-30 |
 楼主|
发表于 2021-4-27 14:50:31
显示全部楼层
| 这个函数是配置外部存储器控制器的: void SystemInit_ExtMemCtl (void) {
 uint32_t emcdivby2_buf[emcdivby2_szw];
 uint32_t div, n;
 uint16_t wtemp = wtemp;
 /* Select and enable EMC branch clock */
 LPC_CCU1->CLK_M4_EMC_CFG = (0 << 2) | (0 << 1) | 1;
 while (!(LPC_CCU1->CLK_M4_EMC_STAT & 1));
 /* Set EMC clock output delay */
 if (SystemCoreClock < 80000000UL) {
 LPC_SCU->EMCDELAYCLK = EMC_CLK_DLY_TIM_0; /* No EMC clock out delay       */
 else {
 LPC_SCU->EMCDELAYCLK = EMC_CLK_DLY_TIM_2; /* 2.0 ns EMC clock out delay   */
 /* Configure EMC port pins */
 LPC_SCU->SFSP1_0  = EMC_PIN_SET | 2;  /* P1_0:  A5                          */
 LPC_SCU->SFSP1_1  = EMC_PIN_SET | 2;  /* P1_1:  A6                          */
 LPC_SCU->SFSP1_2  = EMC_PIN_SET | 2;  /* P1_2:  A7                          */
 LPC_SCU->SFSP1_3  = EMC_PIN_SET | 3;  /* P1_3:  OE                          */
 LPC_SCU->SFSP1_4  = EMC_PIN_SET | 3;  /* P1_4:  BLS0                        */
 LPC_SCU->SFSP1_5  = EMC_PIN_SET | 3;  /* P1_5:  CS0                         */
 LPC_SCU->SFSP1_6  = EMC_PIN_SET | 3;  /* P1_6:  WE                          */
 LPC_SCU->SFSP1_7  = EMC_PIN_SET | 3;  /* P1_7:  D0                          */
 LPC_SCU->SFSP1_8  = EMC_PIN_SET | 3;  /* P1_8:  D1                          */
 LPC_SCU->SFSP1_9  = EMC_PIN_SET | 3;  /* P1_9:  D2                          */
 LPC_SCU->SFSP1_10 = EMC_PIN_SET | 3;  /* P1_10: D3                          */
 LPC_SCU->SFSP1_11 = EMC_PIN_SET | 3;  /* P1_11: D4                          */
 LPC_SCU->SFSP1_12 = EMC_PIN_SET | 3;  /* P1_12: D5                          */
 LPC_SCU->SFSP1_13 = EMC_PIN_SET | 3;  /* P1_13: D6                          */
 LPC_SCU->SFSP1_14 = EMC_PIN_SET | 3;  /* P1_14: D7                          */
 #ifdef CPU_208PIN
 LPC_SCU->SFSP1_18 = EMC_PIN_SET | 7;  /* P1_18: D10                          */
 LPC_SCU->SFSP1_20 = EMC_PIN_SET | 7;  /* P1_20: D11                          */
 #endif
 LPC_SCU->SFSP2_0  = EMC_PIN_SET | 2;  /* P2_0:  A13                         */
 LPC_SCU->SFSP2_1  = EMC_PIN_SET | 2;  /* P2_1:  A12                         */
 LPC_SCU->SFSP2_2  = EMC_PIN_SET | 2;  /* P2_2:  A11                         */
 LPC_SCU->SFSP2_6  = EMC_PIN_SET | 2;  /* P2_6:  A10                         */
 LPC_SCU->SFSP2_7  = EMC_PIN_SET | 3;  /* P2_7:  A9                          */
 LPC_SCU->SFSP2_8  = EMC_PIN_SET | 3;  /* P2_8:  A8                          */
 LPC_SCU->SFSP2_9  = EMC_PIN_SET | 3;  /* P2_9:  A0                          */
 LPC_SCU->SFSP2_10 = EMC_PIN_SET | 3;  /* P2_10: A1                          */
 LPC_SCU->SFSP2_11 = EMC_PIN_SET | 3;  /* P2_11: A2                          */
 LPC_SCU->SFSP2_12 = EMC_PIN_SET | 3;  /* P2_12: A3                          */
 LPC_SCU->SFSP2_13 = EMC_PIN_SET | 3;  /* P2_13: A4                          */
 LPC_SCU->SFSP5_0  = EMC_PIN_SET | 2;  /* P5_0:  D12                         */
 LPC_SCU->SFSP5_1  = EMC_PIN_SET | 2;  /* P5_1:  D13                         */
 LPC_SCU->SFSP5_2  = EMC_PIN_SET | 2;  /* P5_2:  D14                         */
 LPC_SCU->SFSP5_3  = EMC_PIN_SET | 2;  /* P5_3:  D15                         */
 LPC_SCU->SFSP5_4  = EMC_PIN_SET | 2;  /* P5_4:  D8                          */
 LPC_SCU->SFSP5_5  = EMC_PIN_SET | 2;  /* P5_5:  D9                          */
 #ifdef CPU_256PIN
 LPC_SCU->SFSP5_6  = EMC_PIN_SET | 2;  /* P5_6:  D10                         */
 LPC_SCU->SFSP5_7  = EMC_PIN_SET | 2;  /* P5_7:  D11                         */
 #endif
 LPC_SCU->SFSP6_1  = EMC_PIN_SET | 1;  /* P6_1:  DYCS1                       */
 LPC_SCU->SFSP6_2  = EMC_PIN_SET | 1;  /* P6_3:  CKEOUT1                     */
 LPC_SCU->SFSP6_3  = EMC_PIN_SET | 3;  /* P6_3:  CS1                         */
 LPC_SCU->SFSP6_4  = EMC_PIN_SET | 3;  /* P6_4:  CAS                         */
 LPC_SCU->SFSP6_5  = EMC_PIN_SET | 3;  /* P6_5:  RAS                         */
 LPC_SCU->SFSP6_6  = EMC_PIN_SET | 1;  /* P6_6:  BLS1                        */
 LPC_SCU->SFSP6_7  = EMC_PIN_SET | 1;  /* P6_7:  A15                         */
 LPC_SCU->SFSP6_8  = EMC_PIN_SET | 1;  /* P6_8:  A14                         */
 LPC_SCU->SFSP6_9  = EMC_PIN_SET | 3;  /* P6_9:  DYCS0                       */
 LPC_SCU->SFSP6_10 = EMC_PIN_SET | 3;  /* P6_10: DQMOUT1                     */
 LPC_SCU->SFSP6_11 = EMC_PIN_SET | 3;  /* P6_11: CKEOUT0                     */
 LPC_SCU->SFSP6_12 = EMC_PIN_SET | 3;  /* P6_12: DQMOUT0                     */
 LPC_SCU->SFSPA_4  = EMC_PIN_SET | 3;  /* PA_4:  A23                         */
 //  LPC_SCU->SFSPD_0  = EMC_PIN_SET | 2;  /* PD_0:  DQMOUT2                     */
 //  LPC_SCU->SFSPD_1  = EMC_PIN_SET | 2;  /* PD_1:  CKEOUT2                     */
 //  LPC_SCU->SFSPD_2  = EMC_PIN_SET | 2;  /* PD_2:  D16                         */
 //  LPC_SCU->SFSPD_3  = EMC_PIN_SET | 2;  /* PD_3:  D17                         */
 //  LPC_SCU->SFSPD_4  = EMC_PIN_SET | 2;  /* PD_4:  D18                         */
 //  LPC_SCU->SFSPD_5  = EMC_PIN_SET | 2;  /* PD_5:  D19                         */
 //  LPC_SCU->SFSPD_6  = EMC_PIN_SET | 2;  /* PD_6:  D20                         */
 //  LPC_SCU->SFSPD_7  = EMC_PIN_SET | 2;  /* PD_7:  D21                         */
 //  LPC_SCU->SFSPD_8  = EMC_PIN_SET | 2;  /* PD_8:  D22                         */
 //  LPC_SCU->SFSPD_9  = EMC_PIN_SET | 2;  /* PD_9:  D23                         */
 LPC_SCU->SFSPD_10 = EMC_PIN_SET | 2;  /* PD_10: BLS3                        */
 LPC_SCU->SFSPD_11 = EMC_PIN_SET | 2;  /* PD_11: CS3                         */
 LPC_SCU->SFSPD_12 = EMC_PIN_SET | 2;  /* PD_12: CS2                         */
 LPC_SCU->SFSPD_13 = EMC_PIN_SET | 2;  /* PD_13: BLS2                        */
 LPC_SCU->SFSPD_14 = EMC_PIN_SET | 2;  /* PD_14: DYCS2                       */
 LPC_SCU->SFSPD_15 = EMC_PIN_SET | 2;  /* PD_15: A17                         */
 LPC_SCU->SFSPD_16 = EMC_PIN_SET | 2;  /* PD_16: A16                         */
 LPC_SCU->SFSPE_0  = EMC_PIN_SET | 3;  /* PE_0:  A18                         */
 LPC_SCU->SFSPE_1  = EMC_PIN_SET | 3;  /* PE_1:  A19                         */
 LPC_SCU->SFSPE_2  = EMC_PIN_SET | 3;  /* PE_2:  A20                         */
 LPC_SCU->SFSPE_3  = EMC_PIN_SET | 3;  /* PE_3:  A21                         */
 LPC_SCU->SFSPE_4  = EMC_PIN_SET | 3;  /* PE_4:  A22                         */
 //  LPC_SCU->SFSPE_5  = EMC_PIN_SET | 3;  /* PE_5:  D24                         */
 //  LPC_SCU->SFSPE_6  = EMC_PIN_SET | 3;  /* PE_6:  D25                         */
 //  LPC_SCU->SFSPE_7  = EMC_PIN_SET | 3;  /* PE_7:  D26                         */
 //  LPC_SCU->SFSPE_8  = EMC_PIN_SET | 3;  /* PE_8:  D27                         */
 //  LPC_SCU->SFSPE_9  = EMC_PIN_SET | 3;  /* PE_9:  D28                         */
 //  LPC_SCU->SFSPE_10 = EMC_PIN_SET | 3;  /* PE_10: D29                         */
 //  LPC_SCU->SFSPE_11 = EMC_PIN_SET | 3;  /* PE_11: D30                         */
 //  LPC_SCU->SFSPE_12 = EMC_PIN_SET | 3;  /* PE_12: D31                         */
 //  LPC_SCU->SFSPE_13 = EMC_PIN_SET | 3;  /* PE_13: DQMOUT3                     */
 //  LPC_SCU->SFSPE_14 = EMC_PIN_SET | 3;  /* PE_14: DYCS3                       */
 //  LPC_SCU->SFSPE_15 = EMC_PIN_SET | 3;  /* PE_15: CKEOUT3                     */
 LPC_EMC->CONTROL  = 0x00000001;       /* EMC Enable                         */
 LPC_EMC->CONFIG   = 0x00000000;       /* Little-endian, Clock Ratio 1:1     */
 div = 0;
 if (SystemCoreClock > 120000000UL) {
 /* Use EMC clock divider and EMC clock output delay */
 div = 1;
 /* Following code must be executed in RAM to ensure stable operation      */
 /* LPC_CCU1->CLK_M4_EMCDIV_CFG = (1 << 5) | (1 << 2) | (1 << 1) | 1;      */
 /* LPC_CREG->CREG6 |= (1 << 16);       // EMC_CLK_DIV divided by 2        */
 /* while (!(LPC_CCU1->CLK_M4_EMCDIV_STAT & 1));                           */
 /* This code configures EMC clock divider and is executed in RAM          */
 for (n = 0; n < emcdivby2_szw; n++) {
 emcdivby2_buf[n] =  *((uint32_t *)emcdivby2_ram + n);
 *((uint32_t *)emcdivby2_ram + n) = *((uint32_t *)emcdivby2_opc + n);
 __ISB();
 ((emcdivby2 )(emcdivby2_ram+1))(&LPC_CREG->CREG6, &LPC_CCU1->CLK_M4_EMCDIV_CFG, (1 << 5) | (1 << 2) | (1 << 1) | 1);
 *((uint32_t *)emcdivby2_ram + n) = emcdivby2_buf[n];
 /* Configure EMC clock-out pins                                             */
 LPC_SCU->SFSCLK_0 = EMC_PIN_SET | 0;  /* CLK0                               */
 LPC_SCU->SFSCLK_1 = EMC_PIN_SET | 0;  /* CLK1                               */
 LPC_SCU->SFSCLK_2 = EMC_PIN_SET | 0;  /* CLK2                               */
 LPC_SCU->SFSCLK_3 = EMC_PIN_SET | 0;  /* CLK3                               */
 /* Static memory configuration (chip select 0)                              */
 //#if (USE_EXT_STAT_MEM_CS0)
 //  LPC_EMC->STATICCONFIG0  = (1 <<  7) | /* Byte lane state: use WE signal     */
 //                            (2 <<  0) ; /* Memory width 32-bit                */
 //  LPC_EMC->STATICWAITOEN0 = (0 <<  0) ; /* Wait output enable: No delay       */
 //  /* Set Static Memory Read Delay for 90ns External NOR Flash                 */
 //  LPC_EMC->STATICWAITRD0  = 1 + EMC_NANOSEC(90, SystemCoreClock, div);
 //  LPC_EMC->STATICCONFIG0 |= (1 << 19) ; /* Enable buffer                      */
 //#endif
 (1 <<  0) ; /* Memory width 32-bit                */
 //LPC_EMC->STATICCONFIG0 |= (1 << 19) ; /* Enable buffer                      */
 #endif
 #if (USE_EXT_STAT_MEM_CS1)
 LPC_EMC->STATICCONFIG1  = (1 <<  7) | /* Byte lane state: use WE signal     */
 LPC_EMC->STATICWAITOEN1 = (0 <<  0) ; /* Wait output enable: No delay       */
 LPC_EMC->STATICWAITRD1  = 1 + EMC_NANOSEC(90, SystemCoreClock, div);
 //LPC_EMC->STATICCONFIG1 |= (1 << 19) ; /* Enable buffer                      */
 #endif
 #if (USE_EXT_STAT_MEM_CS2)
 LPC_EMC->STATICCONFIG2  = (0 <<  8) | //延长等待使能
 (1 <<  0) ; /* Memory width 8-bit                */
 LPC_EMC->STATICWAITWEN2 = 0x05;//片选到写使能的延迟
 LPC_EMC->STATICWAITWR2  = 0x12;//写延迟
 LPC_EMC->STATICWAITOEN2 = 0x08;//(5 <<  0) ; /* Wait output enable: No delay       */
 LPC_EMC->STATICWAITRD2  = 0x0a;//1 + EMC_NANOSEC(90, SystemCoreClock, div);
 //LPC_EMC->STATICCONFIG2 |= (1 << 19) ; /* Enable buffer                      */
 #endif
 #if (USE_EXT_STAT_MEM_CS3)
 LPC_EMC->STATICCONFIG3  = (1 <<  7) | /* Byte lane state: use WE signal     */
 (1 <<  0) ; /* Memory width 16-bit                */
 LPC_EMC->STATICWAITWEN3 = 0;//片选到写使能的延迟
 LPC_EMC->STATICWAITWR3  = 0x01;//写延迟
 LPC_EMC->STATICWAITOEN3 = 0x00 ; /* Wait output enable: No delay       */
 LPC_EMC->STATICWAITRD3  =0x04;// 1 + EMC_NANOSEC(90, SystemCoreClock, div);
 //LPC_EMC->STATICCONFIG3 |= (1 << 19) ; /* Enable buffer                      */
 LPC_EMC->STATICWAITTURN3  =0x00;
 #endif
 /* Dynamic memory configuration (chip select 0)                             */
 #if (USE_EXT_DYN_MEM_CS0)
 /* Set Address mapping: 128Mb(4Mx32), 4 banks, row len = 12, column len = 8 */
 //  LPC_EMC->DYNAMICCONFIG0    = (1 << 14) |  /* AM[14]   = 1                   */
 //                               (0 << 12) |  /* AM[12]   = 0                   */
 //                               (2 <<  9) |  /* AM[11:9] = 2                   */
 //                               (2 <<  7) ;  /* AM[8:7]  = 2                   */
 /* Set Address mapping: 64Mb(4Mx16), 4 banks, row len = 12, column len = 8 */
 LPC_EMC->DYNAMICCONFIG0    = (0 << 14) |  /* AM[14]   = 0                   */
 (1 <<  9) |  /* AM[11:9] = 1                   */
 (1 <<  7) ;  /* AM[8:7]  = 1                   */
 LPC_EMC->DYNAMICRASCAS0    = 0x00000303;  /* Latency: RAS 3, CAS 3 CCLK cyc.*/
 LPC_EMC->DYNAMICREADCONFIG = 0x00000001;  /* Command delayed by 1/2 CCLK    */
 LPC_EMC->DYNAMICRP         = EMC_NANOSEC (20, SystemCoreClock, div);
 LPC_EMC->DYNAMICRAS        = EMC_NANOSEC (42, SystemCoreClock, div);
 LPC_EMC->DYNAMICSREX       = EMC_NANOSEC (63, SystemCoreClock, div);
 LPC_EMC->DYNAMICAPR        = EMC_NANOSEC (70, SystemCoreClock, div);
 LPC_EMC->DYNAMICDAL        = EMC_NANOSEC (70, SystemCoreClock, div);
 LPC_EMC->DYNAMICWR         = EMC_NANOSEC (30, SystemCoreClock, div);
 LPC_EMC->DYNAMICRC         = EMC_NANOSEC (63, SystemCoreClock, div);
 LPC_EMC->DYNAMICRFC        = EMC_NANOSEC (63, SystemCoreClock, div);
 LPC_EMC->DYNAMICXSR        = EMC_NANOSEC (63, SystemCoreClock, div);
 LPC_EMC->DYNAMICRRD        = EMC_NANOSEC (14, SystemCoreClock, div);
 LPC_EMC->DYNAMICMRD        = EMC_NANOSEC (30, SystemCoreClock, div);
 //  LPC_EMC->DYNAMICRP         = 0x0f;//EMC_NANOSEC (20, SystemCoreClock, div);
 //  LPC_EMC->DYNAMICRAS        = 0x0f;//EMC_NANOSEC (42, SystemCoreClock, div);
 //  LPC_EMC->DYNAMICSREX       = 0x0f;//EMC_NANOSEC (63, SystemCoreClock, div);
 //  LPC_EMC->DYNAMICAPR        = 0x0f;//EMC_NANOSEC (70, SystemCoreClock, div);
 //  LPC_EMC->DYNAMICDAL        = 0x0f;//EMC_NANOSEC (70, SystemCoreClock, div);
 //  LPC_EMC->DYNAMICWR         = 0x0f;//EMC_NANOSEC (30, SystemCoreClock, div);
 //  LPC_EMC->DYNAMICRC         = 0x1f;//EMC_NANOSEC (63, SystemCoreClock, div);
 //  LPC_EMC->DYNAMICRFC        = 0x1f;//EMC_NANOSEC (63, SystemCoreClock, div);
 //  LPC_EMC->DYNAMICXSR        = 0x1f;//EMC_NANOSEC (63, SystemCoreClock, div);
 //  LPC_EMC->DYNAMICRRD        = 0x0f;//EMC_NANOSEC (14, SystemCoreClock, div);
 //  LPC_EMC->DYNAMICMRD        = 0x0f;//EMC_NANOSEC (30, SystemCoreClock, div);
 WaitUs (100);
 LPC_EMC->DYNAMICCONTROL    = 0x00000183;  /* Issue NOP command              */
 WaitUs (10);
 LPC_EMC->DYNAMICCONTROL    = 0x00000103;  /* Issue PALL command             */
 WaitUs (1);
 WaitUs (1);
 LPC_EMC->DYNAMICREFRESH    = EMC_NANOSEC(  200, SystemCoreClock, div) / 16 + 1;
 WaitUs (10);
 //  LPC_EMC->DYNAMICREFRESH    = EMC_NANOSEC(15625, SystemCoreClock, div) / 16 + 1;
 WaitUs (10);
 LPC_EMC->DYNAMICCONTROL    = 0x00000083;  /* Issue MODE command             */
 /* Mode register: Burst Length: 4, Burst Type: Sequential, CAS Latency: 3   */
 //WR_MODE(((3 << 4) | 2) << 12);
 wtemp = *((volatile uint16_t *)(SDRAM_ADDR_BASE | (0x33<<11)));
 WaitUs (10);
 LPC_EMC->DYNAMICCONTROL    = 0x00000002;  /* Issue NORMAL command           */
 LPC_EMC->DYNAMICCONFIG0   |= (1 << 19);   /* Enable buffer                  */
 #endif
